Pages: [1] 2   Go Down
Author Topic: get heat from battery (question)?  (Read 951 times)
Sulaymaniyah-Kurdistan
hi
i want to convert 9v battery or 12 volt battery into heat, i mean to get a heat from the battery to warm something up, it not important if the heat is not too much??
is it possible?
Massachusetts, USA
Energy in a battery can be converted to heat.  Use a resistor.  Current is voltage/resistance. Current times voltage is heat in watts.  If you dump a 12V battery into a 2 Ohm resistor you will get 6A of current and thus 12(V)*6(A) = 72 Watts of heat.
Valencia, Spain
hi
is it possible?
Seems like an expensive way to do it. A battery won't last long if you draw enough current to make it hot. Why not use a normal heating element?
No, I don't answer questions sent in private messages...
UK
What a host of balls she had seen: gaity, the brass buttons...
... and a very smokey resistor ...
Make sure your resistor can handle the power, or it will burst into flames.  A little ¼W one wouldn't be suitable smiley-wink
You can make your own heating element using Nickel Chromium (NiChrome) wire.  A good source for this is from an old electric heater, surprisingly enough smiley
i couldn't what you all said
please explain it clearly!
can i get a enough heat by 9v  battery and normal heating element??
Valencia, Spain
Enough heat for what? You'll get better answers if you tell people what you're trying to do.
for water!
Gosport, UK
How much water? What temperature increase do you need?
the amount of water is less than 2 L and change  the temperature up to  25c from 10c
UK
Over how long a period?  (i.e., how fast do you want it to heat up?)
Valencia, Spain
How many joules of energy is that? How many are in your battery?
Answer: Over 120Kj of heat needed, only 18Kj in a 9V battery. You'll need about 15 batteries to do it.
« Last Edit: November 16, 2012, 10:59:48 am by fungus » Logged
the time as fast as it can
Massachusetts, USA
Answer: Over 120Kj of heat needed.
120,000 Joules = 33.333 Watt-hours
A 100 Watt heater would heat the water in 1/3 hour (20 minutes). Do you need faster heating?
200 Watts would take 10 minutes.
2,000 Watts would take 1 minute.
20,000 Watts would take 6 seconds. smiley
Canada
Sometimes teaching, always learning,
...annnd a 9V battery would take 10 days.  smiley-lol
9V at 150ma = 1.35W
333Wh/1.35W = 246hours
Pages: [1] 2   Go Up
