Topic: How to if digitalRead(OUTPUT) then if digitalRead(INPUT) (Read 4344 times) previous topic - next topic
majdi_mohammad
Nov 16, 2012, 01:16 am Last Edit: Nov 16, 2012, 01:59 am by Coding Badly Reason: 1
Hello, i try to make two LDr sensing the if serial recived example A and B.
if serial A then
PIN11 HIGH
when PIN11 HIGH wait for INPUT sensing LOW at pin 2
if serial B then
PIN10 HIGH
when PIN10 HIGH wait for INPUT sensing LOW at pin 3
this code run in loop..i suggesfully with pin 10, but fail with pin 11.
Here my code:
 Serial.println(i++);
//-------------------------------------FAIL to work-------------------------------------------
//AUTO Sensing following selected autofilling - each sensor
if (digitalRead(11)==HIGH)      // digitalRead(11)==HIGH)
 if (digitalRead(2)==LOW)      // wait for 2.8 litle sensor detected oil then
 digitalWrite(13, LOW);        // pump1 stop
 Serial.println("13 low");
 delay(100);                   // give some time space before next process
 digitalWrite(12, HIGH);       // Start pump2 to pump oil to gearbox container
 Serial.println("12 high");
//-----------------------------------------SUCCESS-----------------------------------------
//AUTOFILLING 3.5LITLE PROCESS
if (digitalRead(10)==HIGH)      //  digitalRead(10)==HIGH)
 if (digitalRead(3)==LOW)      // wait for 3.5 litle sensor detected oil then
 digitalWrite(12, HIGH);       // Start pump2 to pump oil to gearbox cointainer
look like pin 11 not read, because if i change if (digitalRead(11)==LOW) the is work. Why this happen? I try to put LED it ligh on but it not read as HIGH
Moderator edit: [code] [/code] tags added.
Arrch
What's hooked up to pin 11? How is it hooked up? Post all of your code and perhaps try explaining it again; I'm having a difficult time trying to figure out what you're trying to do and what the problem actually is.
majdi_mohammad
#2
Nov 16, 2012, 01:32 am Last Edit: Nov 16, 2012, 01:59 am by Coding Badly Reason: 1
Here all complete code:
This will be serial on/off pin 13 and pin 11&10.
1.When i send 0 or 1 serial data, pin 13 will be HIGH and LOW
2.When i send 2 serial data, pin 13 will HIGH and pin 11.
-Pin 13 i hook with 1k resistor and bc548 transistor to control relay. For pin 11 i hook with Green LED and 220 ohm resistor.
-Pin 13 on the relay and pin 11 on the LED, i plan to used pin 11 as sensing if pin 11 High then it wait for LOW at Pin 2.
-After pin 2 connected with ground and sense as LOW, pin 12 will on and pin 13 off.
-Final process is if pin 4 sense Low the pin 12 off.
*I want to digitalRead pin 11 and 10 to separate the input program sequence for each serial data received.
