Topic: 8-button pinpad wiring/programming (Read 977 times) previous topic - next topic
ppsieradzki
Hello all,
I am the proud owner of an 8-button pin pad, as seen in the link below:
http://dx.com/p/8-push-buttons-keypad-module-blue-150367?item=10
In my code, I commented out all the other buttons other than 0 and 1 for my sanity for the time being. The first time I tried this I had the G pin wired to GND and K0-K7 wired to a digital pin on my Mega 2560. That was giving me random results all the time so I tried something someone in another thread suggested:
http://arduino.cc/forum/index.php/topic,42198.0.html
I had the same problem as him, so I figured it must work. I figure now that the G pin on the keypad must be connected to a voltage source, so I plugged it into 5V. Still constantly on. Back to GND. Still constantly on. I am at wits end. I'm hoping someone else will see something I'm not?
Here is my code:
Code: [Select]
//Define keypad pins:
  const int BUTTON0= 53; //input pin for button 0 on keypad
  //button 0: Chandelier
  int valBUT0=0;
  const int BUTTON1= 52; //input pin for button 1 on keypad
  //button 1: Desk Lamp
  int valBUT1=0;
  const int BUTTON2= 23; //input pin for button 2 on keypad
  //button 2: Speakers
  int valBUT2=0;
  const int BUTTON3= 24; //input pin for button 3 on keypad
  //button 3: SELECT
  int valBUT3=0;
  const int BUTTON4= 25; //input pin for button 4 on keypad
  //button 4: Blinds
  int valBUT4=0;
  const int BUTTON5= 26; //input pin for button 5 on keypad
  //button 5: Floor Lamp
  int valBUT5=0;
  const int BUTTON6= 27; //input pin for button 6 on keypad
  //button 6: Emery Lamp
  int valBUT6=0;
  const int BUTTON7= 28; //input pin for button 7 on keypad
  //button 7: MENU
  int valBUT7=0;
  //Setup for keypad:
    pinMode(BUTTON0, INPUT); //BUTTON0 is an input (on pin 53)
    digitalWrite(BUTTON0, HIGH); //connects internal pullup resistor //write HIGH to input pin
    pinMode(BUTTON1, INPUT); //BUTTON1 is an input (on pin 52)
    pinMode(BUTTON2, INPUT); //BUTTON2 is an input (on pin 23)
    pinMode(BUTTON3, INPUT); //BUTTON3 is an input (on pin 24)
    pinMode(BUTTON4, INPUT); //BUTTON4 is an input (on pin 25)
    pinMode(BUTTON5, INPUT); //BUTTON5 is an input (on pin 26)
    pinMode(BUTTON6, INPUT); //BUTTON6 is an input (on pin 27)
    pinMode(BUTTON7, INPUT); //BUTTON7 is an input (on pin 28)
  // open the serial port at 9600 bps:
    //Check for input from Keypad:
      valBUT0= digitalRead(BUTTON0); //read input from Button 0 and store it
      //Button0: Chandelier
      valBUT1= digitalRead(BUTTON1); //read input from Button 1 and store it
      //Button1: Desk Lamp
      valBUT2= digitalRead(BUTTON2); //read input from Button 2 and store it
      //Button2: Speaker
      valBUT3= digitalRead(BUTTON3); //read input from Button 3 and store it
      //Button3: SELECT
      valBUT4= digitalRead(BUTTON4); //read input from Button 4 and store it
      //Button4: Blinds
      valBUT5= digitalRead(BUTTON5); //read input from Button 5 and store it
      //Button5: Floor Lamp
      valBUT6= digitalRead(BUTTON6); //read input from Button 6 and store it
      //Button6: Emery Lamp
      valBUT7= digitalRead(BUTTON7); //read input from Button 7 and store it
      //Button7: MENU
      //check whether in input is HIGH (button pressed):
      if(digitalRead(BUTTON0 == LOW))
        //switch is closed
        Serial.println("Chandelier");
        Serial.println(" ");
        delay(300);
        //switch is open
        //do nothing
      if(digitalRead(BUTTON1==LOW))
        //switch is closed
        Serial.println("Desk Lamp");
        delay(300);
        //switch is open
        //do nothing
      if(valBUT2==HIGH)
        Serial.println("Speaker");
        delay(300);
       //do nothing
      if(valBUT3==HIGH)
       Serial.println("SELECT");
       delay(300);
       //do nothing
      if(valBUT4==HIGH)
       Serial.println("Blinds");
       delay(300);
       //do nothing
      if(valBUT5==HIGH)
       Serial.println("Floor Lamp");
       delay(300);
       //do nothing
      if(valBUT6==HIGH)
       Serial.println("Emery Lamp");
       delay(300);
       //do nothing
      if(valBUT7==HIGH)
       Serial.println("MENU");
       delay(300);
} //END OF PROGRAM
I am getting so much rando
CrossRoads
Connect G to ground, turn on the internal pullups for ALL pins, take action when a pin goes low.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
