Loading...
Pages: 1 [2]   Go Down
Author Topic: get heat from battery (question)?  (Read 879 times)
UK
Offline Offline
Edison Member
What a host of balls she had seen: gaity, the brass buttons...
View Profile
WWW
Quote
20,000 Watts would take 6 seconds.
...annnd a 9V battery would take 10 days.  smiley-lol
9V at 150ma = 1.35W
333Wh/1.35W = 246hours
Make that 15 days - you're forgetting the time taken to swap the battery every 15 minutes.
Logged
Canada
Offline Offline
Sr. Member
Sometimes teaching, always learning,
View Profile
Also, if you go too slow, you will be losing heat faster than the battery can put it in. Theoretically a 1.35W heater should be able to boil water. Realistically it won't even come close for any substantial amount of water.
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Oh, yes.  All those times assume perfect insulation.
33.333 Watt Hours from a 12V battery would be about 2.8 Amp Hours.  You can get that size sealed lead-acid battery for under $20.  Unfortunately that battery is rated 2.9 Ah at 20 hours.  Without perfect insulation there is no way you are going to heat the water over 20 hours and get the same temperature rise.  I think you will need a significantly larger battery, like a car battery.  You can then buy a 200W car immersion heater to turn the charge in the battery into heat: http://www.langtoninfo.com/showitem.aspx?isbn=8000692729878&gclid=CI3EqfrQ1LMCFUOK4AodA0YARA
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Car batteries aren't great for deep cycle use (but can provide rapid heating, most will provide several kW for a short period).
Fortunately they are usually around 35 to 45Ah, which is a big margin.
Say 400A for 40s (assuming battery voltage drops to 8V or so due to internal losses) would give 120kJ and be about 20%
discharge depth or so.  Stupidly thick copper wiring would be needed (10mm or so)
A more reasonable 50A for 200s (this time about 12V) would mean more practical heater element and connecting wires (4mm diameter or so)
Alternatively a deep-cycle lead-acid battery at 20A for 8 to 10 minutes...  Capacity of 10Ah or more ought to be sufficient for a deep cycle.
Logged
Canada
Offline Offline
Sr. Member
View Profile
I'm curious now why the OP wants to heat up 2L of water as fast as possible with a battery.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
But not to the temperature of tea...
Logged
Offline Offline
God Member
View Profile
i'd go to a camping store and buy a small gas bottle smiley
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
I thought of that (or a gasoline camp stove) but what if flames/combustion are not allowed?
Perhaps an exothermic chemical reaction.
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
Powdered iron, powdered magnesium, salt. Just add water to start the reaction...
Logged
England
Offline Offline
Newbie
View Profile
You could get it to 21 degrees by leaving it stood on the side.
Logged
Sulaymaniyah-Kurdistan
Offline Offline
Jr. Member
View Profile
thanks all for the replays smiley
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
