Loading...
Pages: [1]   Go Down
Author Topic: Question about Arduino Uno + Ethernet Shield pinout  (Read 257 times)
Offline Offline
Newbie
View Profile
What does it happen if I wanna use the digital pins 10, 11, 12, 13 as a output/input in my project with the ethernet shield plugged onto the UNO but without using the ethernet functions? I meant I wanna avoid plugging and unplugging the ethernet shield every time I don't wanna use it.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
If you don't include the Ethernet library in your sketch, and don't initialize the Ethernet class, then those pins are available for other uses. Just don't use the SD card, either.
Logged
Offline Offline
Newbie
View Profile
Ok... But is there any risk to damage the ethernet shield? Thanks paulS for your support!  smiley
Logged
Switzerland
Offline Offline
Faraday Member
View Profile
Quote
If you don't do anything that would also damage your Arduino (like applying over voltage to one of the pins), your Ethernet shield is not in risk.
Logged
Miramar Beach, Florida
Offline Offline
Faraday Member
View Profile
Careful on that! With the ethernet shield connected, and if D10 is LOW, the MISO (D12) line on the w5100 will go to OUTPUT. If you have an OUTPUT device on that pin expecting all on D12 to be high impedance, that would be incorrect, and possibly damaging to one of them.
Logged
Pages: [1]   Go Up
Print
Jump to:
