Loading...
Pages: 1 [2] 3   Go Down
Author Topic: Arduino Uno with a 32-bit ARM Cortex-M0 in 28 pin DIL package  (Read 3714 times)
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
Oh, I'll accept "not 10x faster", but I think "not remotely close to 10x faster" is too harsh.  I see "almost always faster, and 12x faster for some pretty common operations. "
I think I could come up with non-contrived code that would be significantly more than 12x faster (say by using an array of 32bit constants in flash.)
Of course I'm also in the group that believes an AVR is "fast enough" almost all of the time.
Logged
Offline Offline
Edison Member
View Profile
The peripherals are much slower than the mcu: it takes the same time to do 400khz i2c on a 72Mhz CM3 as it does on a 1Mhz avr. Or it takes the same amount of time to wait for a person to press a button, etc.
So the raw speed comparison on a mcu really isn't that meaningful.
I would venture a guess that the CMx chips are no more faster than an avr than their system clocks suggest.
Obviously, that conclusion changes if you are using those chips for some 32-bit intensive tasks (fft for example, or dsp on the cm4s).
Logged
Offline Offline
Newbie
View Profile
Also the ADC for LPC1114FN28/102 is at least 5 times faster than the one on Atmega328p, (for the ARM I am not seeing the maximum conversion time at full resolution which is needed for a more precise comparison).
ARM
The LPC1110/11/12/13/14/15 contain one ADC. It is a single 10-bit successive
approximation ADC with eight channels.
• Measurement range 0 V to VDD.
• 10-bit conversion time >= 2.44 us (up to 400 kSamples/s).
AVR
ATmega48PA/88PA/168PA/328P
Analog-to-Digital Converter
• 10-bit Resolution
• 13 - 260 μs Conversion Time
• Up to 76.9 kSPS (Up to 15 kSPS at Maximum Resolution)
« Last Edit: November 16, 2012, 07:49:09 pm by twice » Logged
Greenville, IL
Offline Offline
Edison Member
Warning Novice on board! 0 to 1 chance of errors!
View Profile
 The voltage range of the Arm is 'Single power supply (1.8 V to 3.6 V)."
A 328 can run up "– 0 - 4MHz@1.8 - 5.5V, 0 - 10MHz@2.7 - 5.5.V, 0 - 20MHz @ 4.5 - 5.5V"
I wonder if the fact an ADC could be required to charge up to the higher VDD on  the 328, if that is responsible for some of the time difference?
Logged
the land of sun+snow
Offline Offline
Edison Member
View Profile
WWW
Quote
I haven't looked into the ARMs directly, but the ADC sampling time is usually related to the size of
the sampling cap on the front-end of the ADC, as well as the the value of the external source
resistance.
Slower ADCs usually have a sampling cap in the 20-120 pF range, while for the fast ones it's more
like 4 pF. Also, the faster ones will say something like "source impedance must be 500 ohms max
for maximum sampling rate", while the slower ADCs will say something like 10K max. So, max
sampling rate mainly comes down to RC charging.
« Last Edit: November 17, 2012, 10:51:16 pm by oric_dan(333) » Logged
Kitchen-Sink Arduino-compatible boards
Greenville, IL
Offline Offline
Edison Member
View Profile
 Thank you for the explanation!
Logged
Offline Offline
Newbie
View Profile
Mouser had 3907 chips LPC1114FN28/102 DIP on 15 Nov. 2012. Now, 4 days later they have 3899 in stock.
This microcontroller does not seem to have many clients.
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
View Profile
It's an interesting chip, but the wide package and "only" 32k of flash make it less than compelling.   A PIC32MX150F128 in narrow 28-dip with 128k of flash is more interesting, even if it's $2 more.
Sigh.  It's really clear that NXP is serious about trying to displace 8bit CPUs.  I wish they were more obviously "on target" with their attempts.  16pin micoBGAs, 28pin wide DIPs, ... nice tries, but not quite what I was hoping for.  I can't quite tell whether they're clueless, or whether it really IS that hard to figure out what is really wanted in this nebulous "hobbyist/small manufacturer/mindshare" market space.
Logged
Offline Offline
Edison Member
View Profile
Quote
It is quite possible that nxp has studied the market and come to the conclusion that this super-duper red-hot "hobbyist" niche is not where they can make sufficient profit to float their boat. Instead, they want to focus instead on this much larger non-sexy industrial applications market for this chip.
Just try to a get a board with through-hole-parts made today and you will understand.
Logged
Offline Offline
Edison Member
View Profile
Quote
It is probably true that large customer orders don't show up on their web inventory.
