Loading...
Pages: [1]   Go Down
Author Topic: Power consumption to write to SD card?  (Read 2547 times)
Offline Offline
Jr. Member
View Profile
I'm trying to determine power consumption of my project.  It's a fairly straightforward circuit to download data over a serial interface, process it, and save it to an SD card.  I'm using a Teensy 2.0 with the pjrc.com microSD adapter. Unfortunately, it's going to be a few weeks until I can test it in action.  On the bench, I can power everything up and initialize the SD card, and measure the power consumption while I do that (~55 mA at 5v).  Will actually writing to the SD card make a significant difference, or can I be reasonably confident in that figure?
Logged
Rapa Nui
Offline Offline
God Member
Pukao hats cleaning services
View Profile
Sdcards can take between 5-40mA, based on type and on what they do actually (init, read, write, idle..). Take as a worst case 40mA. The current consumption has peeks, so provide a good decoupling near the sdcard's socket.
P.
« Last Edit: November 15, 2012, 06:28:34 pm by pito » Logged
Offline Offline
Jr. Member
View Profile
Wow--up to 40 mA is a surprise.  Definitely will need to test it out in action.
Logged
Miramar Beach, Florida
Offline Offline
Faraday Member
View Profile
SanDisk datasheet states their microSD card read/write could use 100ma.  smiley-sad
Logged
Offline Offline
Jr. Member
View Profile
Is that the SD card you have?
Logged
Offline Offline
Faraday Member
View Profile
If you are aiming that at me, the answer is yes. That is what I have. But mine is on an ethernet shield, and it has its own 3.3v regulator for the onboard stuff.
Logged
Offline Offline
Jr. Member
View Profile
Ok...Thanks. I am using the same one. Wow 100ma? That is surprising!
Logged
Offline Offline
Faraday Member
View Profile
Page 2-1 has the specs for read and write.
http://media.digikey.com/pdf/Data%20Sheets/M-Systems%20Inc%20PDFs/SD%20Card%20Prod%20Family%20OEM%20Manual.pdf
Logged
Offline Offline
Jr. Member
View Profile
Sounds like a job for the min/max mode on the DMM, and maybe checking it out with a couple of different uSD cards.
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
You won't get the answer with a DMM.  The max current occurs while flash is being programmed.  This is a brief interval and occurs at random times determined by the SD card's flash controller.  A DMM is too slow to measure this.
80 ma is common for consumer uSD cards.
Plan on 100 ma.  Some cards hit 150 ma peak for 10 us so good bypass caps are needed.
Some older SDHC cards require 200 ma for write.
Logged
Pages: [1]   Go Up
Print
Jump to:
