Pages: [1] 2   Go Down
Author Topic: Arduino Simulator Open Source in c++ using free CPP Dev Compiler  (Read 14045 times)
This is becoming an awesome free product
« Last Edit: December 16, 2012, 09:18:14 pm by Paulware » Logged
Topsham, Vermont USA
... in The Woods In Vermont
Where IS this?
What help do you need?
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
Location is https://github.com/Paulware/ArduinoDebugger/.
Help is no longer needed.  I will add new components to this as time allows
« Last Edit: May 16, 2013, 04:21:34 am by Paulware » Logged
I need your help to make this an awesome free product
gcc is free- why do you need to use a different compiler?
CPP DEV is also free.... CPP DEV comes with an IDE.
From the blood shed website (http://www.bloodshed.net/devcpp.html):
"Bloodshed Dev-C++ is a full-featured Integrated Development Environment (IDE) for the C/C++ programming language. It uses Mingw port of GCC (GNU Compiler Collection) as it's compiler. Dev-C++ can also be used in combination with Cygwin or any other GCC based compiler"
« Last Edit: May 16, 2013, 04:22:16 am by Paulware » Logged
Added lcdDisplay, used my Arduino BASIC language to test it.
here is a short video
« Last Edit: November 20, 2012, 12:23:35 am by Paulware » Logged
The free cpp compiler that was used to build this project can be downloaded from
  http://sourceforge.net/projects/orwelldevcpp/
Last Tested on Windows OS:
  Windows 8
Last Tested with Arduino version
  1.0.2
Github Repository:
« Last Edit: May 16, 2013, 04:22:55 am by Paulware » Logged
Central MN, USA
Looks cool. I will have to complain the "LED without current-limiting resistor" smiley
Central MN, USA
Can't find serialBasic.ino and a few other files. Where are they located? Thanks.
Many thanks for checking the source.  I removed the dependency on SerialBasic.ino and added an example.ino to the default directory.
Created a new video to show lcdDisplay and components can now be connected by clicking on the ports.
Still far to go....Let me know if there are any components you would like to add.
Here is some info:
Simulator Github Repository:
Arduino Libraries used:
  Arduino Basic from Git Hub repository
  Various libraries mocked in libraries directory like LiquidCrystal
Online videos that demonstrate usage:
  http://www.youtube.com/watch?v=AdZ5GbDC1h0&feature=youtu.be
  http://www.youtube.com/watch?v=laa9VnRzuT0&feature=youtu.be
Last Tested 12/6/2012 on Windows OS:
  Windows 8
  1.0.2
Here is the new video:
« Last Edit: May 16, 2013, 04:23:50 am by Paulware » Logged
Cordoba
run over linux or only under windows?
El que pregunta aprende, el que responde aprende a responder.
I use a gcc compiler, but I also handle a bunch of WM message in main.cpp.  Take a look and let me know.
I haven't tried in Linux.  That could be a nice addition assuming it is not too much work.
Interesting project, have you seen the SimulIDE?
Video:
Website: http://sourceforge.net/projects/simulide/
Forum: http://arduino.cc/forum/index.php/topic,105209.0.html
« Last Edit: December 09, 2012, 06:25:46 am by Boopidoo » Logged
   The point of mine is that you can set a breakpoint in your sketch and debug the behavior.
   I added 10k resistor as a component and ability to delete components (place mouse over component and press delete).
   Added keypad
« Last Edit: May 16, 2013, 04:26:09 am by Paulware » Logged
Added a video.  This one uses keypad and lcd display together.
http://www.youtube.com/watch?v=42XPmHdkE8k&feature=youtu.be
Pages: [1] 2   Go Up
