Author Topic: Control Arduino from WIndows using Python  (Read 1188 times)
1st post attempt failed so this one is not as long winded
This code
from firmata import *
import time
a = Arduino("COM32", baudrate=57600) # Baudrate must match rate set in sketch
#time.sleep(3)
a.pin_mode(12, firmata.OUTPUT)
print "wait"
time.sleep(2)
print "Go"
b=1
while True:
    a.digital_write(12, firmata.HIGH)
    time.sleep(1)
    a.digital_write(12, firmata.LOW)
    time.sleep(1)
    print "count" , b
    b= b +1
#a.serial.close()
Stops after 5 counts - ctrl-c takes tens secs to hand back control and then it give this
Traceback (most recent call last):
  File "E:\Dropbox\Private\arduino\py\firmatatest.py", line 12, in <module>
  File "build\bdist.win32\egg\firmata\firmata.py", line 91, in digital_write
    self.serial.write(chr(self.digital_output_data[port_number] >> 7))
  File "C:\Python27\lib\site-packages\serial\serialwin32.py", line 268, in write
    err = win32.GetOverlappedResult(self.hComPort, self._overlappedWrite, ctypes.byref(n), True)
KeyboardInterrupt
any ideas why and what to do about it or alternative working methods of switching pins off and on using Python from Windows?
regards
Simon
Seattle, WA USA
Seattle, WA USA
a = Arduino("COM32"
32? You need to shitcan whatever application is abusing your COM ports. I never get a number above 8 when connecting my Arduinos.
"Ditch" might be the nice term to use over this side of the pond smiley
i don't think that the high com port num is the problem as the Firmate_Test.exe prog works just fine (unless Python on Windows can't handle it???)
(I'm running an 8 Yr old XP machine here that has had more USB kit plugged into it over the years that I've had hot dinners)
I did reset a com port to a lower number a few years ago  so might try doing it again.
regards
Simon
made no diff - switched it down to com2 - still stopped after 5 iterations smiley-sad
Simon
this is getting wierder !
I'd left the python prog running since last post and just noticed my LED on in 12 going off and on - switched to my Python console and the count is now up to 43!
Simon
Netherlands
So consider solved, but not understood?
Rob Tillaart
Not at all smiley
Over an hour the count should have got to 1800 smiley
Simon
Finally after many days of googling and trying I've manged to get a continous blink and read an analog input program running smiley
from pyfirmata import Arduino, util
import time
a = Arduino("COM2", baudrate=57600) # Baudrate must match rate set in sketch
print "wait"
time.sleep(2)
print "Go"
it = util.Iterator(a)
it.start()
a.analog[5].enable_reporting()
while True:
    a.digital[12].write(1)
    time.sleep(1)
    a.digital[12].write(0)
    time.sleep(1)
    print "analog 5" , a.analog[5].read()
I downloaded pyfirmata from here
https://bitbucket.org/tino/pyfirmata
and added to my python 2.7 install by cd ing to my download location
E:\downloads\tino-pyfirmata-4bed4280dd31\tino-pyfirmata-4bed4280dd31
and then typing
c:\Python27\python.exe setup.py install
regards
Simon
« Last Edit: November 18, 2012, 04:10:26 pm by simplesi » Logged
Netherlands
Thanks for sharing!
Rob Tillaart
