Pages: [1] 2   Go Down
Author Topic: Single transistor constant current power led driver.  (Read 1477 times)
I've seen a lot of constant current led driver circuits, however i've never seen anyone using just one transistor.
With the right resistor at the base of a transistor, you can determin the current flowing through it, right?
Why does it not seem possible to make a constant current power led driver this way?
Cape Town South Africa
A newbie with loads of posts, and still so much to learn !
heres a circuit which I have used, if you use an LED in place of the 2 diodes, the temperature coefficient of the transistor tends to cancel out.
You just adjust the value of the emitter res to set the current through the LEDs which can be run from an unregulated supply
We live in the era of the smart phones and stupid people.
Does the "33R" get the entire current from the led's through it?
If so, i'll need a high wattage resistor for that, right?
All you need is a votlage reference - that can be diodes, other transistors, zeners, true voltage references, or even a resistive divider (not as good).
Sometimes people use leds as voltage references too.
To be honest, i don't quite get what the schematic, and the voltage reference does, could you explain it to me?
Valencia, Spain
Let's see if I get it (I'm not the best at electronics so I might be wrong...):
The transistor's resistance depends on the difference between base and emitter (Vbe). In this circuit the emitter isn't connected to ground so the voltage difference depends on the ratio of LED resistance to emitter resistor (they make a voltage divider). ie. Vbe isn't 1.4.
If I raise the supply voltage, the voltage at the transistor's emitter goes up, Vbe goes down. The transistor's resistance increases, the LED current goes down.
If I lower the supply voltage, the voltage at the transistor's emitter goes down, Vbe goes up. The transistor's resistance decreases, the LED current goes up.
The two diodes function as a voltage clamp. When drive goes h igh (sufficient for the diode to conduct), the base is held at approximately 1.4v (forward voltage drop for the diodes). So the voltage on the 33r resistor is 1.4v - .7v(the transistor's Vbe) = 0.7v. So the current goes through the transistor and the led must be 0.7v/33 = 20ma. Give or take a few.
Essentially it is using the diodes as a voltage reference. As such, you can replace the diodes with other voltage references, like a zener, or a led, etc.
Denmark
That worked well.
I made a little experiment:
I used 2 LED's on the base and a 330Ohm resistor on the emitter.
With a LED on the colecctor I measured 0.9 mA
With a light bulb (4,8V 0,5A) I measured 1.0 mA
Manchester (England England)
Solder is electric glue
Yes it does, you will need to work out how much power the resistor dissipates depending on the current, I squared R
Think of it like this. The 33R resistor drops a voltage according to how much current is flowing. This in turn raises up the voltage on the emitter and throttles back the base current until an equilibrium is reached. If more current flows through the LEDs, because they heat up, then there will be more current through the 33R and the voltage across it would like to rise but this turns off the transistor a bit more and so in effect nothing happens.
The resistor is acting as a feed back mechanism for the transistor and thus supplying a constant current in the light of any changes in the load. The value of this constant current is controlled by the size of this resistor. You want more current, you make that resistor smaller so more current has to flow through it in order to develop sufficient voltage to throttle off the transistor.
Valencia, Spain
So...if I know what the 'drive' voltage is (eg. 5V for an Arduino output pin) I don't need the diodes between the transistor base and ground. I can replace them with whatever resistor gives me 1.4V at the transistor base?
That would give me a constant current with three resistors and a transistor.
You could but it would not have the degree of stability that the diodes have with the voltage being independent (ish) of the current through them.
Denmark
I have one more question to Boffin1's schematic.
I have tried with a emitter resistor at 5 Ohm and different supply voltages, and I get these results
Supply Voltage  Collector current mA
3.8      280
4.5      310
7.6      450
I use a BC337 and to LED's on basis
Are these values as expected ?
I was hoping for a constant current independent of voltage to drive my 1W LED's
Valencia, Spain
One Watt?
You probably need a lower value resistor between 'drive' and 'base' or the transistor can't turn fully on.
Denmark
One Watt?
Yes 350 mA  - 3V
Ok, I wil try. In the above example my base current is 1.6, 2, 5 mA, with a 1kOhm resistor, so I am in OutputPin safe area
Thanks for your answer
Not really sure what that means.
No. If you have the circuit properly configured, you should see very little variance on the collector current.
Pages: [1] 2   Go Up
