Spain
« on: November 16, 2012, 01:19:01 pm » |
Hi, I am making a code to save data in a SD card from sensors of air flow and temperature (DS18B20), It´s all right, but when I save data in an excel document, It don´t saves the hour correctly in every samples.......For example: in the menu of the program, I put 5 seconds of delay between samples and I begin to save data at 19:00:00, it continues with 19:00:05 19:00:10 19:00:15 19:00:20 19:00:25 19:00:31. I can say with this that in a X number of samples (which varies) It has a sample with a delay of one second. I tried a lot of methods, but I can´t look the answer. I'm 5 days with this problem, and Its making me crazy  . Can anyone help me please?. I put a part of the code where its the problem (its a part of the while loop-I'm using wire and SD libraries). Wire.beginTransmission(DS1307_ADDRESS); Wire.write(zero); Wire.endTransmission(); Wire.requestFrom(DS1307_ADDRESS, 7); int second = bcdToDec(Wire.read()); int minute = bcdToDec(Wire.read()); int hour = bcdToDec(Wire.read() & 0b111111); //24 horas int weekDay = bcdToDec(Wire.read()); //0-6 -> Domingo-sabado int monthDay = bcdToDec(Wire.read()); int month = bcdToDec(Wire.read()); int year = bcdToDec(Wire.read());
unsigned long currentTime = 3600*hour+60*minute+second; if (currentTime >= lastReadTime + refresh_rate) { File logFile = SD.open("LOG.csv", FILE_WRITE); logFile.print(monthDay); logFile.print("/"); logFile.print(month); logFile.print("/"); logFile.print(year); logFile.print(" - "); logFile.print(hour); logFile.print(":"); logFile.print(minute); logFile.print(":"); logFile.print(second); logFile.print(",");//Separador de columna
DATA TO SAVE
logFile.close(); lastReadTime = 3600*hour+60*minute+second; }
Thanks for your help
Switzerland
« Reply #1 on: November 16, 2012, 01:56:38 pm » |
Have you read the sticky not at the top of this forum?
You should post your full code, else you just waste our time guessing what the rest may be. My guess here is: you have an unnecessary delay() somewhere in your code.
Spain
« Reply #2 on: November 16, 2012, 02:20:31 pm » |
At first: Thanks for your answer. My code has about 1500 lines.......I didn´t post it because it would made harder to help me (menus, etc....). I took a look if I see any unnecesary delay, and I think that it hasn´t, other thing that makes me to think is that this delay sometimes is each 7-8 samples, sometimes is each 70 samples (its irregular). If you don´t see any error in this part of code, I´ll post the rest of it....But if I said before, it will be difficult for its length. Thanks!
Seattle, WA USA
Seattle, WA USA
« Reply #3 on: November 16, 2012, 04:56:20 pm » |
if (currentTime >= lastReadTime + refresh_rate) { You shouldn't be adding time values. That can cause problems if the values roll over. Only subtraction is guaranteed to work. With 1500 lines of code, why do you expect to hit EVERY second on the mark? Opening and closing files takes time. Writing to files takes time. unsigned long currentTime = 3600*hour+60*minute+second; lastReadTime = 3600*hour+60*minute+second; Between those two assignments, lots of time has ticked away.
Spain
« Reply #4 on: November 17, 2012, 10:17:07 am » |
Thank you too PaulS. I took your advices, I tried the substraction in the code and it runs a few better than before.....but I see trhat this part is uncorrect: unsigned long currentTime = 3600*hour+60*minute+second; lastReadTime = 3600*hour+60*minute+second;
If the day changes at 00h, this would cause a problem!! This datalogger must to run for a few days. If anyone knows any example of a datalogger that can help me to save data each predefined time, please post it!
When I finish my code completly, I would post it.....but I think that now is unnecesary, because it has a lot of menus, submenus and other parts unfinished, and it may cause problems to other users. Thank you to everyone!!
