Topic: Extend RFID Read Range SM130 (Read 1 time) previous topic - next topic
purduefiji
Hi Everyone,
Looking for suggestions on enhancing the read distance of SM130 module. The current read distance is 10cm. I would like to double or tripple this distance.
Using
SM130 13.56 MHz RFID Module - http://www.sparkfun.com/datasheets/Sensors/ID/SM130.pdf
RFID Evaluation Shield - 13.56MHz
Arduino Mega
Goal
Enhance read distance
One of the possibile solutions would be to add a power amplifier and attenuator/buffer between the antenna and the SM130 Module.
Example
SM130-->Power Amplifier -->Antenna --> Tag -->Antenna -->Attenuator/Buffer --> SM130
What do you think?
johnwasser
I think an antenna with more turns would produce a higher signal strength.
purduefiji
Could I add an LNA to the receive input?
johnwasser
I don't think so.  The antenna connection is for both output and input.  The RFID reader has to send power to the passive RFID card.  The LNA would help the receiver but would likely block the transmitter completely.  No power to the RFID card means no response.
