Loading...
Pages: [1]   Go Down
Author Topic: VNH5019 Motor Driver - Arduino Mega 2560 - Help needed  (Read 671 times)
Offline Offline
Newbie
View Profile
I am having problems regarding the connection between the Arduino Mega 2560 and the Motor Driver VNH5019. I am trying to connect the Motor Driver to Timer 3 (that is pins 3&5 on the Arduino Mega),in order to use the 16-bit timer instead of the 8-bit timer which is connected to pins 9&10 which is the default connection used. I used these threads http://arduino.cc/forum/index.php?topic=77168.0 & http://forum.pololu.com/viewtopic.php?f=15&t=5806&p=27874&hilit=vnh5019#p27874 but have not been able to get both motors working.
I was previously using an Uno with the Motor Driver and did not have any problems since the 16-bit timer is connected to pins 9&10 on the Uno thus able to get the required PWM frequency (20kHz).
The motors I am using are: http://www.pololu.com/catalog/product/1103.
My set up is:
2 motors connected to the Mega via the Motor Driver powered by a 12V laptop charger which does not seem to have any problems.The connections I have are:
Digital 13      M1INA            Motor 1 direction input A
Digital 4       M1INB             Motor 1 direction input B
Digital 6       M1EN/DIAG      Motor 1 enable input/fault output
Digital 7       M2INA             Motor 2 direction input A
Digital 8       M2INB             Motor 2 direction input B
Digital 3       M1PWM           Motor 1 speed input
Digital 5       M2PWM           Motor 2 speed input
Digital 12     M2EN/DIAG      Motor 2 enable input/fault output
Analog 0       M1CS              Motor 1 current sense output
Analog 1       M2CS              Motor 2 current sense output
The header file is:
Code:
#ifndef DualVNH5019MotorShield_h
#define DualVNH5019MotorShield_h
#include <Arduino.h>
class DualVNH5019MotorShield
  public:
    // CONSTRUCTORS
    DualVNH5019MotorShield(); // Default pin selection
    DualVNH5019MotorShield(unsigned char INA1, unsigned char INB1, unsigned char EN1DIAG1, unsigned char CS1,
                           unsigned char INA2, unsigned char INB2, unsigned char EN2DIAG2, unsigned char CS2); // User-defined pin selection.
    // PUBLIC METHODS
    void init(); // Initialize TIMER 1 (or timer 3 for mega) set the PWM to 20kHZ
    void setM1Speed(int speed); // Set speed
    void setM2Speed(int speed); // Set speed
    void setSpeeds(int m1Speed, int m2Speed); // Set speed for both M1 and M2
    void setM1Brake(int brake); // Brake M1
    void setM2Brake(int brake); // Brake M2
    void setBrakes(int m1Brake, int m2Brake); // Brake both M1 and M2
    unsigned int getM1CurrentMilliamps(); // Get current reading
    unsigned int getM2CurrentMilliamps(); // Get current reading
    unsigned char getM1Fault(); // Get fault reading
    unsigned char getM2Fault(); // Get fault reading
  private:
    unsigned char _INA1;
    unsigned char _INB1;
  /*#if defined(__AVR_ATmega168__)|| defined(__AVR_ATmega328P__)
    static const unsigned char _PWM1 = 9;
    static const unsigned char _PWM2 = 10;
  #endif*/
  #if defined(__AVR_ATmega128__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
    static const unsigned char _PWM1 = 3;
    static const unsigned char _PWM2 = 5;
  #endif
    unsigned char _EN1DIAG1;
    unsigned char _CS1;
    unsigned char _INA2;
    unsigned char _INB2;
    unsigned char _EN2DIAG2;
    unsigned char _CS2;
#endif
while the .cpp file is:
Code:
#include "DualVNH5019MotorShield.h"
// Constructors
DualVNH5019MotorShield::DualVNH5019MotorShield()
  //Pin map
  _INA1 = 13;
  _INB1 = 4;
  _EN1DIAG1 = 6;
  _CS1 = A0;
  _INA2 = 7;
  _INB2 = 8;
  _EN2DIAG2 = 12;
  _CS2 = A1;
DualVNH5019MotorShield::DualVNH5019MotorShield(unsigned char INA1, unsigned char INB1, unsigned char EN1DIAG1, unsigned char CS1,
  //Pin map
  //PWM1 and PWM2 cannot be remapped because the library assumes PWM is on timer1
  _INA1 = INA1;
  _INB1 = INB1;
  _EN1DIAG1 = EN1DIAG1;
  _CS1 = CS1;
  _INA2 = INA2;
  _INB2 = INB2;
  _EN2DIAG2 = EN2DIAG2;
  _CS2 = CS2;
// Public Methods
void DualVNH5019MotorShield::init()
// Define pinMode for the pins and set the frequency for timer1.
  pinMode(_INA1,OUTPUT);
  pinMode(_INB1,OUTPUT);
  pinMode(_PWM1,OUTPUT);
  pinMode(_EN1DIAG1,INPUT);
  pinMode(_CS1,INPUT);
  pinMode(_INA2,OUTPUT);
  pinMode(_INB2,OUTPUT);
  pinMode(_PWM2,OUTPUT);
  pinMode(_EN2DIAG2,INPUT);
  pinMode(_CS2,INPUT);
 // #if defined(__AVR_ATmega168__)|| defined(__AVR_ATmega328P__)
  // Timer 1 configuration
  // prescaler: clockI/O / 1
  // outputs enabled
  // phase-correct PWM
  // top of 400
  // PWM frequency calculation
  // 16MHz / 1 (prescaler) / 2 (phase-correct) / 400 (top) = 20kHz
 // TCCR1A = 0b10100000;
 // TCCR1B = 0b00010001;
 // ICR1 = 400;
 // #endif
  // Mega board specific stuff here - assumes assigning timer3, using pins 3 &5
  TCCR3A = 0b10100000; // Mega pin 5
  TCCR3C = 0b00010001; // Mega pin 3
  ICR3 = 400;
  #endif
// Set speed for motor 1, speed is a number betwenn -400 and 400
void DualVNH5019MotorShield::setM1Speed(int speed)
  unsigned char reverse = 0;
  if (speed < 0)
    speed = -speed;  // Make speed a positive quantity
    reverse = 1;  // Preserve the direction
  if (speed > 400)  // Max PWM dutycycle
    speed = 400;
//  OCR1A = speed;
  OCR3A = speed;
//  #else
//  analogWrite(_PWM1,speed * 51 / 80);
  #endif
  if (reverse)
    digitalWrite(_INA1,LOW);
    digitalWrite(_INB1,HIGH);
    digitalWrite(_INA1,HIGH);
    digitalWrite(_INB1,LOW);
// Same as motor 1
void DualVNH5019MotorShield::setM2Speed(int speed)
  if (speed < 0)
    speed = -speed;  // make speed a positive quantity
    reverse = 1;  // preserve the direction
    speed = 400;
 // OCR1B = speed;
  OCR3C = speed;
 // #else
 // analogWrite(_PWM2,speed * 51 / 80);
  #endif
  if (reverse)
    digitalWrite(_INA2,LOW);
    digitalWrite(_INB2,HIGH);
    digitalWrite(_INA2,HIGH);
    digitalWrite(_INB2,LOW);
// Set speed for motor 1 and 2
void DualVNH5019MotorShield::setSpeeds(int m1Speed, int m2Speed)
  setM1Speed(m1Speed);
  setM2Speed(m2Speed);
// Brake motor 1, brake is a number between 0 and 400
void DualVNH5019MotorShield::setM1Brake(int brake)
  // normalize brake
  if (brake < 0)
    brake = -brake;
  if (brake > 400)  // Max brake
    brake = 400;
  digitalWrite(_INA1, LOW);
  digitalWrite(_INB1, LOW);
 // OCR1A = brake;
  OCR3A = brake;
 // #else
 // analogWrite(_PWM1,brake * 51 / 80);
  #endif
// Same as motor 1
void DualVNH5019MotorShield::setM2Brake(int brake)
  // normalize brake
  if (brake < 0)
    brake = -brake;
  if (brake > 400)
    brake = 400;
  digitalWrite(_INA2, LOW);
  digitalWrite(_INB2, LOW);
 // OCR1B = brake;
  OCR3C = brake;
 // #else
 // analogWrite(_PWM2,brake * 51 / 80);
  #endif
// Brake motor 1 and 2, brake is a number between 0 and 400
void DualVNH5019MotorShield::setBrakes(int m1Brake, int m2Brake)
  setM1Brake(m1Brake);
  setM2Brake(m2Brake);
// Return motor 1 current value in milliamps.
unsigned int DualVNH5019MotorShield::getM1CurrentMilliamps()
  // 5V / 1024 ADC counts / 144 mV per A = 34 mA per count
  return analogRead(_CS1) * 34;
// Return motor 2 current value in milliamps.
unsigned int DualVNH5019MotorShield::getM2CurrentMilliamps()
  return analogRead(_CS2) * 34;
// Return error status for motor 1
unsigned char DualVNH5019MotorShield::getM1Fault()
  return !digitalRead(_EN1DIAG1);
// Return error status for motor 2
unsigned char DualVNH5019MotorShield::getM2Fault()
  return !digitalRead(_EN2DIAG2);
Strangely enough in the .cpp file changing:
Code:
 ICR3 = 400;
to
Code:
TCCR3B = 0b00010001;
ICR3 = 400;
gets one motor working but from the research I did TCCR3B should be connected to pin 2 which is not being used.
Many thanks,
MAAhelp
Logged
Seattle, WA USA
Online Online
Brattain Member
Seattle, WA USA
View Profile
Quote
Why?
Logged
Offline Offline
Newbie
View Profile
To get a PWM frequency of 20kHz as opposed to the maximum of an 8-bit timer. Pololu have developed a library specific to the Arduino Mega for all those interested.
http://forum.pololu.com/viewtopic.php?f=15&t=6139
Logged
Pages: [1]   Go Up
Print
Jump to:
