Topic: arduino mega serial talking with strings (Read 742 times) previous topic - next topic
feveran
Nov 16, 2012, 03:06 pm Last Edit: Nov 16, 2012, 03:29 pm by feveran Reason: 1
hi all,
i am trying to communicate a serial device (pic 12f) with arduino mega.
i connected device to serialport3. when i send command 'g' to serialport3, device blinks a led and sends a sentence like "ok now\n\r".
i send 'g' command to the device by sending 'a' command to arduino. also i want to see the device's reply from arduino serial monitor.
i see the led blinks but i couldn't read the sentence.
i am trying to modify serial event skecth, where problem can be?
Code: [Select]
String inputString = "";         // a string to hold incoming data
boolean stringComplete = false;  // whether the string is complete
inputString.reserve(200);
 Serial3.begin(9600);
 // reserve 200 bytes for the inputString:
  if (Serial.available())
  char ser = Serial.read();
  if(ser == 'a'){
  Serial3.write('g');
 if (stringComplete) {
   Serial.println(inputString);
   // clear the string:
   inputString = "";
void serialEvent() {
 while (Serial3.available()) {
   // get the new byte:
   char inChar = (char)Serial3.read();
   // add it to the inputString:
   inputString += inChar;
   // if the incoming character is a newline, set a flag
   // so the main loop can do something about it:
   if (inChar == '\n') {
     stringComplete = true;
Cybernetician
#1
Nov 16, 2012, 03:16 pm Last Edit: Nov 16, 2012, 03:39 pm by AWOL Reason: 1
[font=Verdana][[/font]code][font=Verdana][[/font]/code] use insert code.
Moderator edit: Dummy code tags corrected.
PaulS
Quote
Code: [Select]
There is a world of difference between a string and a String. The sooner that you learn what that one little letter difference means, the better.
Quote
I call by brother Tom by the name of George...
Code: [Select]
   if(ser == 'a'){
   Serial3.write('g');
Thanks for posting all this... Is your delete key broken?
Code: [Select]
You need to reserve 200 characters to hold a one letter command? Are you serious?
Quote
What sentence? The only code to output anything is commented out.
