Topic: progmem help (Read 950 times) previous topic - next topic
Pavilion1984
Hi all, hope you can help. What is the correct way to read "HELLO2" from the code below?
prog_char hello[] PROGMEM =
  "HELLO1"
  "HELLO2"
  "HELLO3"
Many thanks.
PaulS
Does that snippet even compile?
Pavilion1984
I don't get any errors apart from the line that says
sprintf_P(str1, hello[2]);
my full code below.
#include <avr/pgmspace.h>
  "HELLO1"
  "HELLO2"
  "HELLO3"
//Initialize serial and wait for port to open:
  while (!Serial)
    ; // wait for serial port to connect. Needed for Leonardo only
  char str1;
  Serial.print(str1);
  delay(5000);
Am wanting to have an array of strings and read them when i want. Just trying to learn about progmem.
AWOL
#3
Nov 16, 2012, 02:31 pm Last Edit: Nov 16, 2012, 02:57 pm by AWOL Reason: 1
 "HELLO1"
 "HELLO2"
 "HELLO3"
This is what "hello" contains: "HELLO1HELLO2HELLO3" (a single C string)
If that's what you want, then it is easy to locate "HELLO2" - it starts at offset 6, and is 6 characters long.
It might be easier for you to store them as separate strings.
Pavilion1984
I have just noticed AWOL that my strings are not separate lol and thats what i want so i gues my code needs to be something like below
 "HELLO1",
 "HELLO2",
 "HELLO3"
so how would i read the second string?
Pavilion1984
I have worked it out now with the code below.
prog_char hello[3][7] PROGMEM =
  "HELLO1",
  "HELLO2",
  "HELLO3"
  while (!Serial)
  char str1[16];
  Serial.print(str1);
  delay(5000);
PaulS
If that code is printing "HELLO2", something is wrong. That should be printing "HELLO3".
