Topic: Help. Arduino IDE does not run on MAC OSX 10.7 (Read 4892 times) previous topic - next topic
willemnitert
I have an Arduino Mega 2650.
I installed the Arduino IDE 1.0.2 on my iMAC (MAC OSX 10.7) and started it. The IDE window appears, but without the menu. A pop up window or error message appears but disappears very quickly, so I cannot read it. I have the newest Java Run Time environment installed.
The Arduino IDE and the Mega board work very well on my Laptop running Windows.
What am I doing wrong?
Thanks in advance for some help.
kd7eir
Launch Terminal from /Applications/Utilities/ and type the following command:  java -version
Let us know what it says.
A recent Apple OS X update actually REMOVED Java.
wangfanstar
I have a same problem , but the old version arduino 0023 can run normally in mac os 10.7 and 10.8. wish to be solved.  THE PROCESSING SOFTWARE also have this problem.
willemnitert
Results of the java -version command :
Java(TM) SE Runtime Environment (build 1.6.0_37-b06-434-11M3909)
Java HotSpot(TM) 64-Bit Server VM (build 20.12-b01-434, mixed mode)
willemnitert
I try to install and run the Arduino IDE on MAC OSX 10.7.
It installs, but after startup the IDE window appears without the menu line. I see an error message flashing by, but I do not see it long enough to read it. I suspect, that the JAVA environment and the Arduino IDE are not compatible. My question:
On MAC OSX 10.7: what should be installed (in other words, what are the prerequisites) on MAC OSX to be able to run the Arduino IDE? Since MAC OSX 10.7 (Lion) does not come with JAVA, the installation and version number of JAVA, and perhaps other packages necessary, should be described in the software download page on the Arduino website.
Can an expert with enough karma explain to me, what I should have besides MAC OSX 10.7?
I have JAVA version 7 update 9 installed.
Thanks in advance.
James C4S
There isn't a need to capitalize Java, it isn't an acronym.  (Neither is Mac).
I'm not sure what you mean by Java Version 7, where are you seeing that?
When I check my Java version at the command line, I get:
James-MBP2b:~ james$ java -version
java version "1.6.0_37"
willemnitert
Version 7, Update 9 is mentioned on the Java site, http://www.java.co/nl/download/index.jsp
When I check my java version, I get:
willemnitert
Tried older version of Arduino IDE (0023), problem remains.
Nick Gammon
That's progress for you.
More info:
dxw00d
It all (Arduino IDE 0022, 1.0, 1.0.1, 1.0.2, Processing 1.5.1, 2.0b6) runs fine on my 10.7.5 system. I seem to have the same version of Java installed.
Have you tried running the disk utility verify permissions?
willemnitert
I have run the Disk Utility to verify the permissions. Still no menu on the IDE window.
James C4S
On the terminal run:
"ps aux | grep terminal"
and post the results (in code tags)
Nick Gammon
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Threads merged.
- Moderator
More info:
willemnitert
Results of the command:
iMac-van-W:~ wnitert$ ps aux | grep terminal
wnitert          479   0,0  0,0  2434892    488 s000  R+    9:24pm   0:00.00 grep terminal
/code]
Nick Gammon
I couldn't get 1.0.2 working on my Mac. Try 1.0.1.
Alternatively, if you have a "hardware" folder inside your Arduino documents folder try renaming that (I've heard that might help).
More info:
