Topic: 3.2" TFT LCD Shield + Display w SD Socket for Arduino Mega 2560, SD Problem (Read 12326 times) previous topic - next topic
guilherme_ebio
Hi, I have a 3.2" TFT LCD Shield + Touch Panel Display w SD Socket for Arduino Mega 2560 A080, this one http://www.aliexpress.com/snapshot/203506212.html, and I believe that the documentation to this shield id this one: http://iteadstudio.com/store/images/produce/Shield/Shields/ITDB02ArduinoMEGAsheild2.0/ITDB02%20Arduino%20MEGA%20shield%202.0.pdf
The LCD is working fine with the examples, using the library made by Henning (http://henningkarlsen.com/electronics/library.php?id=51),  but I can't connect to the SD card, I'm trying to use the SD examples that come which the Arduino just to see if it works, and I'm changing the CS PIN to 53, but yet i get the message "initialization failed. Things to check:" ...
The code is below, I think is something really stupid, but I can't figure it out.
Code: [Select]
  SD card test
This example shows how use the utility libraries on which the'
SD library is based in order to get info about your SD card.
Very useful for testing a card when you're not sure whether its working or not.
The circuit:
  * SD card attached to SPI bus as follows:
** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
** CS - depends on your SD card shield or module.
Pin 4 used here for consistency with other Arduino examples
created  28 Mar 2011
by Limor Fried
modified 9 Apr 2012
by Tom Igoe
// include the SD library:
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
const int chipSelect = 53;
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print("\nInitializing SD card...");
  // On the Ethernet Shield, CS is pin 4. It's set as an output by default.
  // Note that even if it's not used as the CS pin, the hardware SS pin
  // (10 on most Arduino boards, 53 on the Mega) must be left as an output
  // or the SD library functions will not work.
  pinMode(53, OUTPUT);     // change this to 53 on a mega
pinMode(4, OUTPUT);
digitalWrite(4, HIGH);
pinMode(42, OUTPUT);
digitalWrite(42, HIGH);
digitalWrite(53, LOW);
  // we'll use the initialization code from the utility libraries
  // since we're just testing if the card is working!
  if (!card.init(SPI_HALF_SPEED, chipSelect)) {
    Serial.println("initialization failed. Things to check:");
    Serial.println("* is a card is inserted?");
    Serial.println("* Is your wiring correct?");
    Serial.println("* did you change the chipSelect pin to match your shield or module?");
    return;
   Serial.println("Wiring is correct and a card is present.");
  // print the type of card
  Serial.print("\nCard type: ");
  switch(card.type()) {
    case SD_CARD_TYPE_SD1:
      Serial.println("SD1");
    case SD_CARD_TYPE_SD2:
      Serial.println("SD2");
    case SD_CARD_TYPE_SDHC:
      Serial.println("SDHC");
    default:
      Serial.println("Unknown");
  // Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
  if (!volume.init(card)) {
    Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
    return;
  // print the type and size of the first FAT-type volume
  uint32_t volumesize;
  Serial.print("\nVolume type is FAT");
  Serial.println(volume.fatType(), DEC);
  volumesize = volume.blocksPerCluster();    // clusters are collections of blocks
  volumesize *= volume.clusterCount();       // we'll have a lot of clusters
  volumesize *= 512;                            // SD card blocks are always 512 bytes
  Serial.print("Volume size (bytes): ");
  Serial.println(volumesize);
  Serial.print("Volume size (Kbytes): ");
  volumesize /= 1024;
  Serial.print("Volume size (Mbytes): ");
  volumesize /= 1024;
  Serial.println("\nFiles found on the card (name, date and size in bytes): ");
  root.openRoot(volume);
  // list all files in the card with date and size
  root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
Thanks for your time and attention.
SurferTim
What pin is the microSD card slave select pin? I think I would put it on digital pin 49.
The Mega2560 SPI data lines are:
MISO -> pin 50
MOSI -> pin 51
SCK -> pin 52
Then I would try this in setup:
Code: [Select]
if(!SD.begin(49)) Serial.println("SD fail");
else Serial.println("SD ok");
guilherme_ebio
MISO -> pin 50
MOSI -> pin 51
SCK -> pin 52
Code: [Select]
You mean like this:
Code: [Select]
#include <SD.h>
File myFile;
   while (!Serial) {
  Serial.println("Initializing SD card...");
   pinMode(10, OUTPUT);
   //digitalWrite(53, LOW);
   //digitalWrite(10, HIGH);
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  myFile = SD.open("test.txt", FILE_WRITE);
  // if the file opened okay, write to it:
  if (myFile) {
    Serial.print("Writing to test.txt...");
    myFile.println("testing 1, 2, 3.");
// close the file:
    myFile.close();
    Serial.println("done.");
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
  // re-open the file for reading:
  myFile = SD.open("test.txt");
  if (myFile) {
    Serial.println("test.txt:");
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
    Serial.write(myFile.read());
    // close the file:
    myFile.close();
// nothing happens after setup
No the problem still persist...
Thanks
SurferTim
No. I mean like this:
Code: [Select]
#include <SD.h>
  // I have a w5100 connected, so I disable it here.
  pinMode(10,OUTPUT);
  digitalWrite(10,HIGH);
  Serial.print("Starting SD...");
  if(!SD.begin(49)) Serial.println("failed");
  else Serial.println("ok");
I bent D4 so it would not insert into the Arduino, then jumpered D4 to D49. I uploaded the code, powered down the Arduino for a few seconds, then ran that code.
Quote
Starting SD...ok
SurferTim
I'm using a Mega2560 with an ethernet shield to test. I bent D4 on the shield so the SD slave select would not connect there, then jumpered that to D49. That hardware setup works fine.
Are you certain the SPI lines are connected from the TFT to the Mega correctly? That would be the difference. I use the ICSP connector for the SPI data lines, not pins 50-52.
guilherme_ebio
I'm using the shield, I tried the jump but it did not worked, I have an Ethernet shield as well and the SD card works, but I need to use the SD Card in the LCD, because I'm not using the Ethernet shield in this project. i think that maybe is something in the software that i must change, but i don't now what.
Thanks
SurferTim
Are you certain the SPI data lines are connected correctly from the TFT to the Mega?
MISO -> 50
MOSI -> 51
SCK -> 52
guilherme_ebio
SurferTim
I took a look at the hardware on the TFT, and I see no logic converters for the inputs to the SD like on the ethernet shield. Otherwise, I'm not sure what is happening.
guilherme_ebio
Yes, but I dont think they would do the place to put de SD CARD and everthing else if not to let it working, thats why i think the change i need to do is on the Software... but i'm not sure.
HazardsMind
question, what is your chipselect at, 53 or 4.
Make it 4 and change pinMode(10, output) to 53 AND DONT MAKE IT LOW OR HIGH,
digitalWrite(53,LOW or HIGH) take this out of your code.
if all else fails, either update your software or downgrade it, it might just be a bug somewhere in the SD.h file.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
guilherme_ebio
No i update to version 1.0.2, and the problem persists, i made the SD chip select 4, and yet nothing, what else can this be?
Thanks
HazardsMind
When you bought the TFT did it come with any websites you can go to, custom libraries, examples, anything at all?
You may need to contact the seller and ask if he/ she knows where to get the correct code that works for that shield.
My GitHub:
HazardsMind
Quick question, there should be a little switch on the I/O shield, is that set to 5V or 3.3V, because according to the hardware page you provided, it says to have it set to 5V to work for the ARD mega 2560.
also your CS should be set to 53, my mistake.
My GitHub:
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
