Sulaymaniyah-Kurdistan
« on: November 16, 2012, 08:15:54 am » |
hi i want to convert 9v battery or 12 volt battery into heat, i mean to get a heat from the battery to warm something up, it not important if the heat is not too much?? is it possible?
Massachusetts, USA
« Reply #1 on: November 16, 2012, 08:41:11 am » |
Energy in a battery can be converted to heat. Use a resistor. Current is voltage/resistance. Current times voltage is heat in watts. If you dump a 12V battery into a 2 Ohm resistor you will get 6A of current and thus 12(V)*6(A) = 72 Watts of heat.
Valencia, Spain
« Reply #2 on: November 16, 2012, 08:56:46 am » |
Seems like an expensive way to do it. A battery won't last long if you draw enough current to make it hot. Why not use a normal heating element?
UK
What a host of balls she had seen: gaity, the brass buttons...
« Reply #3 on: November 16, 2012, 08:58:36 am » |
... and a very smokey resistor ... Make sure your resistor can handle the power, or it will burst into flames. A little ¼W one wouldn't be suitable  You can make your own heating element using Nickel Chromium (NiChrome) wire. A good source for this is from an old electric heater, surprisingly enough
« Reply #4 on: November 16, 2012, 09:23:38 am » |
i couldn't what you all said please explain it clearly!
« Reply #5 on: November 16, 2012, 09:27:20 am » |
can i get a enough heat by 9v battery and normal heating element??
Valencia, Spain
« Reply #6 on: November 16, 2012, 09:31:41 am » |
Enough heat for what? You'll get better answers if you tell people what you're trying to do.
« Reply #7 on: November 16, 2012, 09:37:06 am » |
Enough heat for what? You'll get better answers if you tell people what you're trying to do. for water!
Gosport, UK
« Reply #8 on: November 16, 2012, 09:42:31 am » |
How much water? What temperature increase do you need?
« Reply #9 on: November 16, 2012, 09:44:11 am » |
the amount of water is less than 2 L and change the temperature up to 25c from 10c
UK
« Reply #10 on: November 16, 2012, 10:52:02 am » |
Over how long a period? (i.e., how fast do you want it to heat up?)
Valencia, Spain
« Reply #11 on: November 16, 2012, 10:57:17 am » |
How many joules of energy is that? How many are in your battery? Answer: Over 120Kj of heat needed, only 18Kj in a 9V battery. You'll need about 15 batteries to do it.
« Last Edit: November 16, 2012, 10:59:48 am by fungus »
« Reply #12 on: November 16, 2012, 11:06:18 am » |
the time as fast as it can
Massachusetts, USA
« Reply #13 on: November 16, 2012, 01:38:04 pm » |
Answer: Over 120Kj of heat needed.
120,000 Joules = 33.333 Watt-hours A 100 Watt heater would heat the water in 1/3 hour (20 minutes). Do you need faster heating? 200 Watts would take 10 minutes. 2,000 Watts would take 1 minute. 20,000 Watts would take 6 seconds.
Canada
Sometimes teaching, always learning,
« Reply #14 on: November 16, 2012, 01:54:52 pm » |
20,000 Watts would take 6 seconds. ...annnd a 9V battery would take 10 days. 9V at 150ma = 1.35W 333Wh/1.35W = 246hours
