Loading...
Pages: [1]   Go Down
Author Topic: Floating pointing incrementing, not working  (Read 419 times)
Offline Offline
Newbie
View Profile
I'm currently working on a flow meter, which measures in GPH.  I'm trying to set it up so it displays the current gph usage and two resettable total gallon used counters.  The sketch counts the number of pulses from the sensor every second or so.  I then take the flow measurement( which is pulses * gals per pulse) and add it to totalgallonsA.
TotalgallonsA += flowgal;   // both are float
The problem I'm having is totalgallonsA instead of increasing always goes back to zero?
I can post the complete code if needed, I have it on my other computer
I'm very new to programming, and don't know where to begin??
Matt
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Can you print both variables before and after the add please? (Serial.print).
Possibly one or the other is NaN (not a number).
Preferably post all your code inside code tags.
Logged
UK
Offline Offline
Tesla Member
View Profile
Floating point doesn't seem like a good bet for that sort of thing - you're going to be getting unpredictable rounding errors that could get quite large. Better IMO to define the resolution you're going to measure at (tenths of gallons, hundredths, thousandths etc) and store your counters as fixed point integer numbers.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
I agree. A flow meter that generating pulses per unit of material flowed is best dealt with using integer math. it's rather straight forward counting of pulses in a fixed time interval and of course updating the total flow value, I see no advantages to using floating point math and several disadvantages.
Lefty
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
probably you need to define the total counter as a global variable.
to be sure please post your code.
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
God Member
View Profile
This should work:
Code:
TotalgallonsA = TotalgallonsA + flowgal;   // both are float
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
Code:
And how is that different to the code the IP posted?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Poole, Dorset, UK
Offline Offline
God Member
View Profile
Can't tell unless you post your whole code.
Mark
Logged
Offline Offline
Newbie
View Profile
Here is my code so far.  Im pretty new to the language, any help would be great
Matt
Code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12,11,10,9,8,7);
byte sensorInterrupt = 0;  // 0 = pin 2; 1 = pin 3
byte sensorPin       = 2;
// The hall-effect flow sensor outputs aproximatly one pulse per .00038L
volatile byte pulseCount;
float flowRate;
unsigned int flowGallons;
float totalGallonsA;
unsigned int totalGallonsB;
int pulseCounttot;
unsigned long oldTime;
 lcd.begin(16, 2);
 lcd.setCursor(0, 0);
 lcd.print("BRADSHAW ");
 lcd.setCursor(0, 1);
 lcd.print("INDUSTRIES ");
delay(3000);
 lcd.clear();
 pinMode(sensorPin, INPUT);
 digitalWrite(sensorPin, HIGH);
 pulseCount        = 0;
 flowRate          = 0.0;
 flowGallons       = 0;
 totalGallonsA     = 0;
 totalGallonsB     = 0;
 oldTime           = 0;
 pulseCounttot     = 0;
 // The Hall-effect sensor is connected to pin 2 which uses interrupt 0.
 // Configured to trigger on a FALLING state change (transition from HIGH
 // state to LOW state)
 attachInterrupt(sensorInterrupt, pulseCounter, FALLING);
* Main program loop
 if((millis() - oldTime) >= 1000)    // Only process counters once per second
   // Disable the interrupt while calculating flow rate and sending the value to
   // the host
   detachInterrupt(sensorInterrupt);
   // Because this loop may not complete in exactly 1 second intervals we calculate
   // the number of milliseconds that have passed since the last execution and use
   // that to scale the output.
       unsigned long time = millis() - oldTime;
      float time_in_sec = time / 1000;
      float impuls = pulseCount * time_in_sec; //scale pulse number
     float flowG = impuls * .00010;  // amount of gals
      float GPH = flowG * 120 ;  // convert to gph
      totalGallonsA =+ flowG ;
   oldTime = millis();
   lcd.setCursor(0,0);
   lcd.print(GPH);
   lcd.setCursor(6,0);
   lcd.print("GPH");   // Print the integer part of the variable
   lcd.setCursor(0,1);
   lcd.print(totalGallonsA,4);
   // Reset the pulse counter so we can start incrementing again
   pulseCount = 0;
   // Enable the interrupt again now that we've finished sending output
* Invoked by interrupt0 once per rotation of the hall-effect sensor. Interrupt
* handlers should be kept as small as possible so they return quickly.
void pulseCounter()
 // Increment the pulse counter
 pulseCount++;
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Quote
Code:
That isn't the same as:
Code:
    totalGallonsA += flowG ;
Your version merely sets totalGallonsA to the value in flowG. It doesn't add.
Quote
Code:
    // the host
Better is:
Code:
noInterrupts();
Quote
Code:
Better is:
Code:
interrupts ();
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
Code:
noInterrupts();
Why is it better to disable all of the interrupts instead of just the one?
Logged
www.cmiyc.com - A guide to being an Enginerd
North Queensland, Australia
Offline Offline
Edison Member
View Profile
WWW
Disabling global interrupts is a single bit manipulation, attach/detach interrupt are not as efficient.
The operation could be done before detachInterrupt even returns.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
I agree, but if you wanted finer tuning you could disable that particular interrupt, eg.
Code:
EIMSK &= ~_BV (INT0);
That is also a single-bit operation.
And turn it on later with:
Code:
EIMSK |= _BV (INT0);
In this case I don't think having interrupts off for a moment will be a big deal.
Logged
Pages: [1]   Go Up
Print
Jump to:
