Topic: Looking for an RGB LED addressable strip 1 LED per segment (Read 7895 times) previous topic - next topic
poodull
Hello,
I've been looking for a led strip that can be cut down to 1 led per segment.  Most I've seen are 3 per segment.  I need this because the leds will backlight holes that aren't perfectly spaced and a ribbon solution is easier to implement that some kind of xxxplexing or home run.
I found this:  http://www.amazon.com/Addressable-Waterproof-WS2801-Connectors-Included/dp/B008F05N54/ref=pd_rhf_se_p_t_3
which is okay and a good price, but I have no idea what the lumens are on that LED.
Then there's Pololu's solution which is bit-bang:
http://www.pololu.com/catalog/product/2540
But my controller is using interrupts and a bunch of other things and I don't want to get into a situation where timing will be an issue.  I'd rather clock and latch or SPI (if I can ever figure that out).
Right now I'm using ShiftBrites but they're pretty expensive (~$5/ea compared to <$1/ea).  They are really bright, though.
So that's where I am.. is the Amazon unit (no name x) A) bright *enough* and B) actually a good price?
Further info:  I'm driving about 80~90 LEDs, hopefully updating every 30~50ms.
I scoured Ebay looking for this product but all I found was 5050s, which are 3/segment.
Thanks
fc
KirAsh4
#1
Nov 16, 2012, 10:10 pm Last Edit: Nov 16, 2012, 10:13 pm by KirAsh4 Reason: 1
That Amazon link is for a strip with 5050's on it.  That's the LED name.  The difference is that, as you noticed, they come in different versions, some are able to be cut every pixel and others every 3.  Most of the individually addressed ones are single pixels.  Those things are very bright, I buy entire reels straight from China though.  One 5 meter reel for $60-$70, plus shipping.
Here's the same strip on eBay: http://r.ebay.com/usJlg2
poodull
#2
Nov 16, 2012, 10:28 pm Last Edit: Nov 16, 2012, 11:01 pm by poodull Reason: 1
Hey, awesome!  Thanks.  I learned 2 things today.
So you've had success cutting and rewiring these up?  and length limitations?  sample code or pitfalls to look out for/advice?
Taking another look at the Amazon one, they do have a clock (4 pins, not 3).  The Pololu one's are like yours where it's a single wire.  Other than that I don't know the difference.  In fact, I'm not sure how to drive either one of them.  It seems like the bit-banged ones require knowing the ns timing and making sure its hit accurately.  I guess the one with a clock only requires the clock to be driven high.  Honestly I have no idea how to drive these things and it seems to me like every led strip has it's own library and hardware requirements.  I feel like it's not as steep a learning curve as I'm making it out to be, but the infinite hardware combinations are making it complex.
Thanks again.
fc
KirAsh4
I have cut them to whatever length I need them to be, no issues there.  The only issues with length is that at some point you need to add some pull-downs to the data and clock lines at the END of the string, to avoid reflection of the signal.  And I use FastSPI to drive these.  Adding the necessary dataRate line to the code, you can clock those things pretty dang fast.
poodull
So I guess the ones with a clock you just drive the clock high instead of waiting 50us?  Since I have interrupts I'm guessing that I would need the clock version, even though it's 2x the cost.
fc
KirAsh4
You clock the data in, the waiting period is to latch it in and thus the lights react.  You can clock data in all day long if you want, but it's not till you wait the 500uS that the data you clocked in will actually get latched in and the IC does something with the LEDs.
The FastSPI library takes care of all of that for you.
poodull
So reading this thread has me wondering:
http://arduino.cc/forum/index.php/topic,80567.0.html
why would you suggest WS2811 LEDs on an Arduino forum?  I would need a newer clocked arduino (uno, leo, teensy3, etc) to just keep up with >50 LEDs.  Specifically, something off-brand 'duino compatible with a honking processor.
Nobody on that thread mentioned fastSPI, though.  Is fastSPI fast enough to handle a 2811 on an 16MHz arduino?  32?  32 with interrupts?
Your last post says 500us to latch, but the code says 50us... which the other thread says is impossible/flakey for more than a few leds.
I just seems to me like a pretty significant detail to skip, no?
fc
KirAsh4
Go back and re-read it.  The original OP wanted to try the 2811, which is very different from the 2801 (and 2803 for that matter), and I suggested they experiment.  I wouldn't suggest the 2811 unless I've tried using them myself, and I have not.  As it turned out, you do need a faster processor to work with those.  A stock 16MHz/20MHz Arduino won't cut it.  The newer Leonardo might, but I have no bench test to prove that.  Nor do I have any interest in using the 2811s any time in the near future.  I'm quite happy with the 2801 and 2803, I've also ventured into the LPD1101 series (which is the next generation LPD6803).  They all work with FastSPI on a stock Arduino or clone.
