Topic: Arduino Uno + RN-XV + XBee Shield = Doesn't Work (Read 807 times) previous topic - next topic
kevinsundar
So, recently I have been trying to use the Roving Networks RN-XV (https://www.sparkfun.com/products/10822) and the XBee Shield (https://www.sparkfun.com/products/9976) and the WiflyHQ library to create an ad-hoc network. The purpose is to use it for telemetry on a quadcopter.
But, This doesn't seem to work. The adhoc network is not created (I can't see it with a macbook). And it takes a while to setup the serial connection to the RN-XV (as seen by it flashing three times after a long delay). This makes me think that there is some type of watchdog timer in wifly.begin() that forces it to return after it retries a few times. Do you have any ideas on how to get it to work? Anyone used this combination before? Example code would be great.
This is my code:
Code: [Select]
    #include <Arduino.h>
    #include <WiFlyHQ.h>
    WiFly wifly;
        pinMode(13, OUTPUT);
        wifly.begin(&Serial, NULL);
        wifly.setIpProtocol(WIFLY_PROTOCOL_UDP);
        //Serial.println("Done Setup");
        digitalWrite(13, HIGH);   // turn the LED on (HIGH is the voltage level)
        delay(250);               // wait for a second
        digitalWrite(13, LOW);    // turn the LED off by making the voltage LOW
        //Serial.println("Attempting to Setup ADHOC Network...");
        wifly.createAdhocNetwork("wifly", 10);
        delay(4000);
        delay(250);
        delay(250);
        delay(250);
        if (wifly.available() > 0)
            if(wifly.read() == 'b')
               delay(1000);               // wait for a second
epinc
Couple of quick things.
You should try the RN-XV just buy itself without the Arduino. Download the data sheet on it. Supply 3.3V and Ground, and then there is a pin (pin 8? not sure) that you cycle every second 3 times to reset it and put it into ad-hoc mode. You should see the ad-hoc network then (it takes some time for it to appear). Verify the procedure using the data sheet.
Also, I don't know about the XBEE sheild, but I used the Arduino Wireless SD Shield ( http://www.amazon.com/Arduino-Wireless-SD-Shield/dp/B006RATC2E ) and if you are using Software Serial, you need to bend away pins 1 and 2 and runs jumpers from 1 and 2 to whatever TX and RX pins you are using for Software Serial. You also have make make sure the USB/Micro switch is in the right position.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
