Author Topic: Convert Processing code to Arduino???  (Read 252 times)
Hi.
I want to convert the code (below) from Processing into Arduino but I am getting errors with the syntax, basically what I want to do is to get a vibration motor to start, reach maximum speed and slow down again in the shape of a curve. I have it working in processing (using the Arduino Lib) but I would like to have it working also in the Arduino IDE as I want to disconnect the arduino from the computer...any help will be appreciated ...thanks in advance...
int xspacing = 32;   // How far apart should each horizontal location be spaced
int w;              // Width of entire wave
float theta = 0.0;  // Start angle at 0
float dx;  // Value for incrementing X, a function of period and xspacing
float[] yvalues;  // Using an array to store height values for the wave
  w = 320;
  dx = 0.40212387;
  yvalues = new float[w/xspacing];
  background(0);
  Generatewave();
void Generatewave() {
  // Increment theta (try different values for 'angular velocity' here
  theta += 0.002;
  // For every x value, calculate a y value with sine function
  float x = theta;
  for (int i = 0; i < yvalues.length; i++) {
    yvalues[i] = sin(x)*10.0;
     println(yvalues[i]);
    x+=dx;
UK
Online Online
If instead you say "I want to convert the code (below) from Processing into C/C++", the whole thing becomes much easier.
e.g. not
float[] yvalues;
but
float yvalues [someConstantSize];
Seattle, WA USA
Online Online
Seattle, WA USA
Share them, you greedy pig!  smiley
  background(0);
Your Arduino has something to paint the background color on?
Where are you trying to print to? The Serial Monitor? That requires sending data to the serial port, using the Serial instance.
@AWOL I made that change but when I verify the code below I am now getting the following error: incompatible types in assignment of 'float*' to 'float [10]'
**@PaulS Sorry,I was not being greedy:) and well spotted, I did leave some remnants of Java behind:)...
//float[] yvalues;  // Using an array to store height values for the wave
float yvalues [10];
  w = 320;
  dx = 0.40212387;
  yvalues = new float[10];
  Generatewave();
  theta += 0.002;
  float x = theta;
    Serial.println(yvalues[i]);
    x+=dx;
UK
Online Online
If you already declared a size for the array, you don't need/want "new", so delete this line
