Topic: Mega with wiznet shield (wire hack)+thingspeak+sd problem (Read 15890 times) previous topic - next topic
vespapierre
#30
Nov 21, 2012, 09:56 pm Last Edit: Nov 21, 2012, 09:59 pm by vespapierre Reason: 1
problems coming... test.txt created manually, but have errors.
Temperatures are 29 Celsius, 0 Celsius, 0 Celsius,
connecting...failed
Fail Open fail
Log failed
1
SurferTim
#31
Nov 21, 2012, 10:05 pm Last Edit: Nov 21, 2012, 10:11 pm by SurferTim Reason: 1
Post your current loop() function. That may help me troubleshoot it.
edit: Power it down for a few seconds. Try it again.
vespapierre
#32
Nov 21, 2012, 10:17 pm Last Edit: Nov 21, 2012, 10:26 pm by vespapierre Reason: 1
powerdown not helped.
Code: [Select]
 if(loopCount < 30)
   // if loopCount is less than 30, just delay a second
   // every thirty seconds this runs
   loopCount = 0;
   // Modify next line to load different page
   // or pass values to server
//get temperatures
Serial.print("Getting temperatures...\n\r");
   sensors.requestTemperatures();            //issue global request for each temp sensor on network to return a temp
      if(sensors.getAddress(tempDeviceAddress, 0))
         temp0=(sensors.getTempC(tempDeviceAddress)); //read temp from sensor 0
      if(sensors.getAddress(tempDeviceAddress, 1))
         temp1=(sensors.getTempC(tempDeviceAddress)); //read temp from sensor 1
      if(sensors.getAddress(tempDeviceAddress, 2))
        temp2=(sensors.getTempC(tempDeviceAddress));  //read temp from sensor 2
   Serial.print("Temperatures are ");
   Serial.print(temp0);
   Serial.print(" Celsius, ");
   Serial.print(temp1);
   Serial.print(temp2);
   Serial.print("\n\r");
  sprintf(pageAdd,"/update?key=XXXXXXXXXXXXXXXXXXXX&field1=%u&field2=%u&field3=%u",temp0,temp1,temp2);
// sprintf(pageAdd,"/",totalCount);
   // sprintf(pageAdd,"/arduino.php?test=%u",totalCount);
   if(!getPage(server,pageAdd)) Serial.print("Fail ");
   else Serial.print("Pass ");
   if(!logFile(temp0,temp1,temp2)) Serial.println("Log failed");
   else Serial.println("Log ok");
   totalCount++;
   Serial.println(totalCount,DEC);
 loopCount++;
int logFile(int temp0, int temp1, int temp2) {
 File fh = SD.open("test.txt",FILE_WRITE);
 if(!fh) {
   Serial.println("Open fail");
   return 0;
 // Use the same character array here to send stuff to the file.
 // pageAdd array is global
 sprintf(pageAdd,"Field1=%u Field2=%u Field3=%u",temp0,temp1,temp2);
 fh.println(pageAdd);
 fh.close();
 return 1;
byte getPage(IPAddress ipBuf,char *page)
 int inChar;
 char outBuf[128];
 Serial.print("connecting...");
 if(client.connect(ipBuf,80))
   Serial.println("connected");
   sprintf(outBuf,"GET %s HTTP/1.0\r\n\r\n",page);
   client.write(outBuf);
   Serial.println("failed");
   return 0;
 // connectLoop controls the hardware fail timeout
 int connectLoop = 0;
 while(client.connected())
   while(client.available())
     inChar = client.read();
     Serial.write(inChar);
     // set connectLoop to zero if a packet arrives
     connectLoop = 0;
   connectLoop++;
   // if more than 10000 milliseconds since the last packet
   if(connectLoop > 10000)
     // then close the connection from this end.
     Serial.println("Timeout");
     client.stop();
   // this is a delay for the connectLoop timing
   delay(1);
 Serial.println("disconnecting.");
 // close client end
 client.stop();
 return 1;
UPDATE: strange...without the logfile modification, it is not connecting...that was working fine before...maybe thingspeak issue...
SurferTim
Back up then. Remove the call to logFile and the logFile function. Does it work then?
vespapierre
backed up... connection failed...tried to ping the server..got back answer after ping
SurferTim
The Thingspeak should not affect whether the SD writes or not. If the connection failed, and the SD write failed, something is not right. Are you certain that pageAdd array is big enough to handle all that?
vespapierre
#36
Nov 21, 2012, 10:49 pm Last Edit: Nov 21, 2012, 10:56 pm by vespapierre Reason: 1
after router restart :
Found device 1 with address: 286C81C5030000FA
Found device 2 with address: 2811E8E803000027
Temperatures are 16 Celsius, 8 Celsius, 6 Celsius,
connecting...connected
HTTP/1.1 200 OK
Server: nginx/0.8.53
Date: Wed, 21 Nov 2012 21:49:10 GMT
Content-Type: text/html; charset=utf-8
Connection: close
Vary: Accept-Encoding
Status: 200
ETag: "1ff1de774005f8da13f42943881c655f"
Cache-Control: max-age=0, private, must-revalidate
24
disconnecting.
