Author Topic: Right method for activating internal pull-up resistors  (Read 436 times)
This is the method I've seen everywhere:
pinMode(pin, INPUT);
digitalWrite(pin, HIGH);
What happens if pin already is under a non-ground voltage? Between the pinMode and the digitalWrite the current can freely flow in and damage the pin, right?
Isn't more correct the reverse approach? (putting the pin HIGH and then changing the mode to INPUT)
Melbourne, Australia
Shannon Member
Lua rocks!
How would it damage the pin? An input pin is high impedance.
Norfolk UK
pinMode(pin, INPUT_PULLUP); works on IDE v1.0 and up
Shannon Member
Lua rocks!
Just for interest, INPUT_PULLUP does it in the order: set-input-mode, set-pin-high:
} else if (mode == INPUT_PULLUP) {
uint8_t oldSREG = SREG;
                cli();
*reg &= ~bit;        // set to INPUT
*out |= bit;         // output HIGH
SREG = oldSREG;
Comments added by me.
Most times the setup for pins is done in setup(), and at that point all pins are in INPUT mode anyway (after reset).  If you have a signal that must be kept pulled-up across resets (and from power-up to sketch starting) then a physical pull-up resistor is called for.
Nick Gammon:
doh! so the pull-up is just for avoiding floating values.
Riva:
One line of code less. Nice.
BTW, even if the pins default to INPUT, IMHO it is a good practice to explicitly set the mode. Sort of self-documenting software.
MarkT: Noted.
My circuit has some normally-open buttons. I was concerned about the possibility of having them pressed before the pin was configured. I see that there is no reason for worrying.
Thanks all.
Boston area, metrowest
INPUT_PULLUP was added in 1.0.1:
ARDUINO 1.0.1 - 2012.05.21
* Added INPUT_PULLUP option for pinMode().  The INPUT mode now explicitly
  disables the pullup resistors.
Norfolk UK
Thanks for correcting me  smiley-red
Left Coast, CA (USA)
Measurement changes behavior
 Some people wanting 'fool proof' button circuits will wire a series 200 ohm resistor from the I/O pin to the button switch as a extra safety measure, say from a human programming error where you set a pin to output by mistake (say setting it HIGH) and then the poor user presses the button wired to ground and poof goes the I/O pin. RuggedCircuits uses that in their ruggedized version of a arduino board.
Lefty
Shannon Member
Lua rocks!
Ach! I'd forgotten about that. So reversing the order won't work at all now.
Lefty:
My brain-fart was caused by a tutorial giving precisely that advice:
http://www.ladyada.net/learn/arduino/lesson5.html
Whats this 100Ω resistor all about? There's a 100Ω resistor we use to connect the input pin to either HIGH or LOW voltage. Why is it there? Well, lets say you accidentally set P2 to be an OUTPUT type pin, but then you connected it to 5V. If you write a LOW to the pin (0V) but its connected to HIGH (5V), you've basically caused a short circuit at that pin. This isn't very good for the pin and could damage it! The 100Ω resistor acts as a buffer, to protect the pin from short circuits.
(I'm not blaming the tutorial, but my faulty memory.)