Spain
« Reply #5 on: November 20, 2012, 02:06:20 pm » |
I partially solved the problem using UNIX time, but now, the delay is being existing yet  Anyone knows how to store the time with precission (using more variables or something like this)??? I tried a lot of methods, but the best option is the next....(I must to repeat that I don´t copy all code, because it has 1500 lines of length. But if you need it, I´ll post it. Thank you to everyone DateTime now = RTC.now(); //Para obtener el tiempo unix unsigned long currentTime = now.unixtime();//Obtiene el tiempo UNIX para el tiempo de refresco unicamente if (currentTime -lastReadTime >= refresh_rate) { File logFile = SD.open("LOG.txt", O_CREAT | O_WRITE);//O_CREAT | O_WRITE puede cambiarse por FILE_WRITE lastReadTime = currentTime; logFile.print(monthDay); logFile.print("/"); logFile.print(month); logFile.print("/"); logFile.print(year); logFile.print(" - "); logFile.print(hour); logFile.print(":"); logFile.print(minute); logFile.print(":"); logFile.print(second); logFile.print(",");//Separador de columna for (int l=0; l<numSensoresT; l++) { logFile.print(temparray[l]); if (l < numSensoresT-1) { logFile.print(","); } else { logFile.println(); } } logFile.close(); }
Switzerland
« Reply #6 on: November 20, 2012, 02:16:25 pm » |
Can you describe what your problem is?
Your code logs the sensor values every refresh_rate seconds. What do you expect it to do?
Spain
« Reply #7 on: November 20, 2012, 02:36:48 pm » |
At first, thank you for your fast answer pylon....My problem is the precission: When I put a refresh time It takes samples good and makes a timestamp that seems good, but when it has 30-150 samples (it depends, and its aleatory-I think), the timestamp goes 1 second after, as I describe in my first post, for example if the sample rate is 30 seconds and begins in second 00: the routine is 00 30 00 30 00 [....]30 00 31. It may be a solution for this (this is an end of studies project, for the university, and I wish to do it perfect). Thank you
Switzerland
« Reply #8 on: November 21, 2012, 04:46:21 am » |
If this is still the case even for the code above, your problem is in the main code not in the posted part of it. Meaning you have to post the full code to enable us to find the bug.
My guess is that your main loop is run only once a second. Then this kind of time slip is possible and probable after some time.
Spain
« Reply #9 on: November 21, 2012, 10:24:07 am » |
First of all....Thank you very much for your answer pylon...I´ll post the code now....But before this, I must to explain various things of my code (for best understanding):
-The first thing is that I´m relatively newbie in this kind of programming languaje, and Im sure that you will see a lot of bugs of other parts of the program. -This project is a part of my end studies project (Naval Engineering), this instrument will log temperatures, air flows and other parameters to study the efficiency of a marine instalation (i´ll do some studies too-when I finish this instrument) -This instrument-At the moment has programmed a Nokia 5110LCD, a keypad (for configure parameters, and configurations like number of sensors or the date or time in the DS1307 RTC, an SD card to save data, and temperature sensors DS18B20). -The menus (and there are a lot) are incompleted, only run the things I have configured at the moment. -the code is messy, so I order it when finished all. -This is an example what I got in an excel:
Fecha y hora T1 T2 T3 T4 T5 21/11/12 - 5:37:3 18.12 18.31 18.50 18.19 18.19 21/11/12 - 5:52:3 18.31 18.56 18.69 18.44 18.50 21/11/12 - 6:7:3 18.19 18.50 18.62 18.44 18.37 21/11/12 - 6:22:3 18.19 18.44 18.56 18.31 18.31 21/11/12 - 6:37:3 18.12 18.31 18.50 18.31 18.25 21/11/12 - 6:52:3 18.06 18.31 18.44 18.25 18.25 21/11/12 - 7:7:3 18.00 18.25 18.44 18.19 18.19 21/11/12 - 7:22:4 18.06 18.31 18.37 18.19 18.19 21/11/12 - 7:37:4 18.00 18.25 18.31 18.12 18.12 21/11/12 - 7:52:4 18.00 18.19 18.31 18.12 18.12 21/11/12 - 8:7:4 17.94 18.19 18.31 18.12 18.06 21/11/12 - 8:22:4 17.87 18.19 18.25 18.06 18.06 21/11/12 - 8:37:5 17.94 18.12 18.25 18.06 18.06 21/11/12 - 8:52:5 17.87 18.06 18.25 18.06 18.00 21/11/12 - 9:7:5 17.87 18.12 18.19 18.00 18.00 21/11/12 - 9:22:5 17.87 18.06 18.19 18.00 17.94 21/11/12 - 9:37:5 17.81 18.06 18.19 17.94 17.94 21/11/12 - 9:52:5 17.81 18.06 18.12 18.00 17.94 21/11/12 - 10:7:5 17.81 18.00 18.12 17.94 17.94 21/11/12 - 10:22:5 17.81 18.00 18.12 17.94 17.94 21/11/12 - 10:37:5 17.75 18.00 18.12 17.94 17.87 21/11/12 - 10:52:5 17.75 18.00 18.06 17.94 17.87 21/11/12 - 11:7:6 17.75 17.94 18.06 17.94 17.87 21/11/12 - 11:22:6 17.75 17.94 18.06 17.87 17.87 21/11/12 - 11:37:6 17.69 17.94 18.06 17.87 17.87 21/11/12 - 11:52:6 17.69 17.94 18.06 17.87 17.87 21/11/12 - 12:7:6 17.69 17.94 18.00 17.87 17.81 21/11/12 - 12:22:7 17.69 17.94 18.00 17.87 17.81 21/11/12 - 12:37:7 17.69 17.87 18.00 17.81 17.81 21/11/12 - 12:52:7 17.62 17.94 18.00 17.81 17.81 21/11/12 - 13:7:7 17.69 17.87 18.00 17.81 17.81 21/11/12 - 13:22:7 17.62 17.87 18.00 17.81 17.81 21/11/12 - 13:37:7 17.37 17.56 17.62 17.44 17.44 21/11/12 - 13:52:7 17.31 17.50 17.56 17.44 17.44 21/11/12 - 14:7:7 17.50 17.75 17.87 17.69 17.69 21/11/12 - 14:22:7 17.62 17.87 18.00 17.81 17.81 21/11/12 - 14:37:7 17.62 17.87 18.00 17.81 17.81
At the next post I´ll put the code.
Spain
« Reply #10 on: November 21, 2012, 10:28:13 am » |
/*Desarrollado a partir de Datalogger de la libreria SD, Keypad, LCD5110 Graph y del script de 18B20*/
#include <SD.h> #include <OneWire.h> #include <DallasTemperature.h> #include <LCD5110_Graph.h> #include <Keypad.h>
//--------------DS1307-------- #include "Wire.h" #include "RTClib.h"//Para poder obtener adecuadamente UNIXtime #define DS1307_ADDRESS 0x68 byte zero = 0x00; //workaround for issue #527
RTC_DS1307 RTC;//Va acorde a RTClib.h
unsigned long s;//Segundos reloj unsigned long mi;//Minutos reloj unsigned long h;//Horas reloj unsigned long ds;//Dia semana reloj unsigned long dm;//Dia mes reloj unsigned long me;//Mes reloj unsigned long a;//A帽o reloj
char fechahora='0';//A-Correctos/B-Incorrectos //------------------------------
//Keypad const byte ROWS = 4; //cuatro filas const byte COLS = 4; //cuatro columnas
char keys[ROWS][COLS] = { {'1','2','3','A'}, {'4','5','6','B'}, {'7','8','9','C'}, {'*','0','#','D'} }; byte rowPins[ROWS] = {6,7,8,9}; byte colPins[COLS] = {2,3,4,5};
//Dataloger Refresh Rate unsigned long lastReadTime=0; unsigned long refresh_rate = 0; unsigned long currentTime=0; unsigned long num = 0; unsigned long numQ = 0;//Funcion de sensores de caudal (Definicion) unsigned long t=0; unsigned long numSensoresQ=0; unsigned long numSensoresT=0;
char menu='0'; char menu1='A'; char menu2='A'; char menu3='A'; char menu4='A'; char menu5='A'; char menulog='A'; int pantallazo=0;
char unidad='0';
int numero=0;
int w = 0; //Contador DS18B20
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
//LCD LCD5110 myGLCD(45,46,47,48,49); extern uint8_t unican[]; extern uint8_t helice[]; extern uint8_t helice2[]; extern uint8_t helice3[]; extern uint8_t flecha[]; extern uint8_t borraflecha[];
extern uint8_t SmallFont[];
uint8_t* bm;
//Define puerto 18B20s #define ONE_WIRE_BUS 11 #define TEMPERATURE_PRECISION 12 //resoluci贸n de los sensores en bits
OneWire oneWire(ONE_WIRE_BUS); DallasTemperature sensors(&oneWire);
//SPI SD Card Pins //MOSI = Pin 11 //MISO = Pin 12 //SCLK = PIN 13 int CS_pin = 43; int pow_pin = 8;
void setup() { Serial.begin(9600);
Wire.begin(); //Wire---DS1307 RTC
RTC.begin();
sensors.begin();//Inicializa sensores 18B20 int numSensoresT = sensors.getDeviceCount(); // Numero de sensores int temparray[numSensoresT]; // Array que almacena un array con el numero de sensores
//--------------------------------------------------------LCD-------------------------------------------------------------------- myGLCD.InitLCD(); myGLCD.setFont(SmallFont); myGLCD.clrScr(); myGLCD.drawBitmap(0, 0, unican, 84, 48); myGLCD.update();
delay(2000); myGLCD.clrScr(); myGLCD.drawBitmap(0, 0, helice, 84, 48); myGLCD.update(); delay(250); myGLCD.clrScr(); myGLCD.drawBitmap(0, 0, helice2, 84, 48); myGLCD.update(); delay(250); myGLCD.clrScr(); myGLCD.drawBitmap(0, 0, helice3, 84, 48); myGLCD.update(); delay(250);
Spain
« Reply #11 on: November 21, 2012, 10:28:48 am » |
//Inicializa SD myGLCD.clrScr(); myGLCD.print("Inicializando",CENTER, 10); myGLCD.print("Tarjeta SD",CENTER, 20); myGLCD.update(); delay(1500); //CS Pin Salida pinMode(CS_pin, OUTPUT); //SD toma tension del pin 8, por lo q es HIGH pinMode(pow_pin, OUTPUT); digitalWrite(pow_pin, HIGH); //inicializa tarjeta SD if (!SD.begin(CS_pin)) { myGLCD.clrScr(); myGLCD.print("Fallo de SD",CENTER, 10); myGLCD.update(); delay(1500); } else { myGLCD.clrScr(); myGLCD.print("Tarjeta SD",CENTER, 10); myGLCD.print("lista",CENTER, 20); myGLCD.update(); delay(1500); }
unsigned long Defineletra(){ char key = kpd.getKey(); while(key != '#') { switch (key) { case NO_KEY: break;
case 'A': menu=key; break; case 'B': menu=key; break; case 'C': menu=key; menulog='A'; pantallazo =0; break; delay(1000); } key = kpd.getKey(); } return menu;
//Definicion unidades II unsigned long Defineletra1(){ char key = kpd.getKey(); while(key != '#') { switch (key) { case NO_KEY: break;
case 'A': menu1=key; break; case 'B': menu1=key; break; case 'C': menu1=key; break; case '0': menu1=key; menu='0'; break; delay(1000); } key = kpd.getKey(); } return menu1;
} //Definicion unidades II unsigned long Defineletra2(){ char key = kpd.getKey(); while(key != '#') { switch (key) { case NO_KEY: break;
case 'A': menu2=key; break; case 'B': menu2=key; break; case '0': menu2=key; menu='0'; break; delay(1000); } key = kpd.getKey(); } return menu2;
} //Definicion unidades II unsigned long Defineletra3(){ char key = kpd.getKey(); while(key != '#') { switch (key) { case NO_KEY: break;
case 'A': menu3=key; fechahora='0'; //Para que siempre aparezca la hora en este menu break; case 'B': menu3=key; break; case '0': menu3=key; menu ='A'; break; delay(1000); } key = kpd.getKey(); } return menu3;
} //Definicion unidades II unsigned long Defineletra4(){ char key = kpd.getKey(); while(key != '#') { switch (key) { case NO_KEY: break;
case 'A': menu4=key; break; case 'B': menu4=key; break; case '0': menu4=key; menu ='A'; break; delay(1000); } key = kpd.getKey(); } return menu4;
} //Definicion unidades II unsigned long Defineletra5(){ char key = kpd.getKey(); while(key != '#') { switch (key) { case NO_KEY: break;
