Topic: CSV file read stops after 9 lines? (Read 4819 times) previous topic - next topic
seguinc
Good morning all,
I am in the process of assembling a project using an Arduino Mega 2560.  It consists, in part, of reading in a CSV data file that will have a sequence of a relay addresse followed by each relay's on-time and off-time.  As you can surmise; the sketch causes relays connected to the Mega to turn on then off.  The CSV is formatted with integers in the following manner: relay number, time on (in millis), time off (in millis) terminated by a new line.  Here is a sequence I used to test all relays (for now 16, but this project will have 32 relays in the end):
1,250,250
2,250,250
3,250,250
4,250,250
...etc, you can see where this is going.  I currently have the sketch designed so this information outputs to a serial monitor (on my Linux box, I use a serial port terminal which permits the ability to read in the CSV file directly from my PC and send it to the USB port);in order to see what the sketch is doing with the info.
The issue I have encountered is that the whole thing stops after the 9th relay.  I've tried changing the variable types, played with the on-times and off-times making them longer and shorter, but nothing seems to change.  I can only presume the Mega is running out of memory, but the array I use (data[3]) is recycled at every iteration, so the memory addresses used by the Mega have to be overwritten.  I attempted using the Serial.flush() function right after sending the data array to the relay activation subroutine, but it does not seem to help.
Here is the entire sketch:
Code: [Select]
int data[3];
int counter;
int inbyte;
int relaypin;
void setup(){
  // initialize serial communication:
  Serial.begin(19200);
  counter = 0;
  // initialize the relay pins:
  for (relaypin = 22; relaypin < 38; relaypin++) {
    pinMode(relaypin, OUTPUT);
void loop(){
  if (Serial.available()){
    inbyte = Serial.parseInt();// check for comma separated data
    data[counter] = inbyte;
    counter++;
    if(Serial.read() ==  '\n'){  // end of line test
      counter = 0;
      //send data to actRelay func
      actRelay(data);
      Serial.print("Relay:");
      Serial.println(data[0]);
      Serial.print("Time ON:");
      Serial.println(data[1]);
      Serial.print("Time OFF:");
      Serial.println(data[2]);
void actRelay(int* array){
        switch (data[0]) {
        case 1:
          digitalWrite(22, HIGH);
          delay(data[1]);
          digitalWrite(22,LOW);
          delay(data[2]);
        case 2:
          digitalWrite(23, HIGH);
          delay(data[1]);
          digitalWrite(23,LOW);
          delay(data[2]);
        case 3:
          digitalWrite(24, HIGH);
          delay(data[1]);
          digitalWrite(24,LOW);
          delay(data[2]);
        case 4:
          digitalWrite(25, HIGH);
          delay(data[1]);
          digitalWrite(25,LOW);
          delay(data[2]);
        case 5:
          digitalWrite(26, HIGH);
          delay(data[1]);
          digitalWrite(26,LOW);
          delay(data[2]);
        case 6:
          digitalWrite(27, HIGH);
          delay(data[1]);
          digitalWrite(27,LOW);
          delay(data[2]);
        case 7:
          digitalWrite(28, HIGH);
          delay(data[1]);
          digitalWrite(28,LOW);
          delay(data[2]);
        case 8:
          digitalWrite(29, HIGH);
          delay(data[1]);
          digitalWrite(29,LOW);
          delay(data[2]);
        case 9:
          digitalWrite(30, HIGH);
          delay(data[1]);
          digitalWrite(30,LOW);
          delay(data[2]);
        case 10:
          digitalWrite(31, HIGH);
          delay(data[1]);
          digitalWrite(31,LOW);
          delay(data[2]);
        case 11:
          digitalWrite(32, HIGH);
          delay(data[1]);
          digitalWrite(32,LOW);
          delay(data[2]);
        case 12:
          digitalWrite(33, HIGH);
          delay(data[1]);
          digitalWrite(33,LOW);
          delay(data[2]);
        case 13:
          digitalWrite(34, HIGH);
          delay(data[1]);
          digitalWrite(34,LOW);
          delay(data[2]);
        case 14:
          digitalWrite(35, HIGH);
          delay(data[1]);
          digitalWrite(35,LOW);
          delay(data[2]);
        case 15:
          digitalWrite(36, HIGH);
          delay(data[1]);
          digitalWrite(36,LOW);
          delay(data[2]);
        case 16:
          digitalWrite(37, HIGH);
          delay(data[1]);
          digitalWrite(37,LOW);
          delay(data[2]);
Thank you in advance for helping.
MarkT
You are not checking Serial.available() before every Serial.read() I fear - you must check on every single read.
PaulS
Quote
What good is blocking until all serial data has been sent, when you aren't sending any serial data?
seguinc
MarkT; thanks for the reply.  Would I then have to re-write the section that tests for the new line in the following manner?
