Topic: Arduino Due Inputs (Read 1 time) previous topic - next topic
bblanchon
Hello,  :)
Does anybody know what is the intensity consumed by digital inputs of Arduino Due ? I need this information because I have to convert a 5V signal from a sensor to a 3.3V signal for the Arduino, and I would like to use a voltage divider to simplify components used. Maybe it would be better to use a transistor...
Thank you for your help !
bblanchon
stimmer
According to the data sheet it is 2-30 nA (nanoamps) so you'll be fine with the voltage divider.
Due VGA library - http://arduino.cc/forum/index.php/topic,150517.0.html
bblanchon
Thank you for your answer !
Where did you find this information ? Because I couldn't find it in the datasheet...
Thank you again !
stimmer
It's the input leakage current, page 1391
bblanchon
