Topic: XBee RSSI Signal (Read 3668 times) previous topic - next topic
UNTEngineer
Could I use the RSSI signal to determine signal strength? Can someone suggest a simple circuit that I can visually display the signal using a LED bar graph.
oric_dan
According to my d/s, RSSI is a PWM output. You can filter this using a simple RC low-pass filter, and feed
to an LM394 or LM3915. They apparently still make these things.
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_24230_-1
http://www.jameco.com/1/1/2533-lm3915n-1-lm3915-dot-bar-display-driver.html
For ckts, do a google image search on LM3914 or LM3915,
http://www.google.com/imghp
UNTEngineer
Well I have a PCF8574N. Will that work?
oric_dan
Ok, take at look at the chips I mentioned and see how they compare to your [what I presume is an]
I2C expander. You want a display, no?
UNTEngineer
I looked at the LM3916, and I realized the difference after I posted that. One is a multiple LED/LCD driver and the other is an I2C expander for an LCD.
What values would you suggest for the Low Pass Filter?
UNTEngineer
oric_dan
You need to know the PWM frequency out of the RSSI pin, and then select a cutoff frequency
roughly 10X lower, according to
F3db = 1/(2*pi*R*C)
Use R=4.7K or 10K as a starting point and calculate C accordingly. That's where I'd start.
betomax
take a look to dev interface schematic, were a lm339 is used to drive 3 leds (basic comparator) feed with rssi output through RC filter
http://ftp1.digi.com/support/images/XBIB-R-dev%20schematic.pdf
JChristensen
I'm working on a project right now that does this. Connect the XBee RSSI pin to a digital input pin and use pulseIn() to read the PWM pulse width.
S1 or S2 XBees?
