...blowing up boards one connection at a time
« Reply #15 on: November 15, 2012, 09:27:26 pm » |
hi everyone, thanks for all the pointers and ideas- it seems that the catalog page was missing a bit of info that the data sheet filled in. who would have thought it to move this thing in direction "A", apply a voltage to pin D, this voltage is ranging from 0-10v. to move this thing in direction "B", apply 0-10v to pin E. pin D and pin E are to remain connected to their respective branches of the circuit. i would imagine i could break something it 10v was on pin D and pin E at the same time? the data sheet says that if only one signal pin is available, then the other needs to be grounded. since i will be using both signal pins - there is no need to ground the pin, when traveling in the opposite direction, correct? i'll keep reading a bit and post a circuit sketch in a bit -- again thanks for the help _Jon
the land of sun+snow
« Reply #16 on: November 15, 2012, 09:42:07 pm » |
I agree with dc42 that his ckt should work, and all the way from 0V to 10V output, as the LM358 opAmp has input common-mode range down to ground.
The one thing that may be an issue is that 1st-order filtering of the PWM signal will leave a little ripple on the DC-level, so the valve may jitter some. You can deal with that by using a PWM frequency much much greater than the R*C time constant of his filter, but this will also reduce the frequency response of the valve, if that's an issue.
« Reply #17 on: November 15, 2012, 10:20:15 pm » |
hi oric_dan, thanks for the reply --- although it is bit above my knowledge level. ...filtering of the PWM so if i look at it on a scope i'll see some stepped lines, and not super smooth, the faster the pwm frequency, the less noticeably this becomes? ...PWM frequency much much greater than the R*C time constant of his filter ??? the math of circuits has got me confused. i used to have respectable math skills, but haven't used them in many years. could you clarify a bit. ...response time of valve. --slow is fine. i'm putting together a parts order now... any suggestions? _J
« Reply #18 on: November 15, 2012, 10:27:16 pm » |
This should help explain it, http://www.google.com/search?hl=en&safe=off&q=PWM+ripple&bav=on.2,or.r_gc.r_pw.r_qf.&bpcl=38625945&biw=1153&bih=827&um=1&ie=UTF-8&tbm=isch&source=ogYou can see dc42's same ckt here, http://www.hoelscher-hi.de/hendrik/english/demux.htmFor a 1st-order RC low-pass filter, the 3dB or 'cutoff' frequency is given by F3db = 1/(2*pi*R*C). You want the PWM frequency to be maybe 5X this value to get reasonably small ripple. Probably better to directly access the Arduino PWM subsystem than to use the analogWrite() function, which I believe has a fairly low frequency. BTW, I find I'm using google images for almost everything now, in preference to a regular google search. Easier to zero in on the perfect website, :-).
« Last Edit: November 15, 2012, 10:31:02 pm by oric_dan(333) »
« Reply #19 on: November 15, 2012, 11:05:00 pm » |
hi guys, i am plugging numbers into this calculator... could you verify some of my assumption?? http://sim.okawa-denshi.jp/en/PWMtool.phpfPWM= 480 (this is the operating freq of the pwm timer? ) duty step -- the output i want. 50% if i wanted around 5v output, based on switching 0-10v R and C values?? I got a 'pretty' curve at R =5k and C =10u. Could i expect to get better?? what is the fc - cut off frequecy term mean? thanks jon
Anaheim CA.
Experienced old Whitebeard with a Full head of Hair...
« Reply #20 on: November 16, 2012, 01:08:28 am » |
It means the frequency at which the referenced level is reduced or increased (for a high pass filter) by 3 Db or a power factor of 2.
Bob
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
« Reply #21 on: November 16, 2012, 01:18:06 am » |
That site is very useful. The result with those numbers is not very good, so needing something more like Fpwm=10Khz, Fc=100Hz, or 100:1 to get low ripple.
5K and 10uF -> F3db = 3.18 Hz, which is quite low, but probably ok if all you're doing is changing slowly.
United Kingdom
« Reply #22 on: November 16, 2012, 01:29:52 am » |
My suggestion was 100K and 1uF, giving F3db = 1.59Hz and time constant = 100ms. I guess we need to know how fast the OP needs to move the valve.
« Reply #23 on: November 16, 2012, 01:34:19 am » |
Why aren't you asleep? It's 5:30 AM in the UK!
CO, USA
« Reply #24 on: November 16, 2012, 07:38:05 pm » |
anyone got a better grasp of technical german?? No but if you scroll down the data sheet the bottom half is repeated in English!  You could've really impressed us all by omitting that, and just posting the English part with a 'here you go!' ]
... it is poor civic hygiene to install technologies that could someday facilitate a police state. -- Bruce Schneier
Manchester (England England)
Solder is electric glue
« Reply #25 on: November 17, 2012, 12:32:51 am » |
Why aren't you asleep? It's 5:30 AM in the UK! Yes that is what I would like to know as well but for me this time. You could've really impressed us all by omitting that Yes though of that but opted for honesty, so never make a politician will I?
« Reply #26 on: November 21, 2012, 10:03:03 pm » |
Hi Guys,
Me again...
I'm confused at where the RC filter would be connected in the circuit. If I was switching a transistor with one of the pwm pins, the transistor is allowing the path to ground. Is the RC filter on the collector side or the emitter side? (thinking this is an NPN)
There is a path to ground via the capacitor, is the high freq. stuff is going this route? and that's the whole point...
thanks Jon
« Reply #27 on: November 22, 2012, 01:32:19 am » |
No that is totally wrong. Collector to pull up resistor to +12V. Collector to filter resistor. Other end of resistor to capacitor to ground and also to one of the inputs of your controller. You need two of these circuits one for each input. You also need a common ground.
« Reply #28 on: November 22, 2012, 11:51:11 am » |
...and base ? is this shown correctly?
..and emitter?.. is this show correctly?
..and load?.. is this shown correctly?
cheers.
« Reply #29 on: November 22, 2012, 12:24:27 pm » |
.and base ? is this shown correctly? Yes and emitter?.. is this show correctly? Yes and load?.. is this shown correctly? No. See previous answer.
