Offline
Newbie
« on: November 16, 2012, 10:49:14 am » |
Hi.
I am learning Arduino. I have read the analogWrite actually uses a digital signal, via the PWM technique.
I also read that is good enough for dimming LED's, controlling motors, generating audio...a lot of things, after all.
My question is, what are the main things you can't achieve with PWM, but you definitely need DAC instead? I am asking in general, but also particularly in the Arduino/microcontrollers arena.
Thanks, Dan
Logged
Global Moderator
Boston area, metrowest
Offline
Brattain Member
Available for Design & Build services
« Reply #1 on: November 16, 2012, 11:12:46 am » |
With PWM, you have an oscillating signal that you filter with a low pass filter to smooth into a ripply level. With a DAC, you are basically writing the level you want and it stays there until you write again. You can have dual and quad DACs with higher resolution than the 8 bits offered with PWM, easily accessed with fast I2C or even faster SPI commands. Its also possible to create more complex waveforms if desired, such as playback of sampled files from memory.
Logged
Offline
Newbie
« Reply #2 on: November 16, 2012, 11:17:44 am » |
Very interesting, CrossRoads - thanks a lot.
Is the "low pass filter" you were talking about integrated into the microcontroller or is it something I should take care of?
Dan
Logged
Global Moderator
Offline
Brattain Member
« Reply #3 on: November 16, 2012, 11:29:29 am » |
low pass filter is external, just a resistor/capacitor. there are lots of calculator websites, for example http://www.electronics-tutorials.ws/filter/filter_2.htmlPWM switches ~490 Hz, so pick values to filter out frequencies above that.
Logged
Valencia, Spain
Offline
Edison Member
« Reply #4 on: November 16, 2012, 11:39:49 am » |
In general? Not much. In Arduino terms? Quite a lot. Arduino has quite a limited PWM frequency/resolution. eg. You can't do high quality audio output.
Logged
Offline
Edison Member
« Reply #5 on: November 16, 2012, 11:45:42 am » |
My question is, what are the main things you can't achieve with PWM, but you definitely need DAC instead? I am asking in general, but also particularly in the Arduino/microcontrollers arena. To generate low frequency analog output; to generate fine analog output; to generate fast analog output; etc.
Logged
Offline
Edison Member
« Reply #6 on: November 16, 2012, 11:49:25 am » |
The flip of the coin is also true: there are cases where pwm is much preferred over dac.
Both are very application specific.
Logged
Left Coast, CA (USA)
Offline
Brattain Member
Measurement changes behavior
« Reply #7 on: November 16, 2012, 12:53:43 pm » |
My question is, what are the main things you can't achieve with PWM, but you definitely need DAC instead? I am asking in general, but also particularly in the Arduino/microcontrollers arena. Well I pose a question to your. If one wires a PWM signal to a digital voltmeter what would it read at 50% output? If you have a DAC that outputs 0-+5vdc what will the same voltmeter display with a 50% signal? There lies the difference and should point to applications best suited for one or the other. Lefty
« Last Edit: November 16, 2012, 12:59:56 pm by retrolefty »
Logged
Valencia, Spain
Offline
Edison Member
« Reply #8 on: November 16, 2012, 01:12:42 pm » |
My question is, what are the main things you can't achieve with PWM, but you definitely need DAC instead? I am asking in general, but also particularly in the Arduino/microcontrollers arena. To generate low frequency analog output; to generate fine analog output; to generate fast analog output; etc. I guess all those "1-bit-DAC" CD players are a figment of my imagination....
Logged
Global Moderator
Offline
Brattain Member
« Reply #9 on: November 16, 2012, 01:19:44 pm » |
From wikipedia: "A Bitstream or 1-bit DAC is a consumer electronics marketing term describing an oversampling digital-to-analog converter (DAC) with an actual 1-bit DAC (that is, a simple "on/off" switch) in a delta-sigma loop operating at multiples of the sampling frequency. The combination is equivalent to a DAC with a larger number of bits (usually 16-20). The advantages of this type of converter are high linearity combined with low cost, owed to the fact that most of the processing takes place in the digital domain and requirements for the analog anti-aliasing filter after the output can be relaxed. For these reasons, this design is very popular in digital consumer electronics (CD/DVD players, set-top boxes and the like)." So not sure what you are trying to point out fungus. Found another good description here http://electronics.howstuffworks.com/question620.htm
« Last Edit: November 16, 2012, 01:22:54 pm by CrossRoads »
Logged
Valencia, Spain
Offline
Edison Member
« Reply #10 on: November 16, 2012, 01:48:03 pm » |
1-bit-DAC is an example of using PWM to generate analog signals in consumer electronics. It does all that stuff he claims can't be done ("low frequency analog output; fine analog output; fast analog output; etc"). It may not be practical for all applications but in theory PWM+filter can do anything an DAC can do.
Logged
Samplefinger
Offline
God Member
ALWAYS ASK FOR THREE. One to use. One to lose. One to abuse.
« Reply #11 on: November 16, 2012, 02:39:01 pm » |
Damn, how does TI get away with selling their expensive DACs then? http://www.ti.com/docs/prod/folders/print/dac5670.html
Logged
Latest Sampling Scores: ATXMEGA64A3U-MH x3, ATXMEGA256A3U-MH x3, SST38VF6404-90-5C-EKE x3, SST38VF6402-90-5C-EKE x3, PGA870 x3, THS770006 x3
Global Moderator
Offline
Brattain Member
« Reply #12 on: November 16, 2012, 02:57:47 pm » |
Gotta take the guy mentality for that one: more bits/seconds more power more balls!
Gues it helps to have a higher power uP also to send it data that fast.
Features
14-Bit Resolution 2.4-GSPS Maximum Update Rate Digital to Analog Converter
Power Dissipation: 2 W 252-Ball GDJ Package
APPLICATIONS Satellite Communications
Logged
Valencia, Spain
Offline
Edison Member
« Reply #13 on: November 16, 2012, 03:14:31 pm » |
When I say "in theory" it means there's practical limits... eg. 1.2Gsps output with 14-bit resolution would need a 20 terahertz PWM clock
Logged
Samplefinger
Offline
God Member
« Reply #14 on: November 16, 2012, 03:17:21 pm » |
Guess it helps to have a higher power uP also to send it data that fast.
I think we would be well into (multiple?) CPLD/FPGA territory on that DAC. Certainly a (relatively) slow but smart uP to direct all the action of the heavy equipment.
« Last Edit: November 16, 2012, 03:19:42 pm by JoeN »
Logged
