Hungary
« Reply #15 on: November 21, 2012, 10:25:00 am » |
seems that I'm newbie... I have checked the example method of post... http://community.thingspeak.com/documentation/api/How can I put that to your code Tim? is this the sending to the server?: <code> sprintf(pageAdd,"/",totalCount); // sprintf(pageAdd,"/arduino.php?test=%u",totalCount); if(!getPage(server,pageAdd)) Serial.print("Fail "); else Serial.print("Pass "); </code> Should I use strcpy to put the lines to pageAdd and then sprintf(pageAdd); ? Sorry for the question...
« Last Edit: November 21, 2012, 10:33:40 am by vespapierre »
Miramar Beach, Florida
« Reply #16 on: November 21, 2012, 10:53:21 am » |
The API says it will take GET or POST requests, so this should work. In loop() change the sprintf line. sprintf(pageAdd,"/update?key=MyKey&test=%u",totalCount); Change MyKey to your key. Change "test" to "Field", "Channel", etc. Change totalCount to the parameter you want to pass. Insure there are no illegal characters in the parameters, like spaces.
Hungary
« Reply #17 on: November 21, 2012, 02:04:47 pm » |
Tim,
seems your code is working. Exactly did what you wrote. Serial monitor said:
Starting ethernet... 192.168.9.110 Starting SD...ok Ready connecting...connected HTTP/1.1 200 OK Server: nginx/0.8.53 Date: Wed, 21 Nov 2012 19:01:40 GMT Content-Type: text/html; charset=utf-8 Connection: close Vary: Accept-Encoding Status: 200 ETag: "b4fd1d2cb085390fbbadae65e07876a7" Cache-Control: max-age=0, private, must-revalidate
2809 disconnecting. Pass 1
I have just add manually temp values.
« Reply #18 on: November 21, 2012, 02:23:33 pm » |
Of all the things I enjoy seeing in the serial monitor, this is my favorite: Pass 1
Hungary
« Reply #19 on: November 21, 2012, 02:29:03 pm » |
I have defined the temp0, temp1 ... values as "int". How can put them to sprintf(...)? Manual send was : &field1=200&field2=200 .... instead of 200 i have to put the temp0, temp1 ....
« Reply #20 on: November 21, 2012, 02:31:43 pm » |
That sounds like this: sprintf(pageAdd,"/update?key=MyKey&field1=%u&field2=%u",temp0,temp1); edit: Insure the character array pageAdd has enough storage for the string.
« Last Edit: November 21, 2012, 02:34:09 pm by SurferTim »
Hungary
« Reply #21 on: November 21, 2012, 02:40:29 pm » |
I'm going to be happy  current code is here: SKETCH answer is: Starting ethernet... 192.168.9.110 Starting SD...ok Ready Locating devices...Found 1 devices. Parasite power is: OFF Found device 0 with address: 1092942902080056 Getting temperatures... Temperatures are 85 Celsius, 0 Celsius, 0 Celsius, connecting...connected HTTP/1.1 200 OK Server: nginx/0.8.53 Date: Wed, 21 Nov 2012 19:36:14 GMT Content-Type: text/html; charset=utf-8 Connection: close Vary: Accept-Encoding Status: 200 ETag: "d53697441ef12a45422f6660202f9840" Cache-Control: max-age=0, private, must-revalidate 2818 disconnecting. Pass 1 85 degrees is maybe some kind of delay I guess... we are almost at the start of writing to SD  edit: I have modified the char array to 140. As API documentation said that is the maximum. Can I modify later the temp as float?
« Last Edit: November 21, 2012, 02:43:55 pm by vespapierre »
« Reply #22 on: November 21, 2012, 02:57:16 pm » |
Watch out for type float. If you try to use that type in sprintf, the result will be "?" where you expected the value to be. You need to convert that float to a string first.
Is the value returned from the temperature sensor a float type? Or integer?
edit: Some devices return the temperature in fractions of a degree, like half or quarter of a degree. 85 may be in quarter degrees. That would be 21.25 degrees Celsius.
