Loading...
Pages: [1]   Go Down
Author Topic: Uploading with Atmel Studio 6  (Read 1931 times)
Germany
Offline Offline
Newbie
View Profile
How do I upload code written with Atmel Studio 6?
Do I need a SAMIce Debugger/Programmer or is there a way to upload via the usb programming port?
Cheers
Pingflip
Logged
Chennai, India
Offline Offline
God Member
Peace!!!
View Profile
WWW
The following 2 commands will help you upload a .bin file from command line using the programming port
mode com7:1200,n,8,1
bossac.exe --port=COM7 -U false -e -w -v -b Blink.cpp.bin -R
you need to add the location of the bossac.exe (somewhere inside the arduino folder) to your path file
if you want this to work from Atmel Studio, You can create a batch file and create an external tools under the tools option in Atmel Studio like this
http://www.jayconsystems.com/tutorial/atmerpt1/
Let me know how it goes..
Logged
Be The Change...
Germany
Offline Offline
Newbie
View Profile
thanks for the answer, i'm gonna try that tomorrow.
I just did a quick test with bossac gui and tried to connect to the board, but it was not able to connect (tried on Os X, Windows 8, and Win XP running in a virtual Box on a mac).
Pingflip
Logged
Venezuela
Offline Offline
Full Member
Ground.......ground........always ground
View Profile
WWW
Quote
Every time I need to re-load a sketch in the Arduino Due using bossac as you mentioned, I have to erase-reset the board. Why?
I don't know yet. That is not happening with Arduino IDE. I have checked this phenomenon with Windows 7 and Windows XP with same results.
May be Arduino IDE shows in the verbose output, just part of the enumeration of the upload.
Logged
Wahiawa, Hawaii
Offline Offline
Sr. Member
View Profile
Yes, the bossac bootloader only runs if the memory is erased.  The Arduino IDE does this by opening and closing the COM port at 1200 baud.  This causes the Due to execute a soft erase command.
Logged
Chennai, India
Offline Offline
God Member
Peace!!!
View Profile
WWW
ok..I think to use bossac gui, you need to press the erase button before you choose to load your program but the batch file would be a better approach for loading from within atmel studio. I have no clue how to program the SAM3X8E in atmel studio otherwise i would try.. perhaps you can share a simple code..
Logged
Be The Change...
Odense, Denmark
Offline Offline
Newbie
View Profile
Quote
On win7 the solution, that made it work for me, was to add ",p" to the end of the mode line ie. (using com6) :
mode com6:1200,n,8,1,p instead of just mode com6:1200,n,8,1
Now mode com outputs the following :
Status for device COM6:
    Baud:            1200
    Parity:          None
    Data Bits:       8
    Stop Bits:       1
    Timeout:         ON
    XON/XOFF:        OFF
    CTS handshaking: ON
    DSR handshaking: ON
    DSR sensitivity: OFF
    DTR circuit:     HANDSHAKE
    RTS circuit:     HANDSHAKE
Instead of :
    Baud:            1200
    Parity:          None
    Data Bits:       8
    Stop Bits:       1
    Timeout:         ON
    XON/XOFF:        OFF
    CTS handshaking: OFF
    DSR handshaking: OFF
    DTR circuit:     ON
    RTS circuit:     ON
And bossac is uploading w.o. any pressing of the Erase button.
Logged
Germany
Offline Offline
Newbie
View Profile
Hi, I found this engblaze project (probably everyone knows it) using the arduino standard programmer for the 8bit machines wit AVR-Studio5 and 6. Is there a chance to adapt the code for the 16U2 to the Due to run it with avrdude or bossa so it will work out of the IDE without a additional command line thing?
Logged
Pages: [1]   Go Up
Print
Jump to:
