Topic: Arduino Simulator Open Source in c++ using free CPP Dev Compiler (Read 68519 times) previous topic - next topic
vbnewcomer
So simulIDE works with creating circuit and load firmware or just arduino .ino file ? i'm unable to download paulware ...
Paulware8
#16
Feb 13, 2013, 03:47 am Last Edit: May 16, 2013, 11:18 am by Paulware Reason: 1
My apologize.  I corrected my name spelling.  The repo is located: https://github.com/Paulware/ArduinoDebugger
(I wasn't sure if anyone was actually checking).
I removed ArduinoBasic...that will simplify it slightly.
Paulware8
#17
May 16, 2013, 05:39 am Last Edit: May 16, 2013, 11:18 am by Paulware Reason: 1
Updated Simulator to include 3 digit 7 segment display.
Github repository has moved to: https://github.com/Paulware/ArduinoDebugger/
Each project inside the simulator has its own dedicated sketch.
New Video posted to http://www.youtube.com/watch?v=_W_GPd936jg&feature=youtu.be to demo the 3 digit / 7 segment module
Paulware8
#18
Jun 05, 2013, 03:13 am Last Edit: Jun 05, 2013, 02:00 pm by Paulware Reason: 1
Paulware8
Added a shift register project.  I only takes me a couple days now to add a new component.  If you have any suggestions please let me know.  Thanks
ForestCat
I know this thread is pretty old, but I hope you're still involved with the simulator.  What version of Dev-C++ did you use to compile it?  I need a 32 bit executable, but I'm getting tons of errors with the latest version of Dev-C++, even if I rename your folder as it is referenced in the makefile paths.  What do I need to do to compile this under win7-32 or winXP-32 beyond loading the included .dev file?
Thanks.
