Topic: Uno - prevent multiple COMM port enumeration? (Read 564 times) previous topic - next topic
chrissv
Hello,
I have 20 Arduino Uno devices to program with the same program - for 20 identical instances of my project.
Each time you connect a different Uno, it enumerates a new COMM port.
Is there any way to change this behavior? I have 20 Arduino's to program and it is tedious to keep going into the device manager and deleting the COMM port of the Arduino I just programmed...
Thanks,
    Steven
larryd
Use the ICSP to program them. (bootloader will be removed)
Are these stand alone or separate UNOs?
No technical PMs.
The last thing you did is where you should start looking.
chrissv
These are stand-alone Unos with a custom shield.
I don't want to eliminate the bootloader - I want to continue to use the bootloader to update code in the future. It's just that programming 20 in a row results in 20 enumerated COMM ports (unless I delete them...)
Thanks,
    Steven
larryd
If these are DIP packages move the I.C.s from each destination UNO to an UNO plugged into the USB (Cable removed obviously while going so).
No technical PMs.