Code: [Select]
void loop(){
    counter++;
    if (Serial.available() && Serial.read() ==  '\n'){  // end of line test
      counter = 0;
The original code seems to detect the \n (EOL).  I may be going about parsing the data in the wrong way.  This code has been edited from a few ideas I've found on this forum and others.
PaulS
Code: [Select]
That's not what parseInt() does.
seguinc
Hello PaulS
Can you explain what the Serial.parseInt() does?  It appears to function in my sketch as to actually parse the comma separated values in the file.  It returns the actual number in before each comma (which is what I need to pass on the the Switch subroutine in order to use the numbers to activate the relays and provide timing).
My sketch does not sanitize the data sent to it; ensuring it is numbers and not other characters: I am relying on the CSV to be correct to begin with.  I had used a simple Serial.read() command to get the data, but it returned the ascii code value for each one.  Made programming more complicated until I began experimenting with Serial.parseInt().  What I really need is the numbers, not their ascii equivalent.
Thanks.
PaulS
Quote
It reads from the serial stream until a non-digit character arrives, or until a time limit is exceeded, and converts the data that it read to an int. It does not "check for comma separated data".
Quote
Guess what. That's what parseInt() does, only it's smart enough to know that the value it retrieves is really a char, not an int.
seguinc
Very cool PaulS.
Using Serial.parseInt() is good, but I need to keep in mind that the comma is not what is actually causing the command to parse: anything not a number will suffice.
What about the response from MarT?  Would you weigh in on why my sketch stops after the 9th line?
PaulS
Code: [Select]
void loop(){
    counter++;
      counter = 0;
You have a number of naming issues. inbyte is not a byte.
You use parseInt() to get an int value, that you store in an int called inbyte. You store inbyte in the array and increment the index.
Then, if there is serial data (and there likely will be because something caused parseInt() to stop reading), and if that character is a carriage return, you store the last int received in the array again.
Why is that?
Quote
You'll need to elaborate on this. Does the RX led continue to blink while you are diddling with the relays? Does the file contain data for 9 relays in consecutive order? Does changing the order matter?
Does the sending application keep sending data while you aren't paying attention, and the serial buffer simply overflows and discards all the extra data?
wildbill
I suspect that you're overflowing the serial buffer; at that baud rate, you'll be sending ~1900 characters a second. Your half second delay on the first relay activation alone will cause overflow. I assume your program gets through the data in the buffer accounting for the successful nine and then the rest has been thrown away because there was no space.
SurferTim
#10
Nov 15, 2012, 02:59 pm Last Edit: Nov 15, 2012, 03:19 pm by SurferTim Reason: 1
Is this text CSV? I would think so. What happens after #9?
1
2
3
4
5
6
7
8
9
10
How many characters is that last number?
Just a thought...
edit: I did this with network settings for the w5100 using a microSD card file in this post:
http://arduino.cc/forum/index.php/topic,128763.msg976118.html#msg976118
I read the input into a buffer until the buffer size is reached or a cr/lf is encountered. Then it uses sscanf to retrieve the values.
seguinc
In response to PaulS:
1. Good point on the naming convention.
2. Do I really need to use an array to store the three pieces of data I need to activate the relays?  Maybe not, I will rewrite the code to use variables called: relay, t_on, t_off and I will retest.
3. I will perform tests when I get back to the lab and provide feedback on the comms questions
In response to wildbill:
I will slow down the baud rate and see if this helps.  On that note; what is the method to prevent such an overflow without having to play with baud rate?  The issue may be more prominent when the project gets used in the field: I will be using 1-wire comms to transmit the CSV to the Mega; which will activate the relays.  The length of the 2 wires used to communicate may vary and I don't want to have to adjust the baud rate to prevent overflow every time something changes on the wiring.
Thank you all for weighing in.  More data to come after spending more time in the lab.
wildbill
Slowing down the baud rate won't get you much - your delays are long enough that you'll suffer the same issue. You can test it using the IDE or other terminal program and type the relay commands by hand. If that's the problem, you should be able to go way beyond nine. Don't just cut & paste the dat & send it all though.
PaulS
Quote
Only is you slow it down so far that the delay()s are shorter than the time needed to transmit a buffer full of data.
Quote
Handshaking. The receiver (the Arduino) sends a message to the sender (the PC) that says "Whew, done with that last batch of data; send me some more".
Of course, it doesn't have to be quite that verbose...
Quote
From? You'll need at least two (ground). A third (to allow two way communication) would be even better.
Quote
I don't think you have accurate enough equipment to measure the transmission time of serial data down a short wire vs. a long wire.
Wire length has virtually nothing to do with your issue.
seguinc
Hey Paul,
You'll most likely get to see more questions on the 1-wire comms stuff; that's the next phase of this project.  I will be going from testing the code PC-to-Arduino, then going Arduino (Master Control Module)-to-Arduino (Field Module).  The 1-Wire comms will be Dallas 1-wire.  The protocol performs bi-directional comms using 1 wire plus ground.
Stay tuned...