Logged
Offline Offline
Newbie
View Profile
I have not studied it too much but the LPC Xpresso IDE, designed for ARMs produced by NXP, seems quite easy to work with.
The IDE hides the internal registers and you work mainly with easy to understand functions that set timers, IO ports, etc..
However, there may be traps, complications. LPC Xpresso IDE does not have a simulator, for instance, like Keil. You need the real hardware to test your code.
LPC Xpresso code example:
Code:
 *   $Id:: PWM16_32test.c 3635 2010-06-02 00:31:46Z usb00423                $
 *   Project: NXP LPC11xx 16-bit/32-bit PWM example
 *   Description:
 *     This file contains PWM test modules, main entry, to test PWM APIs.
 * Software that is described herein is for illustrative purposes only
 * which provides customers with programming information regarding the
 * products. This software is supplied "AS IS" without any warranties.
 * NXP Semiconductors assumes no responsibility or liability for the
 * use of the software, conveys no license or title under any patent,
 * copyright, or mask work right to the product. NXP Semiconductors
 * reserves the right to make changes in the software without
 * notification. NXP Semiconductors also make no representation or
 * warranty that such application will be suitable for the specified
 * use without further testing or modification.
#include "driver_config.h"
#include "target_config.h"
#include "timer32.h"
#include "timer16.h"
#include "gpio.h"
extern volatile uint32_t timer32_0_counter;
volatile uint32_t period = 1000;  //48Khz PWM frequency
/* Main Program */
int main (void) {
/* Initialize 32-bits timer 0 */
init_timer32(0, TIME_INTERVAL);
enable_timer32(0);
/* Initialize the PWM in timer32_1 enabling match0 output */
init_timer32PWM(1, period, MATCH0);
setMatch_timer32PWM (1, 0, period/4);
enable_timer32(1);
/* Initialize the PWM in timer16_1 enabling match1 output */
init_timer16PWM(1, period, MATCH1, 0);
setMatch_timer16PWM (1, 1, period/8);
enable_timer16(1);
/* Enable AHB clock to the GPIO domain. */
LPC_SYSCON->SYSAHBCLKCTRL |= (1<<6);
/* Set port 2_0 to output */
GPIOSetDir( 2, 0, 1 );
while (1)                                /* Loop forever */
/* I/O configuration and LED setting pending. */
if ( (timer32_0_counter > 0) && (timer32_0_counter <= 50) )
GPIOSetValue( 2, 0, 0 );
if ( (timer32_0_counter > 50) && (timer32_0_counter <= 100) )
GPIOSetValue( 2, 0, 1 );
while ( timer32_0_counter < 100 ); //wait for
  timer32_0_counter = 0;
A nice feature I like is that LPC Xpresso displays explanations about a function, ex. init_timer32 (the meaning of parameters, etc.) if you glide the mouse cursor over its name.
« Last Edit: November 19, 2012, 07:15:24 pm by twice » Logged
Offline Offline
Edison Member
View Profile
Quote
The ide does not hide anything: you can always code the mcu by writing to the registers.
However, in this case, they use a set of libraries from nxp to operate the peripherals. That's not unusual: ST has a set of its own libraries.
Logged
Offline Offline
Newbie
View Profile
Without those libraries working with ARM peripherals is really not practical.
If indeed one have to write all these lines of code to initialize a timer I imagine that not many people would dare to attack ARMs.
Code:
** Function name: init_timer
** Descriptions: Initialize timer, set timer interval, reset timer,
** install timer interrupt handler
** parameters: timer number and timer interval
** Returned value: None
void init_timer32(uint8_t timer_num, uint32_t TimerInterval)
  if ( timer_num == 0 )
    /* Some of the I/O pins need to be carefully planned if
    you use below module because JTAG and TIMER CAP/MAT pins are muxed. */
    LPC_SYSCON->SYSAHBCLKCTRL |= (1<<9);
    LPC_IOCON->PIO1_5 &= ~0x07; /*  Timer0_32 I/O config */
    LPC_IOCON->PIO1_5 |= 0x02; /* Timer0_32 CAP0 */
    LPC_IOCON->PIO1_6 &= ~0x07;
    LPC_IOCON->PIO1_6 |= 0x02; /* Timer0_32 MAT0 */
    LPC_IOCON->PIO1_7 &= ~0x07;
    LPC_IOCON->PIO1_7 |= 0x02; /* Timer0_32 MAT1 */
    LPC_IOCON->PIO0_1 &= ~0x07;
    LPC_IOCON->PIO0_1 |= 0x02; /* Timer0_32 MAT2 */
#ifdef __JTAG_DISABLED
    LPC_IOCON->JTAG_TDI_PIO0_11 &= ~0x07;
    LPC_IOCON->JTAG_TDI_PIO0_11 |= 0x03; /* Timer0_32 MAT3 */
#endif
#if CONFIG_TIMER32_DEFAULT_TIMER32_0_IRQHANDLER==1
    timer32_0_capture = 0;
#endif //TIMER32_0_DEFAULT_HANDLER
    LPC_TMR32B0->MR0 = TimerInterval;
#if TIMER_MATCH
LPC_TMR32B0->EMR &= ~(0xFF<<4);
LPC_TMR32B0->EMR |= ((0x3<<4)|(0x3<<6)|(0x3<<8)|(0x3<<10)); /* MR0/1/2/3 Toggle */
#else
/* Capture 0 on rising edge, interrupt enable. */
LPC_TMR32B0->CCR = (0x1<<0)|(0x1<<2);
#endif
    LPC_TMR32B0->MCR = 3; /* Interrupt and Reset on MR0 */
    /* Enable the TIMER0 Interrupt */
    NVIC_EnableIRQ(TIMER_32_0_IRQn);
#endif
  else if ( timer_num == 1 )
    /* Some of the I/O pins need to be clearfully planned if
    LPC_SYSCON->SYSAHBCLKCTRL |= (1<<10);
    LPC_IOCON->JTAG_TMS_PIO1_0  &= ~0x07; /*  Timer1_32 I/O config */
    LPC_IOCON->JTAG_TMS_PIO1_0  |= 0x03; /* Timer1_32 CAP0 */
    LPC_IOCON->JTAG_TDO_PIO1_1  &= ~0x07;
    LPC_IOCON->JTAG_TDO_PIO1_1  |= 0x03; /* Timer1_32 MAT0 */
    LPC_IOCON->JTAG_nTRST_PIO1_2 &= ~0x07;
    LPC_IOCON->JTAG_nTRST_PIO1_2 |= 0x03; /* Timer1_32 MAT1 */
    LPC_IOCON->ARM_SWDIO_PIO1_3  &= ~0x07;
    LPC_IOCON->ARM_SWDIO_PIO1_3  |= 0x03; /* Timer1_32 MAT2 */
#endif
    LPC_IOCON->PIO1_4 &= ~0x07;
    LPC_IOCON->PIO1_4 |= 0x02; /* Timer0_32 MAT3 */
#if CONFIG_TIMER32_DEFAULT_TIMER32_1_IRQHANDLER==1
    timer32_1_counter = 0;
    timer32_1_capture = 0;
#endif //TIMER32_1_DEFAULT_HANDLER
    LPC_TMR32B1->MR0 = TimerInterval;
#if TIMER_MATCH
LPC_TMR32B1->EMR &= ~(0xFF<<4);
LPC_TMR32B1->EMR |= ((0x3<<4)|(0x3<<6)|(0x3<<8)|(0x3<<10)); /* MR0/1/2 Toggle */
#else
LPC_TMR32B1->CCR = (0x1<<0)|(0x1<<2);
#endif
    LPC_TMR32B1->MCR = 3; /* Interrupt and Reset on MR0 */
    /* Enable the TIMER1 Interrupt */
    NVIC_EnableIRQ(TIMER_32_1_IRQn);
#endif
  return;
Maybe not all the code above is necessary for a particular application. I do not know.
There is another problem, sometimes you have to change the parameters of a timer on the run as fast as possible between two events that are 10-20 clock cycles apart.
It seems like functions as "init_timer32" need more than 20 clk. ticks. Is there workarounds?
« Last Edit: November 19, 2012, 08:19:39 pm by twice » Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Quote
The LPC Xpresso IDE is fantastic to work with smiley
When I first downloaded it I had a simple test program running in minutes. It's not as turnkey as Arduino but close.
Here's a version of blink that runs on the LPC1227
Code:
#include "LARD.h"
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 7;    // different pin on the LPC Xpresso board
// the setup routine runs once when you press reset:
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
void loop(void) {
  digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);               // wait for a second
  digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
Look familiar? smiley
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Offline Offline
Edison Member
View Profile
Quote
I guess I and folks I work with are one of those people, smiley
Once you build up your own blocks / functional modules by operating on registers, you have built up your own library: once you have written tmr1_set(1000);, you can call it next time to set a period of 2000 or 50199, without knowing much about how it did it, just that you know with confidence that it will do it right.
The beauty of modular programming.
Logged
Pages: 1 [2] 3   Go Up
Print
Jump to:
