Loading...
Pages: [1]   Go Down
Author Topic: PS2 Mouse  (Read 815 times)
Offline Offline
Newbie
View Profile
Hello
I've a problem to connect the ps2 mouse to arduino. I've use the ps2-library directly from arduino.cc, use leonardo board and connected my asus usb-mouse to the arduinoboard(VCC= red, ground= black, green=clock(3), white = date(2)). I've tried with sevaral pins. When i use the mouse example from arduino.cc, it compiled but i haven't a result on the Serial-Monitor.
Can anybody help me? smiley-roll-sweat
Logged
Switzerland
Offline Offline
Faraday Member
View Profile
A USB mouse is NOT a PS/2 mouse. If you wanna connect a USB mouse, you have to use a USB host shield or an Arduino Due (which incorporates similar hardware).
Logged
Denmark
Offline Offline
Newbie
View Profile
I found out that some USB mouses are just a PS/2 mouse... Mostly the simple ones..
It doesnt seem like the one you got is a ps/2 mouse so you need the usb host like pylon says.
Logged
Offline Offline
Newbie
View Profile
I've readed that this will be function in the Practical Arduino Book from Jonathan Oxer.
Is there a possibility to connect an USB mouse to Arduino? I've need this for my schoolproject. I will read with the optical mouse the position coordinates of may robo-car. Have everybody done this befor and can send me the sourcecode and library?
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
You can connect a usb mouse to a usb host shield. Libraries that support mice are provided.
http://www.circuitsathome.com/products-page/arduino-shields/usb-host-shield-2-0-for-arduino
Logged
Espoo, Finland
Offline Offline
God Member
"Oops, try again..."
View Profile
We are using PS/2 mouse to measure wheel rotation, and I don't see why typical USB-mouse wouldn't do that as well.
So, it's time to se the code....?
Cheers,
Kari
Logged
The only law for me; Ohms Law: U=R*I       P=U*I
Note to self: "Damn! Why don't you just fix it!!!"
Offline Offline
Newbie
View Profile
I've connected an old PS2-Mouse with a "ball" for tracking. And it works fine. But when I connect an Optical PS2-Mouse, I haven't a signal. I've debugged the code an saw that it hang up in de while loop:
 while (digitalRead(MCLK) == HIGH)
Anybody a solution?
Code:
 * an arduino sketch to interface with a ps/2 mouse.
 * Also uses serial protocol to talk back to the host
 * and report what it finds.
 * Pin 5 is the mouse data pin, pin 6 is the clock pin
 * Feel free to use whatever pins are convenient.
#define MDATA 5
#define MCLK 6
#define MOUSE_FULL_TURN 1510
#define MOUSE_CPI 384
int     lastMouseX, lastMouseY;
float   lastHead, lastDistance;
float   y_mou, x_mou;
float   dX, dY;
float   dHead;
float   heading_mou;
 * according to some code I saw, these functions will
 * correctly set the mouse clock and data pins for
 * various conditions.
void gohi(int pin)
  pinMode(pin, INPUT);
  digitalWrite(pin, HIGH);
void golo(int pin)
  pinMode(pin, OUTPUT);
  digitalWrite(pin, LOW);
void mouse_write(char data)
  char i;
  char parity = 1;
  //  Serial.print("Sending ");
  //  Serial.print(data, HEX);
  //  Serial.print(" to mouse\n");
  //  Serial.print("RTS");
  /* put pins in output mode */
  gohi(MDATA);
  gohi(MCLK);
  delayMicroseconds(300);
  golo(MCLK);
  golo(MDATA);
  delayMicroseconds(10);
  /* start bit */
  gohi(MCLK);
/* wait for mouse to take control of clock);  -----------------------------------------------------------------------------hang up in this loop*/
   /* clock is low, and we are clear to send data */
  for (i=0; i < 8; i++) {
    if (data & 0x01) {
      gohi(MDATA);
    else {
      golo(MDATA);
    /* wait for clock cycle */
    while (digitalRead(MCLK) == LOW)
    parity = parity ^ (data & 0x01);
    data = data >> 1;
  /* parity */
  if (parity) {
    gohi(MDATA);
  else {
    golo(MDATA);
  /* stop bit */
  gohi(MDATA);
  delayMicroseconds(50);
  /* wait for mouse to switch modes */
  while ((digitalRead(MCLK) == LOW) || (digitalRead(MDATA) == LOW))
  /* put a hold on the incoming data. */
  golo(MCLK);
  //  Serial.print("done.\n");
 * Get a byte of data from the mouse
char mouse_read(void)
  char data = 0x00;
  int i;
  char bit = 0x01;
  //  Serial.print("reading byte from mouse\n");
  /* start the clock */
  gohi(MCLK);
  gohi(MDATA);
  delayMicroseconds(5);  /* not sure why */
  while (digitalRead(MCLK) == LOW) /* eat start bit */
    if (digitalRead(MDATA) == HIGH) {
      data = data | bit;
    bit = bit << 1;
  /* eat parity bit, which we ignore */
  /* eat stop bit */
  golo(MCLK);
  //  Serial.print("Recvd data ");
  //  Serial.print(" from mouse\n");
  return data;
void mouse_init()
  gohi(MCLK);
  gohi(MDATA);
  //  Serial.print("Sending reset to mouse\n");
  mouse_write(0xff);
  mouse_read();  /* ack byte */
  //  Serial.print("Read ack byte1\n");
  mouse_read();  /* blank */
  //  Serial.print("Sending remote mode code\n");
  mouse_write(0xf0);  /* remote mode */
  mouse_read();  /* ack */
  //  Serial.print("Read ack byte2\n");
  delayMicroseconds(100);
  while (!Serial) { }
  //Serial.print("Initialization of Mouse");
  mouse_init();
 * get a reading from the mouse and report it back to the
 * host via the serial line.
  char mstat;
  int sensMouseX;
  int sensMouseY;
  float dPos;
  /* get a reading from the mouse */
  mouse_write(0xeb);  /* give me data! */
  mouse_read();      /* ignore ack */
  mstat = mouse_read();
  sensMouseX = (int)mouse_read();
  sensMouseY = (int)mouse_read();
  dX = sensMouseX - lastMouseX;
  dHead = dX * 360.0 / MOUSE_FULL_TURN;
  heading_mou += dHead;
  lastHead += dHead;
  while (heading_mou>=359)
    heading_mou-= 360.0;
  while (heading_mou<0)
    heading_mou+= 360.0;
  dY = sensMouseY - lastMouseY;
  lastDistance += dY * 25.4 / MOUSE_CPI;
  dPos = dY * cos(heading_mou * PI/180) * 25.4 / MOUSE_CPI;
  y_mou += dPos;
  dPos = dY * sin(heading_mou * PI/180) * 25.4 / MOUSE_CPI;
  x_mou += dPos;
  /* send the data back up */
  //Serial.print("Heading=");
  //Serial.print(lastHead, DEC);
  Serial.print("\tDistance=");
  Serial.print(lastDistance, DEC);
  //Serial.print(mstat, BIN);
  Serial.print("X=");
  Serial.print(dX, DEC);
  Serial.print("\tY=");
  Serial.print(dY, DEC);
  delay(20);  /* twiddle */
« Last Edit: November 17, 2012, 08:50:48 am by marco131 » Logged
Pages: [1]   Go Up
Print
Jump to:
