Topic: Détect if a led is HIGH (Read 822 times) previous topic - next topic
raphael753
Hello !!
I tried to detect when a light is On and write on the serial port, but I don't find how.
Maybe someone can help me ? I just begin
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int derniere = 0;
int led = 13;
// the setup routine runs once when you press reset:
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
  digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);               // wait for a second
  digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
    if ( derniere == HIGH){
    Serial.print("The Lamp is ON ");
    Serial.println("The Lamp is ON ");
AWOL
"derniere" is initialised to be zero, and because you never write to it, that is how it will stay.
Have you tried
derniere = digitalRead (led);?
(of course, because you are the one doing the writing of "led", you should always know whether it is on or off)
guix
Salut, sans utiliser de delay tu peux faire comme ça:
unsigned long old_millis;
bool light_state;
  if ( millis() - old_millis >= 1000 )
    light_state = !light_state;
    digitalWrite( led, light_state );
    Serial.println( light_state ? "The Lamp is ON" : "The Lamp is OFF" );
    old_millis = millis();
Dans ton code, même si tu assigne une valeur HIGH à "derniere", puis une valeur LOW une seconde plus tard, alors ton "if (derniere == HIGH)" ne sera jamais true, puisque le code est séquentiel :)
