Loading...
Pages: [1]   Go Down
Author Topic: 8x8 LED Matrix und Atmega 168 PA PU extern  (Read 902 times)
Offline Offline
Newbie
View Profile
Hi.
Ich habe diese Woche angefangen mich mit dem Thema Multiplexing einer 8x8 LED Matrix auseinander zu setzen.
Soweit habe ich alles vorbereitet und bestellt.
Ich würde jetzt gerne meinen Atmega 168 PA PU nicht auf dem Arduino sitzen lassen sondern mit in die Schaltung einbauen.
Meine Suche über Pläne für die externe Beschaltung vom Atmega blieben erfolglos und deswegen wende ich mich jetzt ans Forum.
Mit freundlichen Grüßen,
Tholscha :-)
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Easy way: MAX7219
http://www.taydaelectronics.com/catalogsearch/result/?q=max7219
Hard way:
Connect 8 pins to anodes with 270 ohm current limit resistors.
Connect 8 Pins to cathodes
1 Anode  High, 1 Cathode Low ONLY for 1 LED on.
Viel Glück in Ihrem Experiment.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
Thanks, but this is not the answer for my problem....
My problem is the Atmega 168 on my Arduino.
I want my Atmega put out from de Arduino and than put in my Matrix.
I need now each components to operate outside my Atmega.
- Quarz
- Resistors
- etc......
my search at the internet was unsuccessful....
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
I get thousands of results: http://www.google.com/search?q=arduino+standalone
Logged
Offline Offline
Newbie
View Profile
Thx Fungus :-D
Does it matter which type I have?
Are all connected to the same?
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
168,328, connect the same way
Connection to MAX7219 varies if you SPI.transfer() commands to drive it, or LED library that is based on slower shiftout() t ype commands.
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
Thx Fungus :-D
http://www.akafugu.jp/images/microcontroller-reference-sheet.png
Logged
Offline Offline
Newbie
View Profile
thx CrossRoads & Fungus :-)
Logged
Offline Offline
Full Member
View Profile
Schau mal hier:
http://www.erik-bartmann.de/programmierung/downloads2.html?task=files.download&cid=19
Die Programmierschnittstelle kannst du ja weglassen.
Logged
10 Euro zu Gewinnen für dein DIY Tutorial: http://www.machzin.de
http://www.opensketches.org share your processing, fritzung and arduino sketches online! http://www.machzin.de and http://www.instructorials.com DIY Magazines
Offline Offline
Newbie
View Profile
Logged
Pages: [1]   Go Up
Print
Jump to:
