Loading...
Pages: [1]   Go Down
Author Topic: Sampling audio from headphone jack.  (Read 244 times)
Haverhill, Ma
Offline Offline
Newbie
View Profile
I searched the forum and found this post http://arduino.cc/forum/index.php/topic,42833.0.html but I'm not able to reply to it.
I have a question in reference to the schematic on that page.
What happens if the "audio in" voltage is greater than 5 volts? Will the voltage going to the arduino still max out at 5 volts?
Thanks,
Bill
Logged
UK
Offline Offline
Edison Member
What a host of balls she had seen: gaity, the brass buttons...
View Profile
WWW
Yes.  The internal ESD diodes in the ATmega will bleed off the excess (to a certain extent).  Too much, though, and you risk blowing the chip.
You should attenuate the signal first if it's going to be too loud.
Logged
Haverhill, Ma
Offline Offline
Newbie
View Profile
That's not what I wanted to here  smiley-cry
Thanks for the reply
Logged
Haverhill, Ma
Offline Offline
Newbie
View Profile
Do you think placing a 5.1 volt zener diode between the analog pin and ground would be enough protection?
Logged
UK
Offline Offline
Edison Member
View Profile
WWW
That plus a resistor is a common way of protecting the inputs, yes.
The other thing you can do is just add a simple pot as a variable attenuator to turn down the volume smiley
Logged
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
No that only protects from over voltage, you also have to protect against negative voltages. Use a pair of rail clamping diodes.
See:-
http://www.thebox.myzen.co.uk/Tutorial/Protection.html
Logged
Haverhill, Ma
Offline Offline
Newbie
View Profile
Thank you both for your help.
Logged
Pages: [1]   Go Up
Print
Jump to:
