Hi.
I want to convert the code (below) from Processing into Arduino but I am getting errors with the syntax, basically what I want to do is to get a vibration motor to start, reach maximum speed and slow down again in the shape of a curve. I have it working in processing (using the Arduino Lib) but I would like to have it working also in the Arduino IDE as I want to disconnect the arduino from the computer...any help will be appreciated ...thanks in advance...
int xspacing = 32; // How far apart should each horizontal location be spaced
int w; // Width of entire wave
float theta = 0.0; // Start angle at 0
float dx; // Value for incrementing X, a function of period and xspacing
float[] yvalues; // Using an array to store height values for the wave
w = 320;
dx = 0.40212387;
yvalues = new float[w/xspacing];
background(0);
Generatewave();
void Generatewave() {
// Increment theta (try different values for 'angular velocity' here
theta += 0.002;
// For every x value, calculate a y value with sine function
float x = theta;
for (int i = 0; i < yvalues.length; i++) {
yvalues[i] = sin(x)*10.0;
println(yvalues[i]);
x+=dx;
