Topic: 8 bits is dead, long live 8 pins (Read 14558 times) previous topic - next topic
graynomad
For those who like the Attiny85 but need some more grunt, how about the new LPC800, 32-bits in a DIP8 package (and others)
http://www.nxp.com/news/press-releases/2012/11/nxp-revolutionizes-simplicity-with-lpc800.html
Surely this has to be a hobbyist's dream.
The only down side (and it can be a biggy in some applications) is no ADC, but there is this, 3 USARTs, 2 SPI, and an I2C interface with USART and I2C driver in ROM so they don't use any flash memory. 30Mhz with no crystal, CRC engine, boot loader in ROM, 16k flash and 4k RAM, full debugging support, yada yada yada.
I think I'm in love.
Quote
System:
* ARM Cortex-M0+ processor, running at frequencies of up to 30 MHz with single-cycle multiplier and fast single-cycle I/O port.
* ARM Cortex-M0+ built-in Nested Vectored Interrupt Controller (NVIC).
* System tick timer.
* Serial Wire Debug (SWD) and JTAG boundary scan modes supported.
* Micro Trace Buffer (MTB) supported.
Memory:
* Up to 16 kB on-chip flash programming memory with 64 Byte page write and erase.
* 4 kB SRAM.
* ROM API support:
* Boot loader.
* USART drivers.
* I2C drivers.
* Power profiles.
* Flash In-Application Programming (IAP) and In-System Programming (ISP).
Digital peripherals:
* High-speed GPIO interface connected to the ARM Cortex-M0+ IO bus with up to 18 General-Purpose I/O (GPIO) pins with configurable pull-up/pull-down resistors.
* GPIO interrupt generation capability with boolean pattern-matching feature on eight GPIO inputs.
* Switch matrix for flexible configuration of each I/O pin function.
* State Configurable Timer (SCT) with input and output functions (including captureand match) assigned to pins through the switch matrix.
* Multiple-channel multi-rate timer (MRT) for repetitive interrupt generation at up to four programmable, fixed rates.
* Self Wake-up Timer (WKT) clocked from either the IRC or a low-power, low-frequency internal oscillator.
* CRC engine.
* Windowed Watchdog timer (WWDT).
Analog peripherals:
* Comparator with external voltage reference with pin functions assigned or enabled through the switch matrix.
Serial interfaces:
* Three USART interfaces with pin functions assigned through the switch matrix.
* Two SPI controllers with pin functions assigned through the switch matrix.
* One I2C-bus interface with pin functions assigned through the switch matrix.
Clock generation:
* 12 MHz internal RC oscillator trimmed to 1 % accuracy that can optionally be used as a system clock.
* Crystal oscillator with an operating range of 1 MHz to 25 MHz.
* Programmable watchdog oscillator with a frequency range of 9.4 kHz to 2.3 MHz.
* 10 kHz low-power oscillator for the WKT.
* PLL allows CPU operation up to the maximum CPU rate without the need for a high-frequency crystal. May be run from the system oscillator, the external clock input CLKIN, or the internal RC oscillator.
* Clock output function with divider that can reflect the crystal oscillator, the main clock, the IRC, or the watchdog oscillator.
Power control:
* Integrated PMU (Power Management Unit) to minimize power consumption.
* Reduced power modes: Sleep mode, Deep-sleep mode, Power-down mode, and
Deep power-down mode.
* Power-On Reset (POR).
* Brownout detect.
* Unique device serial number for identification.
* Single power supply.
* Available as SO20 package, TSSOP20 package, TSSOP16, and DIP8 package.
Preliminary data sheet.
http://www.nxp.com/documents/data_sheet/LPC81XM.pdf
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
John_Smith
Oh dear
I only speak Arduino language :-(
45 years of editing projects with a knife and soldering iron, then I found Arduino !
CrossRoads
No EEPROM, ADC, PWM, only 18 IO and memory the size of a 168?
Seems a bit lacking compared to a '1284 even if it does run a little faster.
graynomad
Yes but compare it to any other DIP8 processors. I'm a big fan of the 1284, in fact I'm about to make a board with one, but it is 40/44 pins.
On the LPCs you can use flash for non-volatile storage, not as good as EEPROM I guess but usually good enough. Lack of an ADC is strange these days.
Quote
My LARD framework should fix that, if I ever get it finished that is :)
______
Rob
CrossRoads
Depends on the application I guess. I've never had a need to go that small. And if I did, I doubt I'd be doing tons of processing, probably just a little smart IO for a sensor.
retrolefty
My main WOW for this is that it means DIP packaged ARM uP will remain available at least for a while longer. Long live the DIP package.  ;)
Lefty
graynomad
Yeah, that's two DIP ARMs available now, a promising sign.
______
Rob
GoForSmoke
Economy driven chip evolution and 100's of newly opened niches?
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
graynomad
Quote
I think so. For example you could design your own small peripheral chips. Of course you can do that with a Tiny as well but this has more grunt.
The other day we had someone wanting 12 (I think) hardware serial ports. We suggested UARTs and co-processors, but the only real co-processor option was the Tiny2313 because the other small chips don't have UARTs, or I2C or real SPI.
This would have been a good option.
______
Rob
JChristensen
But it's only available in an 8-pin DIP??!! :-o  With all that capability a lot of it will necessarily go unused with only 8 pins. OK I guess if the price is right but it seems a bit of a shame...
graynomad
Yes it would have been nice to have the 16 and 20-pin versions in a DIP as well. Go figure.
______
Rob
JChristensen
Wow, missed this the first time through. They don't mention quantity, but even if that's at 1000 copies, it ought to still be very affordable in quantities of 1-10.  Definitely one to watch for, good catch!
Quote
Pricing for the LPC810 starts at $0.39 USD.
graynomad
Welcome to the world of 32-bit 555 timers :)
______
Rob
Palliser
4004 must be spinning in his grave...
graynomad
Man I remember getting a 4004 data sheet as a promo, I read it and couldn't for the life of me see how these microprocessors things could be useful for anything.
Wrong :)
Still at least I didn't put all my money into buggy-whip shares.
_____
Rob