case 'A': menu5=key; break; case 'B': menu5=key; break; case 'C': menu5=key; break; case 'D': menu5=key; break; delay(1000); } key = kpd.getKey(); } return menu5;
Spain
« Reply #12 on: November 21, 2012, 10:29:17 am » |
//Definicion unidades II unsigned long Defineletra7(){ char key = kpd.getKey(); while(key != '#') { switch (key) { case NO_KEY: break; case 'A': myGLCD.drawBitmap(62, 30, borraflecha, 8,  ;//Borra flecha en B myGLCD.drawBitmap(66, 40, borraflecha, 8,  ;//Borra flecha C myGLCD.drawBitmap(52, 20, flecha, 8,  ;//Dibuja flecha A myGLCD.update(); t=3600; break; case 'B': myGLCD.drawBitmap(52, 20, borraflecha, 8,  ;//Borra flecha A myGLCD.drawBitmap(66, 40, borraflecha, 8,  ;//Borra flecha C myGLCD.drawBitmap(62, 30, flecha, 8,  ;//Dibuja flecha en B myGLCD.update(); t=60; break; case 'C': myGLCD.drawBitmap(52, 20, borraflecha, 8,  ;//Borra flecha A myGLCD.drawBitmap(62, 30, borraflecha, 8,  ;//Borra flecha en B myGLCD.drawBitmap(66, 40, flecha, 8,  ;//Dibuja flecha C myGLCD.update(); t=1; break; delay(1000); } key = kpd.getKey(); } return t; } //numero unidades II unsigned long Definenumero() { unsigned long num = 0; char key = kpd.getKey(); while(key != '#') { switch (key) { case NO_KEY: break; case '0': case '1': case '2': case '3': case '4': case '5': case '6': case '7': case '8': case '9': num = num * 10 + (key - '0'); myGLCD.printNumI(num, 0, 30); myGLCD.update(); break; case '*': num = 0; myGLCD.update(); break; } key = kpd.getKey(); } return num; } //numero sensores de Caudal unsigned long DefinenumeroQ() { unsigned long numQ = 0; char key = kpd.getKey(); while(key != '#') { switch (key) { case NO_KEY: break; case '0': case '1': case '2': case '3': case '4': case '5': case '6': case '7': case '8': case '9': numQ = numQ * 10 + (key - '0'); myGLCD.printNumI(numQ, 0, 40); myGLCD.update(); break; case '*': numQ = 0; myGLCD.update(); break; } key = kpd.getKey(); } return numQ; } //DEfine fecha y hora unsigned long Definediasemana() { unsigned long ds = 0; char key = kpd.getKey(); while(key != '#') { switch (key) { case NO_KEY: break; case '0': case '1': case '2': case '3': case '4': case '5': case '6': case '7': case '8': case '9': ds = ds * 10 + (key - '0'); myGLCD.printNumI(ds, 0, 40); myGLCD.update(); break; case '*': ds = 0; myGLCD.update(); break; } key = kpd.getKey(); } return ds; } //DEfine fecha y hora unsigned long Definediames() { unsigned long dm = 0; char key = kpd.getKey(); while(key != '#') { switch (key) { case NO_KEY: break; case '0': case '1': case '2': case '3': case '4': case '5': case '6': case '7': case '8': case '9': dm = dm * 10 + (key - '0'); myGLCD.printNumI(dm, 0, 40); myGLCD.update(); break; case '*': dm = 0; myGLCD.update(); break; } key = kpd.getKey(); } return dm; } //DEfine fecha y hora unsigned long Definemes() { unsigned long me = 0; char key = kpd.getKey(); while(key != '#') { switch (key) { case NO_KEY: break; case '0': case '1': case '2': case '3': case '4': case '5': case '6': case '7': case '8': case '9': me = me * 10 + (key - '0'); myGLCD.printNumI(me, 0, 40); myGLCD.update(); break; case '*': me = 0; myGLCD.update(); break; } key = kpd.getKey(); } return me; } //DEfine fecha y hora unsigned long Defineano() { unsigned long a = 0; char key = kpd.getKey(); while(key != '#') { switch (key) { case NO_KEY: break; case '0': case '1': case '2': case '3': case '4': case '5': case '6': case '7': case '8': case '9': a = a * 10 + (key - '0'); myGLCD.printNumI(a, 0, 40); myGLCD.update(); break; case '*': a = 0; myGLCD.update(); break; } key = kpd.getKey(); } return a; }
