Loading...
Pages: [1]   Go Down
Author Topic: Right method for activating internal pull-up resistors  (Read 442 times)
Offline Offline
Newbie
View Profile
This is the method I've seen everywhere:
pinMode(pin, INPUT);
digitalWrite(pin, HIGH);
What happens if pin already is under a non-ground voltage? Between the pinMode and the digitalWrite the current can freely flow in and damage the pin, right?
Isn't more correct the reverse approach? (putting the pin HIGH and then changing the mode to INPUT)
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
How would it damage the pin? An input pin is high impedance.
Logged
Norfolk UK
Offline Offline
Edison Member
View Profile
pinMode(pin, INPUT_PULLUP); works on IDE v1.0 and up
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Just for interest, INPUT_PULLUP does it in the order: set-input-mode, set-pin-high:
Code:
} else if (mode == INPUT_PULLUP) {
uint8_t oldSREG = SREG;
                cli();
*reg &= ~bit;        // set to INPUT
*out |= bit;         // output HIGH
SREG = oldSREG;
Comments added by me.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Most times the setup for pins is done in setup(), and at that point all pins are in INPUT mode anyway (after reset).  If you have a signal that must be kept pulled-up across resets (and from power-up to sketch starting) then a physical pull-up resistor is called for.
Logged
Offline Offline
Newbie
View Profile
Nick Gammon:
Quote
doh! so the pull-up is just for avoiding floating values.
Riva:
Quote
One line of code less. Nice.
BTW, even if the pins default to INPUT, IMHO it is a good practice to explicitly set the mode. Sort of self-documenting software.
MarkT: Noted.
My circuit has some normally-open buttons. I was concerned about the possibility of having them pressed before the pin was configured. I see that there is no reason for worrying.
Thanks all.
Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
INPUT_PULLUP was added in 1.0.1:
ARDUINO 1.0.1 - 2012.05.21
* Added INPUT_PULLUP option for pinMode().  The INPUT mode now explicitly
  disables the pullup resistors.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Norfolk UK
Offline Offline
Edison Member
View Profile
Thanks for correcting me  smiley-red
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
 Some people wanting 'fool proof' button circuits will wire a series 200 ohm resistor from the I/O pin to the button switch as a extra safety measure, say from a human programming error where you set a pin to output by mistake (say setting it HIGH) and then the poor user presses the button wired to ground and poof goes the I/O pin. RuggedCircuits uses that in their ruggedized version of a arduino board.
Lefty
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Ach! I'd forgotten about that. So reversing the order won't work at all now.
Logged
Offline Offline
Newbie
View Profile
Lefty:
Quote
My brain-fart was caused by a tutorial giving precisely that advice:
http://www.ladyada.net/learn/arduino/lesson5.html
Quote
Whats this 100Ω resistor all about? There's a 100Ω resistor we use to connect the input pin to either HIGH or LOW voltage. Why is it there? Well, lets say you accidentally set P2 to be an OUTPUT type pin, but then you connected it to 5V. If you write a LOW to the pin (0V) but its connected to HIGH (5V), you've basically caused a short circuit at that pin. This isn't very good for the pin and could damage it! The 100Ω resistor acts as a buffer, to protect the pin from short circuits.
(I'm not blaming the tutorial, but my faulty memory.)
Logged
Pages: [1]   Go Up
Print
Jump to:
