Loading...
Pages: [1]   Go Down
Author Topic: Delimiters of two incoming series 1 Xbees  (Read 135 times)
Offline Offline
Full Member
View Profile
WWW
I have a total of 3 series 1 xbees communicating in transparent mode through serial. Two of them are sending incoming reads and one of them is receiving.  I wanted to separate the incoming values with delimiters to know what value is coming from where.I've gotten up to this point with success.  Problem now is I dont know how to label this incoming values through the receiving Arduino. I simply just want to add something like, "Serial.print("this is the first sensor = "); and so fourth for second sensor. I am just not sure where it is appropriate within the code. here is the code below:
Emitter : (code is the same for both )
Code:
// Example of sending numbers by Serial
// Author: Nick Gammon
// Date: 31 March 2012
const char startOfNumberDelimiter = '<';
const char endOfNumberDelimiter   = '>';
const int rssi_pin = 9; //RSSI Pin of the XBee Module
 int rssiDur;
void setup ()
  //srand (42);
  Serial.begin (38400);
  } // end of setup
void loop ()
     rssiDur = pulseIn(rssi_pin, LOW, 200); //sending this val
  for (int i = 0; i < 10; i++)
    Serial.print (startOfNumberDelimiter);
    Serial.print (rssiDur);    // send the number
    Serial.print (endOfNumberDelimiter);
    Serial.println ();
    }  // end of for
  delay (300);
  }  // end of loop
....and the receiver
Code:
// Example of receiving numbers by Serial
void setup ()
  //Serial.println ("Starting ...");
  } // end of setup
void processNumber (const long n)
    Serial.print("bike 2 = ");
  Serial.println (n);
  }  // end of processNumber
void processInput ()
  static long receivedNumber = 0;
  static boolean negative = false;
  byte c = Serial.read ();
  switch (c)
    case endOfNumberDelimiter:
      if (negative)
        processNumber (- receivedNumber);
        processNumber (receivedNumber);
    // fall through to start a new number
    case startOfNumberDelimiter:
      receivedNumber = 0;
      negative = false;
    case '0' ... '9':
      receivedNumber *= 10;
      receivedNumber += c - '0';
    case '-':
      negative = true;
    } // end of switch
  }  // end of processInput
void loop ()
  if (Serial.available ())
    processInput ();
  // do other stuff here
  } // end of loop
Logged
Pages: [1]   Go Up
Print
Jump to:
