Topic: Convert Processing code to Arduino??? (Read 2014 times) previous topic - next topic
bonobono
Hi.
I want to convert the code (below) from Processing into Arduino but I am getting errors with the syntax, basically what I want to do is to get a vibration motor to start, reach maximum speed and slow down again in the shape of a curve. I have it working in processing (using the Arduino Lib) but I would like to have it working also in the Arduino IDE as I want to disconnect the arduino from the computer...any help will be appreciated ...thanks in advance...
Code: [Select]
int xspacing = 32;   // How far apart should each horizontal location be spaced
int w;              // Width of entire wave
float theta = 0.0;  // Start angle at 0
float dx;  // Value for incrementing X, a function of period and xspacing
float[] yvalues;  // Using an array to store height values for the wave
  w = 320;
  dx = 0.40212387;
  yvalues = new float[w/xspacing];
  background(0);
  Generatewave();
void Generatewave() {
  // Increment theta (try different values for 'angular velocity' here
  theta += 0.002;
  // For every x value, calculate a y value with sine function
  float x = theta;
  for (int i = 0; i < yvalues.length; i++) {
    yvalues[i] = sin(x)*10.0;
     println(yvalues[i]);
    x+=dx;
AWOL
Quote
If instead you say "I want to convert the code (below) from Processing into C/C++", the whole thing becomes much easier.
e.g. not
Code: [Select]
float[] yvalues;
but
Code: [Select]
float yvalues [someConstantSize];
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
PaulS
Quote
Share them, you greedy pig!  :)
Code: [Select]
  background(0);
Your Arduino has something to paint the background color on?
Code: [Select]
Where are you trying to print to? The Serial Monitor? That requires sending data to the serial port, using the Serial instance.
bonobono
@AWOL I made that change but when I verify the code below I am now getting the following error: incompatible types in assignment of 'float*' to 'float [10]'
**@PaulS Sorry,I was not being greedy:) and well spotted, I did leave some remnants of Java behind:)...
Code: [Select]
//float[] yvalues;  // Using an array to store height values for the wave
float yvalues [10];
  w = 320;
  dx = 0.40212387;
  yvalues = new float[10];
  Generatewave();
  theta += 0.002;
  float x = theta;
    Serial.println(yvalues[i]);
    x+=dx;
AWOL
Code: [Select]
If you already declared a size for the array, you don't need/want "new", so delete this line