« Last Edit: November 21, 2012, 03:08:00 pm by SurferTim »
Hungary
« Reply #23 on: November 21, 2012, 03:07:19 pm » |
I have tried that, I will stay at integer ( i gues return value can be a float)...I hope it will show negative values. Facing to SD writing...I have put the SD code what you wrote to the setup(). Can you help how should I go ahaed? it was my original SD code: #include <Wire.h> #include <OneWire.h> #include <Rtc_Pcf8563.h> #include <SD.h>
//init the real time clock Rtc_Pcf8563 rtc;
// Global variables const int period = 30000; const int chipSelect = 8;
//**************************SETUP***************************** void setup() { String message=""; Serial.begin(9600); Wire.begin(); pinMode(8, OUTPUT); if (!SD.begin(chipSelect)) { Serial.println("Card failed"); return; } Serial.println("Card init"); File logFile = SD.open("errorlog.txt", FILE_WRITE); if (logFile) { message = String(rtc.formatDate(RTCC_DATE_ASIA)) + " " + String(rtc.formatTime()); logFile.println("Progstart: " + message); logFile.close(); Serial.println("Progrstart: " + message); } // if the file isn't open, pop up an error: else { Serial.println("cannot open errorlog.txt"); } }
//********************LOOP********************************** void loop() { delay(period); // make a string for assembling the data to log: String dataString = ""; String sDate = ""; String sTime =""; //------------------------------------------------------------- sTime=rtc.formatTime(); //read formatted time from i2C RTC sDate=rtc.formatDate(RTCC_DATE_ASIA); //read formatted date from 12C RTC
Serial.print(sTime); Serial.print(" "); Serial.print(sDate); Serial.println(); dataString += String(sDate + ";" + sTime + ";"); delay(100); File dataFile = SD.open("datalog.txt", FILE_WRITE); if (dataFile) { dataFile.println(dataString); dataFile.close(); // print to the serial port too: Serial.println(dataString); } // if the file isn't open, pop up an error: else { Serial.println("cannot open datalog.txt"); } } // END LOOP
or should I use your ftp code?? Seems I will need your further help
« Last Edit: November 21, 2012, 03:11:19 pm by vespapierre »
« Reply #24 on: November 21, 2012, 03:09:54 pm » |
Did you see my edit to my last post? The value returned may be in 1/4 degrees Celsius. 85 / 4 = 21.25 degrees. Is that about right?
Hungary
« Reply #25 on: November 21, 2012, 03:14:27 pm » |
oh yes...I will double check the DS18b20...now I'm excited about the SD  Did you see my edit to my last post? The value returned may be in 1/4 degrees Celsius. 85 / 4 = 21.25 degrees. Is that about right?
« Reply #27 on: November 21, 2012, 03:21:04 pm » |
And this seems to be the final piece of the puzzle for you. Thanks, wildbill!
Hungary
« Reply #28 on: November 21, 2012, 03:22:58 pm » |
Thanks wildbill, I will put initial sensor readings to setup.
Tim,
can you help me out of this SD code? What and where should I put? Should I stay at my code or better to use your ftp like?
edit: after initial reading of sensors in setup() 85 degrees at the start disappeared, thanks again!
« Last Edit: November 21, 2012, 03:29:42 pm by vespapierre »
« Reply #29 on: November 21, 2012, 03:38:01 pm » |
Since you have the values in the loop() function, I would put the SD routine immediately after the getPage() call. Like this: if(!logFile(temp0,temp1)) Serial.println("Log failed"); else Serial.println("Log ok");
Here is logFile: int logFile(int temp0, int temp1) { File fh = SD.open("test.txt",FILE_WRITE);
if(!fh) { Serial.println("Open fail"); return 0; }
// Use the same character array here to send stuff to the file. // pageAdd array is global sprintf(pageAdd,"Field1=%u Field2=%u",temp0,temp1); fh.println(pageAdd); fh.close(); return 1; }
