Topic: generating a -10v...+10v control signal from an arduino (Read 15398 times) previous topic - next topic
Jonnym
Quote
your valve has minimum speed requirement (near dc control signal)
not sure if i understand this?? were you thinking that the control circuity in the valve needs to be updated at a certain minium frequency? which would mean the settling time of the RC portion needs to be somewhat fast?
how much would things change if i would change the PWM frequency that the Arduino is pushing out?
how is the pull-up resistor affecting the R/C filter, or does it? ( i would think this might be 'magic')
..and how did you come up with charge / discharge time ??
thanks
_J
dhenry
i was assuming that you dont need to change the valve quickly. aka no music fountain.
the existing time constant is very long. unless you loswer your pmw output below 200hz, i wouldnt worry about.
time constant is r*c. discharge tc is 10k*4.7u. chage-tc is 20k*4.7u.
dc42
One thing we don't know is the input resistance of the valve (I couldn't find it on the datasheet). That's why I suggested using an op-amp. For the circuit you have sketched to give you the full range of control, the valve input resistance will need to be at least 55K, if you are using a 12V supply for the circuit, 1K for R2, and 10K for R3.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
andybott
This has been one of the most usefull posts I have fond and I wanted to thank all the contributors for their time on this. blowing away the cobwebs of my electronics degree has been most enjoyable ! many thanks all