//Setup atmega328-p serial communication and inout pin
Serial.begin(9400);
//Setup input pin------------------------------------------------------------------------------------
pinMode(2, INPUT);  //Sensor 1 litle
pinMode(3, INPUT);  //Sensor 2 litle
pinMode(4, INPUT);  //Sensor OverFlow
//Setup output pin------------------------------------------------------------------------------------
pinMode(10, OUTPUT); //Sensing 2.8 Litle
pinMode(11, OUTPUT); //Sensing 3.5 Litle
pinMode(12, OUTPUT); //PUMP2
pinMode(13, OUTPUT); //PUMP1
//Set all output as low/off----------------------------------------------------------------------------
digitalWrite(10, LOW);
digitalWrite(11, HIGH);
digitalWrite(12, LOW);
//Initialise i as 0, so it start cointing from 0 to infinite
int i=0;
//Using loop function for all operation
if (digitalRead(11)==HIGH) // && digitalRead(11)==HIGH)// wait for android send data to serial, and give HIGH status for pin 10
if (digitalRead(10)==HIGH) // && digitalRead(10)==HIGH)// wait for android send data to serial, and give HIGH status for pin 10
//Over flow sensor detection function
if (digitalRead(4)==LOW)
 Serial.println("12 low");
 delay(100);
 digitalWrite(11, LOW);
 Serial.println("11 and 10 low");
//Serial speed
delay(200);
//Wait for serial android data recived------------------------------------------------------------------
if (Serial.available())
int msg = Serial.read();
//Evan from android, sub p will wait in loop mode to operate as ordered
//START PUMP1
if (msg == '0')
 digitalWrite(13, HIGH);                           //PUMP1 manual start
 Serial.println("Pump1 start");
//STOP PUMP1
if (msg == '1')
 digitalWrite(13, LOW);                            //PUMP1 manual stop
 Serial.println("Pump1 stop");
//2.8 Litle filling
if (msg == '2')
 digitalWrite(11, HIGH);                     //Sensing for 2.8 litle function ON
 digitalWrite(13, HIGH);                     //Pump 1 start to pump oil from main tank1 to Measure tank2
 Serial.println("Sensing auto filling 2.8");
//3.5 Litle filling
if (msg == '3')
 digitalWrite(10, HIGH);                     //Sensing for 3.5 litle function ON
 Serial.println("Sensing auto filling 3.5");
PeterH
Are you trying to do digitalRead() on an output pin? (Why?)
Please enclose your code in [ code ] [ /code ] tags to stop the forum software from munging it.
I only provide help via the forum - please do not contact me for private consultancy.
Arrch
Pin 13 can't be HIGH and LOW at the same time, do you mean you want pin 13 to be HIGH when you receive a '0' and pin 13 to be LOW when you receive a '1'?
... and pin 11 what?
-i plan to used pin 11 as sensing if pin 11 High then it wait for LOW at Pin 2.
What? How do you plan on using pin 11 to sense if it is HIGH? Isn't pin 11 an output? If it's an output, then your code controls if it's HIGH or LOW, so you just need a simple variable to keep track.
Pin 2 is connected straight to ground? It will always sense LOW, so pin 12 will always be on and pin 13 will always be off.
What does "input program sequence" mean?
majdi_mohammad
Yup, i want to used output pin read for avoid from sensor 2.8 liter run their code before 3.5 liter sensor detected.
Here i attached a picture to help other understand better.
Let say the code is working, if i send serial data 2, pump1 start pumping oil from tank a to tank b, senosr 2.8 liter detected then pump 1 stop and pump2 start pumping oil from tank b to tank c. After over flow detected pump 2 stop.
But if i send serial data 3, it will be stuck on 2.8 liter sensor not 3.5 liter sensor.. ;(
If there any better suggestion please guide me..
majdi_mohammad
Yes, it not HIGH & LOW at same time, it High when serial data send "0", and Low if serial data "1". ---This part work fine
Pin 11 will on an LED if serial data send "2"
I used :
Not work on pin 11
if (digitalRead(11)==High)           // pin 11 ------------->LED------>220 ohm ---------GND
  if (digitalRead(2)==LOW)          // pin 2 ----^------> 20kOhm----------> 5DC
    {                                        //              l l sensor sense then connect to GND
NEXT code here.....
Successfully work on pin 10
if (digitalRead(10)==High)           // pin 10 ------------->LED------>220 ohm ---------GND
  if (digitalRead(3)==LOW)          // pin 3 ----^------> 20kOhm----------> 5DC
NEXT code here.....
Input sequence i mean, if i choose to sensor 3.5 liter detected oil, then all program for sensor 2.8 liter will not run..
majdi_mohammad
Hey guys, it work ;) my bad soldering, i dont know why it act like that, but i mistaken join Pin11----Led----bypass the resistor-----GND.. Then the code not detected it as HIGH. After i remove the bad soldering and Pin11----LED---220 ohm ------ Gnd. Then it work perfectly. Thank guys for your time.
