Topic: Temperature Sensor LM60 (Read 8379 times) previous topic - next topic
Papa G
You're right. I just simplified the equation a little more.
I get the correct answer for your hypothesis of 424 mV measured with both your equation and mine, 0. Your original question implied that you were getting an error. Did you edit your original equation or just solve it incorrectly? Anyway, the answer to your original question the way it stands now is both your code's opinion and your opinion are correct.
KenshinPT
Thank you all mates! You helped me solving the problem.
I was doing my math wrong. I was confusing ADC readings with miliVolts!!!  :smiley-red:
The code is this:
Code: [Select]
void WriteTemperatureOnLCD(void)
  k++;
  if (k == 50)
   Vin=0;
   temp=0;
   for(j=0 ; j<=49 ; j++)
     samples[j] = (analogRead(analogtemp)); //Here you get a value from 0 to 1023. If Vref is 1100mV, then 1023 represents a Vin = 1023*1100/1024 = 1098.93mV.
     Vin = Vin + samples[j]*1089/1024; //Here you convert from ADC to milivolt -> Voltage = ADC*Vref/1024
   Vin=Vin/50;
   Serial.println(Vin);
   lcd.setCursor(9, 0);
   lcd.print(Vin, 1);
   lcd.print("mV");
  if (k == 100)
    temp = (Vin / 6.250) + minimum;
    if ( (temp >=0) & (temp <10) )
      lcd.setCursor(8, 0);
      lcd.print("   ");
      lcd.print(temp, 1);
    if ( (temp >=10) & (temp <100) )
      lcd.print("  ");
      lcd.print(temp, 1);
    if (temp >=100)
      lcd.print("    Hi");
    if ( (temp >-10) & (temp <0) )
      lcd.print("  ");
      lcd.print(temp, 1);
     if (temp <=-10)
      lcd.print("    Lo");
Papa G
Sometimes it helps just to think through it out loud. You don't say what type your variable "Vin" is but if it's an integer you might want to make it an unsigned int as it could, theoretically, get larger than a regular int.
KenshinPT
#18
Nov 15, 2012, 11:44 am Last Edit: Nov 15, 2012, 12:18 pm by KenshinPT Reason: 1
Yah! You're right :)
About Vin, I declared it as a double :) Temp is also a double!
About variable "samples[50]"... each sample is an integer [0 - 1023].
However, adding 50 integers and then divide all by 50 the "samples" variable could NOT be an integer.
That is, if all samples are 500 (ADC). Then the sum is 50*500 = 25000. Then, dividing all by 50, the average value is 500!!! OK, it's an integer!
But if 49 samples are 500 (ADC). and the last one is 501. The average value is  500.02 :)
If "samples[50]" is declared as a integer, it would be rounded down to 500. But the real value is 500.02.
So, I also declared it as a double!
Thank you so much for your help!
Regards.
