Pages: [1] 2   Go Down
Author Topic: My Servo won't move [SOLVED]  (Read 626 times)
Against Stupidity, the gods themselves contend in vain.
I have a program that receives data over Serial1 of the mega 2560. The data is a series of bytes that represent a number in english from about -10 to 10, followed by an 'E'. anyway, what this is supposed to do is map the number to 0 to 179 for the servo, and write it to the motor. The problem is that after initially moving the servo to 90, nothing happens to the servo. I know from the Serial output that the values are being manipulated correctly, so it is definitely a problem with the implementation of Servo. The hardware is right because the servo sweep example works. Any ideas? Also, if anyone knows an easier way to cast from a character array to a float, that would be much appreciated.
#include <Servo.h>
char byteIn;
char numberChar[6];
int sVal;
int x;
int y;
float number = 0.000;
Servo myservo;
  Serial1.begin(9600);       // start serial communication at 9600bps
  myservo.attach(9);
  myservo.write(90);
  if (Serial1.available())
    byteIn = Serial1.read();
    if (byteIn == 'E')
     x = 0;
     y = 0;
     if (numberChar[0]=='-')\
      y = 1;
     number = numberChar[0+y]-'0';
     number += ((numberChar[2+y]-'0')/10.0);
     number += ((numberChar[3+y]-'0')/100.0);
     number += ((numberChar[4+y]-'0')/1000.0);
      number = number*-1;
     sVal = (int)map(number, -10, 10, 0, 179);
     myservo.write(sVal);
     Serial.println(number);
     Serial.println(sVal);
     delay(10);
     numberChar[x] = byteIn;
     x++;
« Last Edit: November 14, 2012, 03:03:47 pm by InventiousTech » Logged
UK
Those Serial print statements are rather anonymous so it'd be easy to be mistaken about which value is which. I suggest you prefix each output with the name of the value you're printing. If you still think the number processing part is correct, then post the input and output from running the sketch and describe what the servo does.
Wow, that was fast. Ok. how about this:
#include <Servo.h>
char byteIn;
char numberChar[6];
int sVal;
int x;
int y;
Servo myservo;
  myservo.attach(9);
  myservo.write(90);
    if (byteIn == 'E')
     x = 0;
     y = 0;
      y = 1;
      number = number*-1;
     Serial.print("Raw value: ");
     Serial.print("Servo angle: ");
     Serial.println();
     delay(10);
     x++;
The input is actually coming from a python script running on scripting layer for android (SL4A) over bluetooth through a JY-MCU module to the Serial1 input, so it's a little hard to tell you exactly what is coming in, given that the data goes through a couple layers of android data manipulation then the bluetooth module, but I can tell you with reasonable certainty that the value coming in (for this example) is "5.057" as a series of bytes through Serial1. The output is
Raw value: 5.06
Servo angle: 134
So yes, I am pretty sure the data is right. The servo essentially does nothing. Hence the problem, since it started at 90 degrees and should be at 134.
UK
Can I introduce you to a good friend of mine?
How is the servo connected and powered?
Seattle, WA USA
Seattle, WA USA
0, 2, 3, 4? Are you missing a finger?
UK
No, he's missing the point   smiley-wink
Lol, yes I am missing the point.  smiley-wink
As to the servo, the white is connected to pin 9, the red is on VIN (Straight to the USB cable powering the device), and the black is obviously ground. Servos usually don't draw more than 50 mA, or so I have read, and USB can supply up to 500mA, so I think power is fine. What makes me think the wiring is good is that the "sweep" example works fine. I am at rather a loss here, not even getting any errors. I tried myservo.writeMicroseconds, mapping the data between 1000 and 2000, but that didn't work either.
Seattle, WA USA
Seattle, WA USA
Bullpoop. Servos can pull up to an amp under load.
If your servo works with the sweep example, then the problem isn't with the servo or the wiring. It is with the input that you are sending it, or the way you are processing that input.
What are you sending the Arduino? From what?
Valencia, Spain
What happens if you set the servo to 0 degrees in setup?
Paul, yes, but this servo is not under load, as I am just testing it. As to the input, my thoughts exactly. Read my first two posts to see what the input is.
If I set it to 0, then it goes to 0 and stays there for the duration of the program. Currently it goes to 90 and stays there.
Seattle, WA USA
Seattle, WA USA
You've explained what you think they are, not what they actually are, or where the input is coming from. Let's start with some really simple questions, one at a time.
Are you using the Serial Monitor to send data to the Arduino?
Au contraire, mon ami. I have explained exactly where the data is coming from. It originates in an android phone, it is sent by a python script to the JY-MCU bluetooth module connected to the Serial1 input of the Arduino Mega 2560. The data received by the bluetooth chip is sent to the arduino, fed into a character array until the program hits the end character 'E', then it converts the character array to a floating point number, maps it to the servo's range of 0 to 179, and sends it to the servo via myservo.write(sVal). The data is sent to the computer via Serial both before and after mapping and appears to be correct. Another possibly related issue is that I have the program set up to go to the thousandths place on the float value, but I appear to only be getting hundredths. For a specific example, refer to my second post.
Seattle, WA USA
Seattle, WA USA
The reason for the questions about the source of the data are because you are assuming that EVERY character read from the serial port is useful, and goes in a specific spot. If the sender is tacking a carriage return/line feed after the E, that will screw up the next iteration, since the carriage return and line feed are going where you expect the ones digit and the decimal point.
Getting? Or printing?
Yes, I see your point, but no there is no carriage return at the end of transmission. If I create a program that just  relays information from one serial to another, I just get a long string of numbers separated by 'E's. Also, I know that's not the case because the data being printed to the computer would also be screwed up, but it's not. About the precision, I am wondering what would cause there to be a difference between calculating hundredths and printing hundredths. By the way, thanks for the help so far.
Just for clarity, here is the python script on the phone:
import android, time
BT_DEVICE_ID = '00:12:09:13:97:48'
droid = android.Android()
droid.bluetoothConnect('00001101-0000-1000-8000-00805F9B34FB', BT_DEVICE_ID)
x = 0
while x<100:
droid.startSensingTimed(1, 25)
time.sleep(0.1)
s4 = droid.sensorsReadAccelerometer().result
droid.stopSensing()
ret = round(s4[1], 3)
droid.bluetoothWrite(str(ret)+"E")
print(ret)
x += 1
exit()
« Last Edit: November 14, 2012, 08:15:53 am by InventiousTech » Logged
UK
The default two places of decimals for the "print" method?
Pages: [1] 2   Go Up
