Topic: power for rf module (Read 940 times) previous topic - next topic
majenko
#15
Nov 15, 2012, 01:30 am Last Edit: Nov 15, 2012, 01:33 am by majenko Reason: 1
Ok, so I can use a 9v battery then, right?
Yes... kind of.
The little PP3 9V batteries don't last long though, as they have very little capacity, and with a linear regulator they last even less time.
If you want it to last a while you should be looking into other power sources, like Lithium Ion / Lithium Polymer, and switching (buck / boost) regulators.
A typical PP3 has only 565 mAh, whereas your normal AA battery has 1800-2600 mAh.
be80be
#16
Nov 15, 2012, 01:59 am Last Edit: Nov 15, 2012, 02:04 am by be80be Reason: 1
Just put a diode coming from the positive side of the battery it will drop you down enough to make
the receiver work
4 AAA one diode makes 5.3 volts and will keep you from hooking the battery's wrong  XD
thedovid
Thank you to all of you.
I got it working with that 5v regulator and the 4 AA batteries.
cool cool.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
