Loading...
Pages: [1] 2   Go Down
Author Topic: Pickit 2 with the ATMega  (Read 1607 times)
Offline Offline
Newbie
View Profile
Can I use it to program the chip on an Arduino board with the FTDI interface?
Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
What is "pickit 2"?
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Global Moderator
Melbourne, Australia
Online Online
Shannon Member
Lua rocks!
View Profile
WWW
An ICSP programmer device for the MicroChip range of processors.
I think the simple answer is: No.
Logged
Offline Offline
Edison Member
View Profile
Quote
Yes, you can.
Logged
Global Moderator
Online Online
Shannon Member
Lua rocks!
View Profile
WWW
Hmm. It looks like the PicKit has got a UART mode, so with the right connections it may work. I haven't tested it. Which Arduino board do you have? Why not just use the USB interface?
Logged
Offline Offline
Newbie
View Profile
I want to use a pair of barebones arduinos in my project, to cut costs. I just wanted to know if I can use my existing programmer, or if I'd have to buy a programmer.
Logged
Global Moderator
Online Online
Shannon Member
Lua rocks!
View Profile
WWW
Right, then we have to get the terminology right. Will these barebones boards have a bootloader on them? If not, the FTDI interface won't put it there. You need an ICSP programmer (one that uses the SPI interface) and I strongly doubt that the Pic Kit will do that. Its interface will be for PIC chips.
To save costs, if you have at least one Arduino already you can use that as an ICSP programmer. Search for "Arduino as ISP". I wrote a sketch that lets you put code onto SD cards and program bare baords, as described here:
http://www.gammon.com.au/forum/?id=11638
Example in use:
However you can get cheap ISP programmers.  eg. This one for $20:
http://www.pololu.com/catalog/product/1300
Logged
Offline Offline
Edison Member
View Profile
Quote
A standalone programmer for the price of a cup of latte.
Quote
Yes you can. But standalone programmer for avr is easier.
Logged
Offline Offline
Newbie
View Profile
So would the $15 pocket AVR programmer from Sparkfun be able to burn the bootloader?
I do have a couple of unburnt ATMegas in transit.
I can use the Pickit 2 to flash in place, but not to burn.
Logged
Valencia, Spain
Offline Offline
Faraday Member
View Profile
Yes. You can also use it to program ATtiny chips like the ATtiny84 and ATtiny85, etc. Make really small devices.
Logged
No, I don't answer questions sent in private messages...
Offline Offline
Edison Member
View Profile
Quote
Yes. Better yet, $5 avr programmers can do that too.
Logged
Offline Offline
Newbie
View Profile
Where's a $5 AVR programmer?
Logged
Rapa Nui
Offline Offline
Edison Member
Pukao hats cleaning services
View Profile
http://www.ebay.com/sch/i.html;jsessionid=B963627E40ECEEA2581357A48E3273E6?_sacat=0&_from=R40&_nkw=usbasp&_nkwusc=uspasp&_rdc=1
Logged
the land of sun+snow
Offline Offline
Edison Member
View Profile
WWW
Quote
Yes, you can.
Maybe in a parallel universe, ie programming a PIC. [would be nice if "just once" there was some
explanation attached to those comments, so we wouldn't have to be mind readers all the time].
I have PICKIT2 and PICKIT3 and actually do most of my programming on PICs. The PICKITs and PICs in
general use completely different programming algorithms from AVR, and have 3 output pins, Mclr/Vpp
[typically 13V for programming], plus SCLK and SDA lines, which are not Sclk, MOSI, MISO.
Also, I've used the UART mode of the PICKIT and it really doesn't work all that well for some reason,but
maybe could be jiggered for downloading sketches to an Arduino bootloader [which is unnecessary in any
case], but doubtful for recoding a raw AVR. Better to use an FTDI Friend/etc on a board without a USB
chip.
I also bought one of the AVR programming dongles from Pololu, but never could get it installed properly on
my notebook, so to burn bootloaders, I use 2 Arduino boards connected via the ICSP headers, and run the
bootloader sketch from the IDE on the master board.
Logged
Something different - Kitchen-Sink Arduino-compatible boards
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
http://dangerousprototypes.com/2010/04/07/program-your-avr-with-pickit2/
the owner seems to have disappeared, though.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