Pass Open fail
Log failed
1
this is with the SD version
without SD it is fine.
UPDATE: in the txt I can find the values!!! but failed message appears on serial monitor
vespapierre
let's have a rest... :smiley-red:
again thanks for your help/support Tim!
I'll back to here tomorrow...(meanwhile trying to figure out, how to put date,time and ";" values to the log.it was working alone in a previous sketch what can be found in Reply #23)
If you could help me in that too I would be more than happy!:) I have learned a lot today.
vespapierre
#38
Nov 24, 2012, 10:08 am Last Edit: Nov 24, 2012, 12:13 pm by vespapierre Reason: 1
Strange that I have only found 1 line in the test.txt when the program started...I have checked this after a day...(????)
Now I tried to put to the code this one:
Code: [Select]
#include <Rtc_Pcf8563.h>
//init the real time clock
Rtc_Pcf8563 rtc;
loop()
char sdate[11] = "";
char stime[9] ="";
strcpy(stime, rtc.formatTime());
strcpy(sdate, rtc.formatDate(RTCC_DATE_ASIA));
Serial.print(stime);
Serial.print(" ");
Serial.print(sdate);
//***************log cuccos
if(!logFile(sdate,stime,temp0,temp1,temp2)) Serial.println("Log failed");
int logFile(int sdate, int stime, int temp0, int temp1, int temp2) {
 if(!fh) {
   return 0;
 sprintf(pageAdd,"Date=%u Time=%u Field1=%u Field2=%u Field3=%u",sdate,stime,temp0,temp1,temp2);
 fh.close();
 return 1;
but seems this is not a good idea...problems having converting sdate and stime... those are char and it should be int
UPDATE: the first writing attempt to log file is failing....than the second one is fine! at this moment it is running with usb cable and serial monitor. The previous test was from external supply with 12V..._(when I have found only 1 line in the log)
Tim have you got any idea?
SurferTim
#39
Nov 24, 2012, 01:29 pm Last Edit: Nov 24, 2012, 01:52 pm by SurferTim Reason: 1
That last code has problems. It is not complete. You should post all the code.
edit: This is wrong in the code you posted:
Code: [Select]
// sdate and stime are character arrays here
char stime[9] ="";
// then later you pass the character array pointer to logFile
// but logFile has sdate and stime as int type. ??
This is how logFile should look:
Code: [Select]
int logFile(char* sdate, char* stime, int temp0, int temp1, int temp2) {
  if(!fh) {
    return 0;
  sprintf(pageAdd,"Date=%s Time=%s Field1=%u Field2=%u Field3=%u",sdate,stime,temp0,temp1,temp2);
  fh.close();
  return 1;
Insure you have enough memory allocated for pageAdd. If it is still 32 characters, you are overflowing the pageAdd array.
vespapierre
Tim,
this is the full code, without the date and time...sometimes it is put empty lines to log, or stop the log, however serial sais log ok.
Code: [Select]
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
#include <OneWire.h>
#include <DallasTemperature.h>
byte mac[] = {
  0x00, 0x11, 0x22, 0x33, 0x44, 0x55 };
// change to your network settings
IPAddress ip(192,168,9,110);
IPAddress gateway(192, 168, 9, 1);
IPAddress subnet(255, 255, 255, 0);
// change to your server
IPAddress server(184,106,153,149);
// Data wire is plugged into pin 3 on the Arduino
#define ONE_WIRE_BUS 3
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
//Variables
EthernetClient client;
int totalCount = 0;
int loopCount = 0;
char pageAdd[140];
int temp0;                                   //temperature 1
int temp1;                                  //temperature 2
int temp2;                                  //temperature 3
int numberOfDevices;                          // Number of temperature devices found
DeviceAddress tempDeviceAddress;             // We'll use this variable to store a found device address
// function to print a device address
void printAddress(DeviceAddress deviceAddress)
  for (uint8_t i = 0; i < 8; i++)
    if (deviceAddress[i] < 16) Serial.print("0");
    Serial.print(deviceAddress[i], HEX);
//**********SETUP***************
  // disable SD SPI
  pinMode(8,OUTPUT);
  digitalWrite(8,HIGH);
  // Start ethernet
  Serial.println("Starting ethernet...");
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  // If using dhcp, comment out the line above
  // and uncomment the next 2 lines
   //if(!Ethernet.begin(mac)) Serial.println("failed");
   //else Serial.println("ok");
  digitalWrite(10,HIGH);
  Serial.println(Ethernet.localIP());
  //start SD
  Serial.print("Starting SD...");
  if(!SD.begin(8)) Serial.println("failed");
  else Serial.print("ok ");
  delay(2000);
  Serial.println("Ready");
  //Start sensors
  sensors.begin();
  // Grab a count of devices on the wire
  numberOfDevices = sensors.getDeviceCount();
  // locate devices on the bus
  Serial.print("Locating devices...");
  Serial.print("Found ");
  Serial.print(numberOfDevices, DEC);
  Serial.println(" devices.");
  // report parasite power requirements
  Serial.print("Parasite power is: ");
  if (sensors.isParasitePowerMode()) Serial.println("ON");
  else Serial.println("OFF");
  // Loop through each device, print out address
  for(int i=0;i<numberOfDevices; i++)
    // Search the wire for address
    if(sensors.getAddress(tempDeviceAddress, i))
      Serial.print("Found device ");
      Serial.print(i, DEC);
      Serial.print(" with address: ");
      printAddress(tempDeviceAddress);
      delay(100);
      // Get inital sensor readings to avoid 85 degrees
//****************LOOP****************
  if(loopCount < 30)
    loopCount = 0;
    //get temperatures
    sprintf(pageAdd,"/update?key=XXXXXXXXXXXXXX&field1=%u&field2=%u&field3=%u",temp0,temp1,temp2);
    totalCount++;
  loopCount++;
  if(!fh) {
    return 0;
  sprintf(pageAdd,"Field1=%u,Field2=%u,Field3=%u",temp0,temp1,temp2);
  fh.close();
  return 1;
  int inChar;
  char outBuf[128];
    return 0;
      connectLoop = 0;
    connectLoop++;
      client.stop();
    delay(1);
  // close client end
  client.stop();
  return 1;
SurferTim
You may be running out of SRAM. The SD open function requires a lot of memory. If you run out of SRAM, the open function may return success, but if you try to read or write, that is when it seems to fail. I'll take a quick guess that it does not check if the memory is available, just if it can open the file on the SD card.
vespapierre
#42
Nov 24, 2012, 02:05 pm Last Edit: Nov 24, 2012, 02:15 pm by vespapierre Reason: 1
:( what can I do in this case? Should I take out some from the code? I have just followed your advices.
edit: maybe I should not use the function to find the onewire adresses automatically? but that is good function in case of a sensor change...
SurferTim
#43
Nov 24, 2012, 02:14 pm Last Edit: Nov 24, 2012, 02:17 pm by SurferTim Reason: 1
If you are using a Mega, you should not be running out of SRAM unless something has gone wrong. It has 8K, compared to the Uno's 2K. I suspect maybe a buffer overflow is the cause.
Go back to the playground and upload that code again. Get it running. You had it running before. Change the network settings, the array size for pageAdd, and add "#include <SD.h>" at the top (edit: Change the pin for your SD card SS to the correct pin number in SD.begin). That's all!
Then add this to it:
Code: [Select]
 if(!fh) {
   return 0;
 fh.close();
 return 1;
Don't call the the logFile routine in loop(). See if everything runs ok before you do.
Upload the code, then power down the Arduino for a few seconds, then power it up and open the serial monitor.
vespapierre
ok. with this as you said running all ok:
Code: [Select]
#include <SD.h>
#include <SPI.h>
// this must be unique
byte mac[] = {  0x00, 0x11, 0x22, 0x33, 0x44, 0x55 };
IPAddress ip(192,168,9,108);
int totalCount = 0;
int loopCount = 0;
char pageAdd[200];
//char pageAdd[140];
 // disable SD SPI
 pinMode(8,OUTPUT);
 // Start ethernet
 // if(!Ethernet.begin(mac)) Serial.println("failed");
 // else Serial.println("ok");
//start SD
 delay(2000);
 if(loopCount < 30)
   loopCount = 0;
  sprintf(pageAdd,"/update?key=XXXXXXXXXXXXXXX&field1=200&field2=200&field3=200");
   totalCount++;
 loopCount++;
 int inChar;
 char outBuf[128];
   return 0;
     connectLoop = 0;
   connectLoop++;
     client.stop();
   delay(1);
 // close client end
 client.stop();
 return 1;
 if(!fh) {
   return 0;
 fh.close();
 return 1;
here there was mannually added temp values as 200. no temp reading from the sensors. and no writing to the logfile
