i want to configured the xbee ...
when i upload the sketch ,i put the switches prog/usb
when is the upload finish, i put the switches run/xbee
www.dfrobot.com/wiki/index.php/Xbee_Shield_For_Arduino_(no_Xbee)_(SKU:DFR0015)
but the xbee is not configured like say the tuto
boolean configured;
int ledPin = 13; // LED connected to digital pin 13
boolean configureRadio() {
// put the radio in command mode:
Serial.print("+++");
String ok_response = "OK\r"; // the response we expect.
// Read the text of the response into the response variable
String response = String("");
while (response.length() < ok_response.length()) {
if (Serial.available() > 0) {
response += (char) Serial.read();
// If we got the right response, configure the radio and return true.
if (response.equals(ok_response)) {
Serial.print("ATID3137\r");
Serial.print("ATCN\r"); // back to data mode
return true;
return false; // This indicates the response was incorrect.
void setup () {
Serial.begin(9600); // Begin serial
configured = configureRadio();
void loop () {
if (configured) {
Serial.print("Hello!");
delay(3000);
else {
delay(30000); // Wait 30 seconds
configured = configureRadio(); // try again