You, on the other hand, are asking about the 2801, and you can drive those just fine with any stock or clone Arduino with a 16MHz processor, or even at 8MHz.  I have several strings that I made of 50 pixels, running on an 8MHz with no problems.  And I've bit-banged them, which is much slower than FastSPI.  I'm working on a custom design that has a 90 pixel string, running at 16MHz with FastSPI, no issues what so ever.
As for the latch/reset timing, read the datasheet, specifically page 11, under 'Gray Scale Data Word Format and Timing', very first sentence.  If you're using FastSPI, you don't need to do any of the latching yourself, just send it the necessary commands and the library does it all.  And those saying it's flakey, that's merely because they neglect to add the dataRate needed in the FastSPI code for this specific IC.
poodull
Okay, got it.  And let me start by first saying thanks for your help.  I really do appreciate it.
My only point of confusion (and the reason I posted my last post) was because the link you sent me to the led strip in Ebay states that it uses 2811s
http://www.ebay.com/itm/60-LEDs-m-1M-WS2811-RGB-LED-strip-IP67-Waterproof-Individually-Addressable-/160896346789
That's all.  I was confused because I think you found a similar strip to my link to Amazon, but with the different (faster) clock.
Or am I missing something bigger?
Thanks again,
fc
KirAsh4
#9
Nov 19, 2012, 09:06 pm Last Edit: Nov 19, 2012, 09:10 pm by KirAsh4 Reason: 1
Sorry, that's my bad.  I had multiple windows open.  What I meant to link was the 2801 version:
http://r.ebay.com/HUVgak
Note that the same vendor also sells a full reel, 5m, for a little over $144.  Buying it straight from China will be a little under $90 including shipping.  Just saying.
poldim
#10
Nov 26, 2012, 05:09 am Last Edit: Nov 26, 2012, 05:29 am by poldim Reason: 1
Do you have any more info on this?
More specifically, I purchased a similar 5m led digital strip,WS2801IC 32pcs IC+32pcs 5050 SMD RGB/meter with a total of 160 (32*5) LEDs.  I've paired this up with a duemillanove and a 5V 5A PS.  On the arduino, I've ran the fastSPI test leds PDE and the adafruit WS2801 strand test PDE, with consistent errors after exceeding about 60 LEDs.  The failure that occurs are the first led pixel being off color and some leds toward the end of the string or all leds begin to behave erratically. Any thoughts?  Maybe throw in a pull down resistor after the 50th?
KirAsh4
#11
Nov 26, 2012, 10:56 am Last Edit: Nov 26, 2012, 10:58 am by KirAsh4 Reason: 1
Read the data sheet on the WS2801.  It tells you when/where you need to add the resistors.
However, I have run the FastSPI testled sketch on a full 5m reel straight out of the box with no problems what so ever.  The only change I made to the sketch was to add the proper dataRate line, which is missing from the sketch.  No resistors added, just hook up the four wires, make sure the 4 wires at the end aren't touching anything metal, and turn it on.  In fact, I just grabbed two reels, hooked them up in parallel to my Uno, using FastSPI.  I only ran one sequence, which is the single color down the whole strip, because it's not hooked up to a high amp power supply:
(the freezing that you're seeing, if any, is just the way YouTube processed the video - the chase is smooth with no hiccups.)
http://www.youtube.com/watch?v=1XhF-0Tlg_U
poldim
Thanks for posting this up. I looked in the spec sheet and it only states what's below.  I changed the pull up resistors from 10K to 50 with no positive effect.
The Connection and Driving of Cascading Operation
The transmit the data over long distance by cascading, the WS2801 integrates push-pull output stage with strong driving capability which enables the data and clock can be transmitted up to 6 meters at 2MHz clock frequency.
To prevent the reflection, it is necessary to connect a 50? resistor at the data input or output port for impedance match.
Any thoughts on what the problem could be?  A bad/faulty strip?  This wouldn't surprise me because the quality does not look top notch...
This afternoon I will try swapping out to a spare arduino to see if that changes anything.
KirAsh4
Maybe post your sketch so I can see what you're doing ...
poldim
#14
Nov 27, 2012, 02:25 am Last Edit: Nov 27, 2012, 06:09 am by poldim Reason: 1
FastSPI: http://code.google.com/p/fastspi/
Adalight: https://github.com/adafruit/Adalight
I've found that the adalight package fails almost immediately.  However, with FastSPI, if I set the data rate to 7 (the slowest), and increase all of the delay times, it more or less works but eventually fails.