Spain
« Reply #13 on: November 21, 2012, 10:29:46 am » |
//DEfine fecha y hora unsigned long Definehora() { unsigned long h = 0; char key = kpd.getKey(); while(key != '#') { switch (key) { case NO_KEY: break;
case '0': case '1': case '2': case '3': case '4': case '5': case '6': case '7': case '8': case '9': h = h * 10 + (key - '0'); myGLCD.printNumI(h, 0, 40); myGLCD.update(); break;
case '*': h = 0; myGLCD.update(); break; }
return h; }
//DEfine fecha y hora unsigned long Defineminutos() { unsigned long mi = 0; char key = kpd.getKey(); while(key != '#') { switch (key) { case NO_KEY: break;
case '0': case '1': case '2': case '3': case '4': case '5': case '6': case '7': case '8': case '9': mi = mi * 10 + (key - '0'); myGLCD.printNumI(mi, 0, 40); myGLCD.update(); break;
case '*': mi = 0; myGLCD.update(); break; }
return mi; }
//DEfine fecha y hora unsigned long Definesegundos() { unsigned long s = 0; char key = kpd.getKey(); while(key != '#') { switch (key) { case NO_KEY: break;
case '0': case '1': case '2': case '3': case '4': case '5': case '6': case '7': case '8': case '9': s = s * 10 + (key - '0'); myGLCD.printNumI(s, 0, 40); myGLCD.update(); break;
case '*': s = 0; myGLCD.update(); break; }
return s; }
//Definicion unidades II unsigned long Definefechahora(){ char key = kpd.getKey(); while(key != '#') { switch (key) { case NO_KEY: break;
case 'A': fechahora=key; break; case 'B': fechahora=key; break; delay(1000); } key = kpd.getKey(); } return fechahora;
unsigned long Definelog(){ char key = kpd.getKey(); while(key != '#') { switch (key) { case NO_KEY: break;
case 'A': menulog=key; break; case 'B': menulog=key; break; case 'C': menulog=key; break; case 'D': menulog=key; break; case '0': menulog=key; menu='0'; break; delay(1000); } key = kpd.getKey(); } return menulog;
//----------------------------------- void loop() { int numSensoresT = sensors.getDeviceCount(); float temparray[numSensoresT]; inicio: if (menu=='0') { myGLCD.clrScr(); myGLCD.print("-MENU-", CENTER, 0); myGLCD.drawLine(2,8,82,8); myGLCD.print("#: Confirmar", CENTER, 10); myGLCD.print("A: Config", 0, 20); myGLCD.print("B: SD", 0, 30); myGLCD.print("C: Datos", 0, 40); myGLCD.update(); char menu=Defineletra(); } else if (menu =='A') { myGLCD.clrScr(); myGLCD.print("CONFIGURACION", CENTER, 0); myGLCD.drawLine(2,8,82,8); myGLCD.print("A:Tiempo", 0, 10); myGLCD.print("B: Sensores", 0, 20); myGLCD.print("C: Unidades", 0, 30); myGLCD.print("0: Volver", 0, 40); myGLCD.update(); char menu1=Defineletra1(); if (menu1=='A') {inicio3: myGLCD.clrScr(); myGLCD.print("-TIEMPO-", CENTER, 0); myGLCD.drawLine(2,8,82,8); myGLCD.print("A:Fecha/h", 0, 10); myGLCD.print("B: Periodo Log", 0, 20); myGLCD.print("0: Volver", 0, 30); myGLCD.update(); char menu3=Defineletra3(); if (menu3=='A') { while(fechahora=='0') { myGLCD.clrScr(); myGLCD.print("A:Correcto", 0, 0); myGLCD.print("B:Cambiar", 0, 10); verhora(); char fechahora=Definefechahora(); } while(fechahora=='A') { {goto inicio3;} } while(fechahora=='B') { ponerhora(); {goto inicio3;} } } else if (menu3=='B') { myGLCD.clrScr(); myGLCD.print("Definir unidad", 0, 0); myGLCD.print("y pulsar #", CENTER, 10); myGLCD.print("A: Horas", 0, 20); myGLCD.print("B: Minutos", 0, 30); myGLCD.print("C: Segundos", 0, 40); myGLCD.update(); char unidad=Defineletra7(); myGLCD.clrScr(); myGLCD.print("Numero unidades", 0, 0); myGLCD.print("#: Confirmar", 0, 10); myGLCD.print("*: Borrar", 0, 20); myGLCD.update(); unsigned long num = Definenumero(); numero = num; refresh_rate=(num*t); {goto inicio3;} } else if (menu3=='0') {goto inicio;} } else if (menu1=='B') { inicio4: myGLCD.clrScr(); myGLCD.print("SENSORES", 0, 0); myGLCD.drawLine(2,8,82,8); myGLCD.print("A:Temperatura", 0, 10); myGLCD.print("B: Caudal", 0, 20); myGLCD.print("0: Volver", 0, 30); myGLCD.update(); char menu4=Defineletra4();
