Topic: Wifi connection established - but how do I connect? (Read 965 times) previous topic - next topic
LockenPeter
Good afternoon,
I struggle a problem with my Arduino uno and wifi shield (also from Arduino).
I use a quite simple code which is shown below.
It just measures the temperature (and changes an RGB led colour according to that) AND connects to an WPA2 wifi network.
I do get the message "connected" so all seems to work pretty well...however - how do I connect to it to get the printing via wifi which is shown in Arduino's 'Serial Monitor'.
Does it work by typing the shield's IP into the internetexplorer, when also connected to the same WPA2 networl,.....and how do I get the shield's IP address?
Thanks a lot for any help,
Peter
Code: [Select]
#include <WiFi.h>
int sensorPin = 0;      //the analog pin the TMP36's Vout (sense) pin is connected to
                        //the resolution is 10 mV / degree centigrade with a
                        //500 mV offset to allow for negative temperatures
int redPin = 9;         // R petal on RGB LED module connected to digital pin 11
int greenPin = 11; // G petal on RGB LED module connected to digital pin 9
int bluePin = 10; // B petal on RGB LED module connected to digital pin 10
char ssid[] = "XXXXXX";     //  your network SSID (name)
char pass[] = "XXXXXX";    // your network password
int status = WL_IDLE_STATUS;     // the Wifi radio's status
* setup() - this function runs once when you turn your Arduino on
* We initialize the serial connection with the computer
  Serial.begin(9600);           //Start the serial connection with the computer
                                //to view the result open the serial monitor
// attempt to connect using WPA2 encryption:
  Serial.println("Attempting to connect to WPA network...");
  status = WiFi.begin(ssid, pass);
  // if you're not connected, stop here:
  if ( status != WL_CONNECTED) {
    Serial.println("Couldn't get a wifi connection");
    while(true);
  // if you are connected, print out info about the connection:
  else {
    Serial.println("Connected to network");
  pinMode(redPin, OUTPUT); // sets the redPin to be an output
  pinMode(greenPin, OUTPUT); // sets the greenPin to be an output
  pinMode(bluePin, OUTPUT); // sets the bluePin to be an output
void color (unsigned char red, unsigned char green, unsigned char blue)     // the color generating function
  analogWrite(redPin, 255-red);
  analogWrite(greenPin, 255-green);
  analogWrite(bluePin, 255-blue);
void loop()                                                      // run over and over again
  int reading = analogRead(sensorPin);                           //getting the voltage reading from the temperature sensor
  float voltage = reading * 5.0;                                 // converting that reading to voltage, for 3.3v arduino use 3.3
  voltage /= 1024.0;
  Serial.println("_____________________________");               // print out the voltage, println erzeugt einen folgenden Zeilenumbruch
  Serial.print("Gemessene Spannung: "); Serial.print(voltage); Serial.println(" Volt");
  float temperatureC = (voltage - 0.5) * 100 ;                   //converting from 10 mv per degree wit 500 mV offset; to degrees ((volatge - 500mV) times 100)
  Serial.print(temperatureC);Serial.println(" Grad Celsius");    // now print out the temperature
  float temperatureF = (temperatureC * 9.0 / 5.0) + 32.0;        // now convert to Fahrenheight
  Serial.print(temperatureF); Serial.println(" Grad Fahrenheit");
  if (temperatureC <= 0)
    Serial.println("Temperature: unter 0");
    Serial.println("Farbe: Weiss");
    color(255,255,255);
  else if ((temperatureC >0) && (temperatureC <= 5))
    Serial.println("Temperature: 0 - 5");
    Serial.println("Farbe: Tuerkis");
    color(127,255,212);
  else if ((temperatureC > 5) && (temperatureC <= 10))
    Serial.println("Temperature: 5 - 10");
    Serial.println("Farbe: Dunkelblau");
    color(0,0,255);
  else if ((temperatureC >10) && (temperatureC < 15))
    Serial.println("Temperature: 10 - 15");
    Serial.println("Farbe: Gruen");
    color(0,100,0);
  else if ((temperatureC > 15) && (temperatureC < 20))
    Serial.println("Temperature: 15 - 20");
    Serial.println("Farbe: Hellgruen");
    color(124,252,15);
  else if ((temperatureC > 20) && (temperatureC < 25))
    Serial.println("Temperature: 20 - 25");
    Serial.println("Farbe: Gelb");
    color(255,255,0);
  else if ((temperatureC > 25) && (temperatureC < 30))
    Serial.println("Temperature: 25 - 30");
    Serial.println("Farbe: Orange");
    color(255,69,0);
    Serial.println("Temperature: ueber 30");
    Serial.println("Farbe: Rot");
    color(255,0,0);
delay(5000);                                     //erneute Messung in 5 Sekunden
James C4S
Hint:  Serial.print() prints to Serial.
Server.print and Client.print print over WiFi.
http://arduino.cc/en/Reference/WiFiClientPrint
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
LockenPeter
Great, thank you very much for that hint. This might sort the biggest issues out.
Could someone maybe also give me a hint for the connection itself?
Do I need the shield's IP address and how can I find it?
Actually I tried to search the wifi environment for the shield but it isn't shown. So that seems to be the wrong idea.
Thanks a lot & regards,
Peter
LockenPeter
Each time when I chane serial.print to server.print it gets indicated as an error during compilation  :smiley-eek: .
Any ideas what's going wrong?
The shown message ist:
'server' not declared in this scope
Thanks a lot!!
And I'm still curious how to find out the IP address .-/ .
James C4S
Sounds like you need to spend some time with the included examples.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
