Pages: 1 2 [3] 4   Go Down
Author Topic: Importing a large lookup table  (Read 800 times)
ONE file, separate from the sketch itself, containing all my data.
That's not the point.
Your approach wouldn't work if multiple files make wants to reference the data in "numbers.hh".
Maryland, USA
Sorry, that I didn't understand.
Once I have my data in an array, I can reference that in the sketch, I won't need to reference "numbers.hh" anymore.
There are three kind of people in the world: Those who can count, and those who can't
Melbourne, Australia
Shannon Member
Lua rocks!
"mydata.hh" on disk is 30 bytes long.
"numbers.hh"on disk is 9 bytes long.
Your idea of "large" and mine must differ.
France
Scientia potentia est.
It was probably a small test file just to demonstrate the problem... smiley
Maryland, USA
Indeed smiley
I made up a couple of quick text files, one with strings, the other with integers, to see if I could make the darn thing work!
And when I finally made it to work (again, I did not do anything different from last night, today it just worked) it also works with the "real" thing.
It turns out that I was able to reduce the actual table, by organizing the data in a different way to a mere 400 bytes or so, well below the RAM restrictions.
Small size still, probably by your (and my) standards. smiley-razz
Shannon Member
Lua rocks!
You might be able to put the table into PROGMEM to minimize your RAM usage.
Also, the compiler tries to not compile things it doesn't think have changed. I'm not sure, but it's possible that if you change the .h file it won't realize to recompile the .cpp file. In other words, if you change the numbers but not the sketch.
I don't like #includes in the middle of a declaration, personally. Why not just put the whole array into a separate file (including the declaration, and the trailing brace)?
Maryland, USA
I thought of doing something like that but I don't know how to do it  smiley-roll-sweat
Even thought of creating a "Library" but when I consulted the reference on how to do that I thought it was a bit of an overkill for my purpose.
Also, my way (well, the one I learned form a c++ forum) does not require two files (.h and .cpp) but just one: .hh  (and by the way, I have no clue of the meaning of the .hh extension ....) which would seem to me more practical.
But again, I don't have much experience and I would not be surprised if there were a better way. smiley
Come to think of it, is the .h and .cpp business the same as creating a library?
Shannon Member
Lua rocks!
Just put all the stuff in a separate .h file, eg. from my bootloader project:
byte PROGMEM atmega328_optiboot [] = {
0x11, 0x24, 0x84, 0xB7, 0x14, 0xBE, 0x81, 0xFF, 0xF0, 0xD0, 0x85, 0xE0, 0x80, 0x93, 0x81, 0x00,
... blah blah ...
0xFF, 0x27, 0x09, 0x94, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x04, 0x04,
};  // end of atmega328_optiboot
I posted an example for you earlier.
You should never declare a variable in a .h file - that's so un-c that it will get you fired in most places. Declaring a variable in .h files creates localized global variables at each inclusion of those .h files.
Instead, declare the variable in the .c file and if such variables are to be referenced somewhere else, "extern" such variables.
Maryland, USA
@Nick
So, if I understand correctly:
In a separate file called mydata.h  I put:
const int data [] [2] = {
     {1,2},
     {3,4},
     {5,6},
// and so on...
(assuming it's small enough to fit in RAM)
And then in the main sketch I put:
#include "mydata.h" ;
Is it that simple?
That would have the additional advantage that I can put several arrays in the same file (if I need them) and just use an #include in the main sketch.
What about the mentioned extra .cpp file?
« Last Edit: November 21, 2012, 04:40:57 pm by Thot » Logged
Maryland, USA
Yes, thank you. I saw your earlier post but I did not fully understand that, sorry smiley
So, the example I just asked Nick about is not correct because I AM declaring the variable in an .h file?
Thanks
P.s. I'm glad I am not a programmer, finding a job these days is a pain ....
« Last Edit: November 21, 2012, 04:41:29 pm by Thot » Logged
Shannon Member
Lua rocks!
dhenry has got a point, however his suggested change has its own issues.
Let's make an example.
Sketch:
void setup ()
  Serial.begin (115200);
  Serial.println (data [0] [0]);
  }  // end of setup
void loop ()  {  }
foo.cpp:
     {1,2},
     {3,4},
     {5,6},
// and so on...
Error:
sketch_nov22a.cpp: In function 'void setup()':
sketch_nov22a:5: error: 'data' was not declared in this scope
So the variable "data" exists, the sketch just doesn't know about it.
So we add an "extern" to the main sketch:
extern const int data [] [2];
void setup ()
  }  // end of setup
void loop ()
  }  // end of loop
Still an error:
sketch_nov22a.cpp.o: In function `setup':
sketch_nov22a.cpp:10: undefined reference to `data'
Different error (a linker error, not a compiler error).
The problem is that "const" data is not exported. So remove the word "const" from both files, and it compiles.
But now we ask ourselves, "how big is data"? Well if it was declared in the same file, we can find that out with sizeof. A helpful macro does that:
extern int data [] [2];
// number of items in an array
#define NUMITEMS(arg) ((unsigned int) (sizeof (arg) / sizeof (arg [0])))
void setup ()
  for (int i = 0; i < NUMITEMS (data); i++)
    Serial.println (data [i] [0]);
  }  // end of setup
void loop () { }
Unfortunately the compiler doesn't know how big data is, because it is in a different file, hence:
sketch_nov22a:10: error: invalid application of 'sizeof' to incomplete type 'int [][2]'
If we make the extern an explicit size it will compile:
extern int data [3] [2];
void setup ()
  }  // end of setup
void loop () { }
But we have to keep the "extern" in step with the actual variable size in the other (.cpp) file.
Shannon Member
Lua rocks!
@dhenry: In my particular example, I think the use of the .h file is OK. It works around the issue I described (not knowing the variable size) and in this case the include files were only included once. Plus, I won't be firing myself. smiley-wink
So here is how it works in your case:
numbers2.h (you can name it whatever you want, as long as it is consistent)
//hearder file for data[]
//to be included in user code
extern const int data[] [2];
numbers2.c
#include "numbers2.h"
const int data[] [2]={
    {1,1},
  {-2,4},
  {3,-9},
  {4,5}, // Second element here will be 0, Like:  {4,0},
  {-5,-25}
Your user code: a simple reference to data[]
void setup(void) {
void loop(void) {
  unsigned char tmp;
  //an example of invoking data[];
  tmp+=data[0][(tmp & 0x01)?1:0];
numbers2.h can be referenced as many times as you want.
This is fairly standard C.
Shannon Member
Lua rocks!
You haven't addressed the question: how do you know how big the array is?
Pages: 1 2 [3] 4   Go Up