Spain
« Reply #14 on: November 21, 2012, 10:30:19 am » |
if (menu4=='A') { myGLCD.clrScr(); myGLCD.print("Detectando", CENTER, 10); myGLCD.print("sensores", CENTER, 20); myGLCD.update(); delay(1000); myGLCD.clrScr(); myGLCD.print("SENSORES:", 4, 10); myGLCD.printNumI(numSensoresT, 58, 10); myGLCD.update(); delay (1000); {goto inicio4;} } else if (menu4=='B') { myGLCD.clrScr(); myGLCD.print("-CAUDAL-", CENTER, 0); myGLCD.print("Definir numero", CENTER, 10); myGLCD.print("de sensores", CENTER, 20); myGLCD.print("y pulsar #", CENTER, 30); myGLCD.update(); unsigned long numQ=DefinenumeroQ(); numSensoresQ=numQ; {goto inicio4;} } else if (menu4=='0') {goto inicio;} } else if (menu1=='0') {goto inicio;} }
else if (menu == 'B') {inicio2: myGLCD.clrScr(); myGLCD.print("TARJETA SD", CENTER, 0); myGLCD.drawLine(2,8,82,8); myGLCD.print("A:Formatear", 0, 10); myGLCD.print("B: Extraer", 0, 20); myGLCD.print("0: Volver", 0, 30); myGLCD.update(); char menu2=Defineletra2(); if (menu2=='0') {goto inicio;} } while (menu == 'C') { while (pantallazo == 0) { //Escritura del encabezado File logFile = SD.open("LOG.txt", FILE_WRITE); if (logFile) { logFile.println(", , , ,"); //Dejar linea en blanco, por si hay datos previos logFile.print("Fecha y hora"); logFile.print(","); for (int encabezado=0; encabezado<numSensoresT;encabezado++) // { logFile.print("T"); logFile.print(encabezado+1); if (encabezado < numSensoresT-1) { logFile.print(","); } else { logFile.println(); } } } else { myGLCD.clrScr(); myGLCD.print("Fallo de",CENTER, 10); myGLCD.print("tarjeta",CENTER, 20); myGLCD.print("SD",CENTER, 20); myGLCD.update(); delay(1500); } logFile.close(); delay(3000); myGLCD.clrScr(); myGLCD.print("PERIODO", 0, 0); myGLCD.printNumI(numero, 0, 10); if (t==3600) { myGLCD.print(" horas", 15, 10); } else if (t==60) { myGLCD.print("min.", 15, 10); } else if (t==1) { myGLCD.print("segs.", 15, 10); } else if(t==0) { myGLCD.print("ND", 15, 10); } myGLCD.drawLine(1,18,83,18); myGLCD.print("Sensores T:", 0, 21); myGLCD.printNumI(numSensoresT, 64, 21); myGLCD.print("Sensores Q:", 0, 31); myGLCD.printNumI(numSensoresQ, 64, 31); myGLCD.update(); delay(3000); myGLCD.clrScr(); myGLCD.print("0:STOP", 0, 0); myGLCD.print("A: Temp 1", 0, 10); myGLCD.print("B: Temp. 2", 0, 20); myGLCD.print("C: Caudales 1", 0, 30); myGLCD.print("D: Caudales 2", 0, 40); myGLCD.update(); delay(3000); pantallazo++; } sensors.requestTemperatures(); // Petici贸n de temperatura a todos los sensores for (w=0; w<numSensoresT; w++)//Para la creaci贸n del array de temperaturas { float temp = sensors.getTempCByIndex(w); //Toma la temperatura del sensor i y la almacena en la variable temp temparray[w] = (temp); }
ini: if (menulog == 'A'){ myGLCD.clrScr(); for (int j=0; j<numSensoresT;j++) // { int a=(10*j); myGLCD.print("T", 0, a); myGLCD.printNumI((j+1), 8 ,a); myGLCD.print(":", 20, a); myGLCD.printNumF(temparray[j], 3, 25 ,a); //El 3 se cambia segun precision requerida, Estoy usando 12 bits para el ds18b20-->0.0625潞C precision myGLCD.print("*C", 62, a);
} myGLCD.update(); }
